Old 06-23-2002, 07:14 PM   #1
-=Stu=-
UK Member
My Ride: .
Tech Question: 330 CiC - Limited Slip ?
This may be an absoultely pathetic question so I applogose in advance
Does any of the E46 models have Limited Slip Diff. ? Just wanted to know.
Sorry
Thanks,
Stuart.
-=Stu=- is offline   Reply With Quote
Old 06-23-2002, 07:46 PM   #2
xS3x
mi casa @ technik
My Ride: 2002 330Ci
Send a message via MSN to xS3x
i believe they have an open differential
xS3x is offline   Reply With Quote
Old 06-23-2002, 07:52 PM   #3
-=Stu=-
UK Member
My Ride: .
Question
what that mean ?
Thanks,
Stuart.
Old 06-23-2002, 08:44 PM   #4
samir@technik
samir@technikpower.com
My Ride: 335/330/M3
Only the ///M models come with LSDs...the rest get open diffs. However, there are LSDs (aftermarket) available for regular E46s.
samir@technik is offline   Reply With Quote
Old 06-23-2002, 09:15 PM   #5
Coldintake
Registered OG User
My Ride: Mid-engine beast
Uh... I'm almost certain ALL e46's come with a LSD. Most of the aftermarket ones are open, such as dinan.
Even some of the e36's had a LSD.
There is a way to find out...
Start to peel out, if you see 2 rear tire marks, you have a LSD. If you only see one tire mark you have Non-LSD.
Coldintake is offline   Reply With Quote
Old 06-23-2002, 09:54 PM   #6
abqhudson
My Ride: 05 325ci, 04 530i
No LSDs for e46 except M3.
It's a bummer.
abqhudson is offline   Reply With Quote
Old 06-23-2002, 11:03 PM   #7
B
OG Moderator Extraordinaire
B's Avatar
My Ride: 325iX-M3-525iT-M5
Send a message via AIM to B
Sorry my friend... you are incorrect.
Samir/Technik's response was on point though.
peace
B
B is offline   Reply With Quote
Old 06-23-2002, 11:34 PM   #8
Fraggle
My Ride: 2001 330Ci
Technik is correct, however, e46's (non ///M) use the brakes individually on the rear wheels to arrest and control spin provided you haven't pushed the DSC/ABD button.
If you completely disable the DSC/ABD (3 second push) it is perfectly possible to peg-leg a launch (one wheel spinning).
Technik, I have been looking for an aftermarket torsen differential, are there any available yet? I was under the impression there were not.
Fraggle is offline   Reply With Quote
Old 06-24-2002, 03:59 AM   #9
Coldintake
Registered OG User
Oh well, I always thought it was a LSD. Just another excuse to peel out. :tongue:
Old 06-24-2002, 06:19 AM   #10
-=Stu=-
UK Member
My Ride: .
How good is the DSC etc at compensating for not having LSD.. ?
I know it isn't going to be anywhere near as good but, in terms of reducing damage to the rear for example when accelerating hard from stationary round a corner ?
Thanks,
Stuart.
Old 06-24-2002, 10:23 AM   #11
Fraggle
My Ride: 2001 330Ci
DSC/ADB is actually fairly good at keeping the tires from spinning on launches, even around corners. With all the idiot controls on, you would be hard pressed to spin your car out on a launch.
It is not, however, performance oriented. That is my complaint against it. For DSC/ADB to work it has to use your brakes and/or cut your throttle, which obviously hurts acceleration. It's another thing to interject between the driver and the road that isn't completely predictable.
Old 06-24-2002, 10:27 AM   #12
Fraggle
My Ride: 2001 330Ci
FYI on a torsen differential
A torsen type differential is available for the 323/328 e46's but has not yet been either adapted or certified to work on 325/330's
(I don't see why it wouldn't, but I'm not gonna try until I know)
see the attached e-mail
Yes there will be an application for the 330i. Will let you know when it is available.
Tom
Some lowlife wrote:
> On the website Part No. 246428310 is listed for the BMW E46 323i/328i. Is there an application for the E46 BMW E46 2001 330Ci?
Hiop Race-Tec, Inc
Tom Jackson
Ph: 480.941.5233
Fax: 480.941.0233
http://www.hioprace-tec.com
mailto: hiopusa@hioprace-tec.com
