Old 02-13-2014, 07:43 AM   #1
jdjg
My Ride: e39, m52tub30
ESS T2+ Vacuum readings
hi, I have a question about vacuum readings in my new setup....
first Im just install the ESS T2+ supercharger without the FI Supercharger camshaft (248 intake/256 exhaust), and my Vacuum reading was around 15~16, now I install the Schricks Camshaft for Supercharger (248 intake/256 exhaust), and my vacuum values drop to 12.... its normal?, what are suppose to be a good vacuum values with this setup?
regards
jdjg is offline   Reply With Quote
Old 03-06-2014, 12:58 AM   #2
lab rat
My Ride: '02 330iT
My readings were always around -12 at idle (stock cam). But I have been chasing a vacuum leak for couple of years now so I'm really curious what other people get at idle.
Because sleeper
Old 03-25-2014, 10:38 PM   #3
Davew
My Ride: 2004 330ci Msport
Mines at 20 in-hg at idle, engine warm.
Davew is offline   Reply With Quote
Old 02-02-2015, 11:53 PM   #4
cosmos328Ci
My Ride: 398.5whp. 498.8ftlb
Mid 20's. (Pre-laminovas)
Last edited by cosmos328Ci; 02-03-2015 at 07:19 AM. Reason: The added info maybe helpful, as Davew commented. :)
cosmos328Ci is offline   Reply With Quote
Old 02-03-2015, 07:13 AM   #5
Davew
Originally Posted by cosmos328Ci View Post
Mid 20's.
I should aso comment, around 20 post laminovas, it was around 24 pre laminovas.
Old 02-03-2015, 11:44 AM   #6
lab rat
My Ride: '02 330iT
The pre/post laminova numbers are very important. If I had correct information I would have found my boost leak long time ago. If your boost gauge (pre laminova) doesn't reach at least 10PSI with TS2 you have a leak.
Mine was reading 8-9 which I thought was normal based on the TS2 specs.
Because sleeper
Old 02-03-2015, 05:19 PM   #7
jdjg
thanks!! nice you found your problem FPR
