Bixenon retrofit DIY - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 12-28-2003, 01:33 PM   #1
Scott
My Ride: 03 330 ZHP 01 X5 3.0
I wired up my bixenons and wrote a DIY today. I'm too lazy to re-key it here, see link below:
http://www.bimmerfest.com/forums/showthread.php?t=46813
--Scott
Scott is offline   Reply With Quote
Old 12-28-2003, 02:15 PM   #2
itchyNscratchy
Help me Help you!
My Ride: Undrpwr&Ovrweight2.5
Re: Bixenon retrofit DIY
--Scott
scott ur the man!
been waiting for the diy since you accomplished this awhile ago!!!
thx!!
List of mods:
BONE STOCK
itchyNscratchy is offline   Reply With Quote
Old 12-28-2003, 03:45 PM   #3
itzjonjon69
My Ride: 09 E92 M3
Send a message via AIM to itzjonjon69
after seeing the installation i dont wanna do it anymore its just too confusing
Gone but not forgotten:
2009 gti
2011 s4
2009 c63
2011 335is
IG: @joneffingvo
itzjonjon69 is offline   Reply With Quote
Old 01-02-2004, 11:14 PM   #4
Scott
No offense, but if connecting 5 wires is too confusing, you are probably better off not attemptiing it.
03 330i ZHP
01 X5 3.0i
73 MGB Roadster
79 Triumph Spitfire 1500
Old 01-03-2004, 10:35 AM   #5
niL
is on da floor
niL's Avatar
My Ride: 2001 330i
Send a message via AIM to niL
It's only 5 wires. Scott, do you happen to know if the pre-facelift LCM's are the same as the facelifted LCM's? I'm doing a xenon to bi-xenon retrofit on my car.
2001 330i rebuilt from the salvage yard
From start to finish...
niL is offline   Reply With Quote
Old 01-03-2004, 11:53 AM   #6
Scott
pre/post facelifted LCMs are *not* the same, when xenon (or bixenon) is fitted.
The pre-facelift LCM will not have the pinout config to activate the shutters via the LCM, although you can use the stock highbeam/H7 wiring if you donty mind losing the flash to pass.
I have a facelifted bixenon LCM that I'll sell for $50 shipped (I bought it but didn't use it). Dont know if it will work in your car though. It also has the "auto" lights feature.
03 330i ZHP
01 X5 3.0i
73 MGB Roadster
Old 01-19-2004, 12:42 PM   #7
bradleyg
unregistered user
My Ride: '02 325ci
Scott- I noticed in your final DIY you decided not to go with a diode across the relay. Do you think this would still be a good choice? Any problems noted with the lights after your upgrade? I want to thank you for taking your time to type up the DIY.
--Brad
bradleyg is offline   Reply With Quote
Old 01-19-2004, 12:50 PM   #8
Scott
No probs...
No problems, my lights still work fine.
If the ETK diagram is correct, the relay I used has a pair of diodes built into it. I dedided to skip the external diodes.
The reason to add a diode is to prevent a voltage spike from reversing into the LCM (via the bixenon shutter lead) when the coil is de-energized and the mag field collapses. The diode blocks this and protects the LCM.
--Scott
Old 01-19-2004, 12:54 PM   #9
bradleyg
unregistered user
My Ride: '02 325ci
Thanks Scott. Have you attempted to retrofit the autoleveling sensors yet?
--Brad
Old 01-19-2004, 01:09 PM   #10
itzjonjon69
My Ride: 09 E92 M3
anyone in CA wanna install these for me?
2009 gti
2011 s4
2009 c63
2011 335is
IG: @joneffingvo
Old 01-19-2004, 01:10 PM   #11
Scott
Nope, been too lazy/lots going on/kids.
The sensors are easy, the wiring is the PITA.
Stay tuned... maybe in the Spring.
Old 01-20-2004, 01:43 AM   #12
cyberhide
My Ride: 2001 330i
Damn, now I just need to figure out howto use a facelifted lcm in my pre-facelifted 330i. Its good to see its not hard to wire up once you've got an lcm that works with it.
-Chris
cyberhide is offline   Reply With Quote
Old 03-08-2004, 06:51 AM   #13
bimmer jon
My Ride: M3(Sold),2005 645ci
don't want to sound like an a$$hole after your very nice installation but is there a way just to ghetto rig it. WIll it simply work by hardwiring it from the existing hi-beam wires? I was thinking buying the harness and expererimenting with the power from the high beam wires. I told myself I wouldn't do major work to this car because when I went to trade in my last car, I was so pissed at all the massive amounts of wires and just everything that I did. The simpler the better for me. But if it won't work, i might attempt your DIY. its a great write-up. What do you think of the hardwire? do you think it will work?
B l a c k . S a p p h i r e . M e t a l l i c . 6 4 5 c i
bimmer jon is offline   Reply With Quote
Old 03-08-2004, 10:02 AM   #14
bradleyg
unregistered user
My Ride: '02 325ci
You can't ghetto rig it from the high beam wires because they get connected to the inner halogen lights. Those are still used for flashing, and daytime rumnning lights. You could possibly introduce a ton of problems if you try to cut/paste/splice those wires to try to rig something. I can vouch for scott's diy, it's a real good write up and not tough to do at all. I used his diy to get the highbeams going in a friend's car. My next goal when I get time will be the autolevleing for that car. Wiring the car scott's way really is painless and is a clean install.
Old 03-08-2004, 10:11 AM   #15
bimmer jon
wait, so the halogens are still used with bi-xenons. i thought that they weren't used but just there for looks and DRL. so during the daytime, there used for flashing and when the headlights are on, the bi-xenons are used. is that what you are saying. i have no experience with these so forgive me if i'm wrong. i think thats what I got from your post. Also, i read that you may need a new LCM right.
Old 03-08-2004, 10:42 AM   #16
bradleyg
unregistered user
My Ride: '02 325ci
The inner halogen (your highbeams now) are used for both the daytime running lights and flashing, like when you pull back on the turn signal stalk. Pushing forward on the turn signal stalk will turn on the bixenon highbeams (just like now how it turns your brights on now and keeps them on). The bixenon will do both the low and high beam right out of that same projector...all the highbeams are is that flap opening up to let more light out.
I can't say for sure if you need a new lcm, the car I upgraded was a 2002 coupe, and we had it flashed at the dealer to accept the bixenons. You may need a new LCM since i don't think that bi-xenons were available in 01. If they were available when your car was built then chances are you may have the correct lcm.
Old 03-09-2004, 05:56 PM   #17
Scott
Correct - you cannot operate the bixenons using the existing high beam wiring - you must tap into the LCM to make them work. Once the car is flashed for bixenons, your high beam wiring ceases to function as high beam wiring - it only works for DRL and flash to pass.
bradleyg - thanks for the compliments, glad to help.
03 330i ZHP
01 X5 3.0i
73 MGB Roadster
Old 03-22-2004, 12:10 PM   #18
PAGALM3
My Ride: 2002 M3
Scott,
Just PM'ed you with a quick question!
PAGALM3 is offline   Reply With Quote
Old 03-22-2004, 02:38 PM   #19
Scott
Originally Posted by PAGALM3
Scott,
Just replied
03 330i ZHP
01 X5 3.0i
73 MGB Roadster
Old 03-29-2004, 12:38 AM   #20
330 joe
Banned
My Ride: 330ci
dude, you dont even have a car or a license so why would you want stuff installed
330 joe is offline   Reply With Quote
