Sponsored by BAVSOUND
Old 01-01-2004, 11:31 PM   #1
m3kid
My Ride: M3
cd changer skipping becase of bass......help?!
Im running 2 12's HX2s....... they pound so much that the bass makes the cd changer skips. I am unable to enjoy the bass at the level i want because of the changer.
some people suggested to go with a MP3 device like phatbox or RCA ..... but i rather not if i can fix this problem with some other ways....
whould dynamat fix this if i wrap the cd changer with it? any suggestions would be helpful, thanks!.
m3kid is offline   Reply With Quote
Old 01-02-2004, 09:43 AM   #2
23wt
My Ride: E46 330Ci, E85 Z4
you can try moving the changer to the glovebox.. i've seen ppl do that...
23wt is offline   Reply With Quote
Old 01-07-2004, 06:41 AM   #3
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
How do you have it mounted and what kind of changer do you have? Some times changing the mounting angle of the changer will eliminate the skipping.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 01-07-2004, 01:32 PM   #4
ca1242
My Ride: 2003 330i
Dynamat most likely won't help. I would look into mounting location (it isn't mounted on the subwoofer box, is it?).
Also, check if you installer set the changer up properly. Some changers have springs that need to be configured for either vertical or horizontal mounting. If the springs are not setup correctly, it could cause skipping problems.
Old 01-07-2004, 02:11 PM   #5
bigjae1976
bigjae1976's Avatar
one more thing you can try, clean the lens on your CD changer and make sure the thing ain't broke! I had the same problem years ago with a Sony CD Changerand the suspension was messed up...one of the little rubber bands inside broke.
Old 01-08-2004, 12:56 AM   #6
m3kid
My Ride: M3
its a stock bmw 6 disc changer......... can you still adjust the springs?
Old 01-08-2004, 01:15 PM   #7
bigjae1976
bigjae1976's Avatar
I'm not sure how the stock changers are built but I don't think when they designed the stock changer they had lots of boomin' bass in mind. So it just may be that the changer sucks...like the rest of the stock HK system. You might have to move it out of the trunk.
