Old 06-24-2002, 09:20 AM   #1
SHANT330CI
Jo-Mamma
My Ride: 2013 BMW 535i
Send a message via AIM to SHANT330CI
Question Question about my gauages
I recently bought the silver gauges from CEC, and during the installation process I had to remove the pins. Now that the gauge is in my pins are not lines up correctly..Have any of you had this problem before?? and if so how did guys/gals fix it I feal like this little guy
"It's not how you live and how you die, It's what you live for and what you die for"
SHANT330CI is offline   Reply With Quote
Old 06-24-2002, 09:29 AM   #2
Clem
Alpha Male
Clem's Avatar
My Ride: Twin Turbo'd Beast
1. Before you mount the pod back into the dash.
2. Install it w/o the front cover on, plug in the harnesses and turn the key to the "ON" position.
3. The needles with do an cycle in which they vibrate and find their resting position. Turn key to "OFF" position.
4. Unplug the harnesses w/o disturbing the needles
5. Adjust the needles slightly past their usual resting spot when the key is off.
6. Repeat steps 1 through 5 until the needles sit in the right spot.
7. Reassemble the gauge pod without disturbing the needles and reinstall back into the dash.
Clem is offline   Reply With Quote
Old 06-24-2002, 09:39 AM   #3
Clem
Alpha Male
Clem's Avatar
Old 06-24-2002, 09:48 AM   #4
blue_bimma
E46
My Ride: BMW
put your needles back on and rotate it COUNTER-CLOCKWISE (you'll feel resistance) until you get to the point where you want it to rest. plug it in and the meters should reset itself
https://lh5.googleusercontent.com/-zjEo_YuC2rI/TiISYslkcsI/AAAAAAAAD6Y/icoRA9K8EZA/bmw-12.jpg
blue_bimma is offline   Reply With Quote
