Sponsored by BAVSOUND
Old 01-01-2004, 06:12 PM   #1
Yellowmann
Rolling on Dubs. Got Boost?
My Ride: AA SC Y2K 323i
Send a message via AIM to Yellowmann
Question Aftermarket head unit with OEM speakers
Does all E46 have separate amps for our speakers even if we dont have HK system? If I was to hook up aftermarket unit and use my OEM speaker for the time being will the aftermaket unit amp mess up with the OEM amp? Im guessing it will amplify the OEM and that is not good. Is my speaker system a common ground system? I dont want to over heat anything...Has anyone done this?
Later this wont matter since the new speakers will run directly from the aftermarket unit.
TIA,
Charlie
Once A Yellowmann, Always A Yellowmann ...One Who Is Wise - Always Learn From Other People's Mistakes ...One Who Thinks That They Can Never Be Successful - Will Never Be Successful ...First You Don't Succeed - Try, Try Again ...
Yellowmann is offline   Reply With Quote
Old 01-01-2004, 06:27 PM   #2
egyptnads
Banned
My Ride: 2000 silver 323i
Send a message via AIM to egyptnads
i believe non hk systems arent pre amplified. you wont have any trouble hooking up an aftermarket headunit
egyptnads is offline   Reply With Quote
Old 01-01-2004, 06:29 PM   #3
Yellowmann
It must be cus I had to hook up the remote wire to the OEM harness in order to hear my OEM speakers. I just dont want it to amplify an amplify, might cause over heating...
Old 01-01-2004, 08:05 PM   #4
PM "Corrupted"
Clem's Padawan
My Ride: 2004 X3
Non HK = 1 amp
HK = 2 amps (except tourings)
AFAIK no head unit power drives speakers, amp for all systems.
PM "Corrupted" is offline   Reply With Quote
Old 01-01-2004, 08:21 PM   #5
Yellowmann
Originally posted by PM "Corrupted"
Non HK = 1 amp
Thanks for that info but wont it still be amplified twice... since the aftermarket unit is amplified. The only way that I got the OEM speaker to work was to hook the remote from the aftermarket unit to the OEM harness. I just want to make sure I wont damage something till I get new speakers.
Old 01-01-2004, 10:11 PM   #6
PM "Corrupted"
Clem's Padawan
My Ride: 2004 X3
Try a VEN 4.5 from Peripheral , it allows you to run factory speakers from new head unit. From their site....
Use any aftermarket radio with speaker level outputs and the VEN4.5 does the rest. Add the appropriate wire harness from "Best HarnessesTM” to simplify the installation
Old 01-03-2004, 07:55 PM   #7
FlyingDutchMan
My Ride: Built 02 M3
You can run the high output speaker outputs from the aftermarket headunit into the stock amps, the stock amps are high input and it works fine. The system will sound much better, I just added a Pioneer Premier to the stock HK system and it was well worth it.
FlyingDutchMan is offline   Reply With Quote
Old 01-03-2004, 08:00 PM   #8
Yellowmann
I got it working but just wanted to know if the OEM harness goes to the amp to power the OEM speaker or does it just turn on and bypass the OEM amp. If I take the remote wire off the OEM harness nothing works. I just dont want to over heat the OEM amp with my aftermarket unit. This is only a temp setup for now.
Thanks all for you input.
Charlie
