Thread Tools Search this Thread Rating: Thread Rating: 23 votes, 4.83 average. Display Modes
Old 02-23-2014, 12:20 AM   #181
devinruss
My Ride: e46 330ci
I know almost nothing about engine mods, and whats smart, and what's stupid, and you'll probably hate me for asking this but what are some simple mods to boost hp?
devinruss is offline   Reply With Quote
Old 03-21-2014, 11:29 AM   #182
cosmos328Ci
My Ride: 398.5whp. 498.8ftlb
Yr/Model: 1999 / 328Ci
System SC: ESS Twin Screw, TS2
RWHP/TQ: 296 whp / 410 ftlb
Dyno type used to measure power: Dyno Dynamics
Note: Clutch is slipping badly.
Attachment 550889
Going into car as we speak:
UUC Twin Plate going on M54B30 then replacing my current M52TU28. Then re-tune. I will update when final Dyno has been completed.
M54B30, ESS TS2, Schrick Cams, S54 Cam Chain Tensioner, ATI Super Damper 6.8", 3.5" Throttle Body, XForce Headers, Custom Twin Exhaust, Quaife LSD 2.93:1, UUC Twin Plate and Lightened Flywheel, GSR Four-bolt Oil Pump, M56 Engine cover with Built-in CCV.
http://forum.e46fanatics.com/showthr...619&highlight=
cosmos328Ci is offline   Reply With Quote
Old 04-02-2014, 05:39 AM   #183
cosmos328Ci
Attachment 550889
Dyno- Dyno Dynamics:
Well, got email today from tuner, 340+ whp on petrol 98 (93 in USA) with M54B30 and new UUC Twin Plate Clutch.
Eflex sensor is not reading correct, once fixed it will be dynoed for E85.
Getting there,.. slowly.
Old 04-08-2014, 12:00 AM   #184
cosmos328Ci
M54B30 on 98 RON (93 USA)
Engine: M54B30
Kit/Stage: ESS TS2. (using ESS 15 psi pulley)
Other Power adders: Custom 2.5" exhaust, Haltech PS2000
Type of Dyno: Dyno Dynamics
Miles on car: 193K Km's (120K Miles)
Miles with S/C: 50K Km's
HP: 329 whp
TRQ: 424 ftlb
Dyno is of: Old M52TU28 on E85 (296whp) Vs New M54B30 on 98 Fuel (93 USA) (329whp)
Old 05-21-2014, 01:13 AM   #185
cosmos328Ci
Today: 357 Hp / 450 ft/lb - Dyno Dynamics
M54B30 on E85 - Still got the Meth/Water Injection to go. (could not get the controller to work ) So no meth yet, it's all hooked up and ready to go though.
Engine: M54B30
Other Power adders: Custom 2.5" exhaust, Haltech PS2000 ECU
HP: 357 whp
TRQ: 450 ftlb
Dyno is of: M54B30 on 98 Fuel (93 USA) (329whp) Vs Current M54B30 on E85 Fuel (357whp)
Old 05-23-2014, 03:16 PM   #186
carbonm32002
My Ride: 2002 bmw m3
boost 4 days counting down!!
4 days until start date at max psi. will have before and after dyno!!
carbonm32002 is offline   Reply With Quote
Old 05-24-2014, 11:53 PM   #187
cosmos328Ci
Awsome.
How much boost are you going for?
Whats your set up?
All the best with the results.
Old 05-27-2014, 02:05 PM   #188
carbonm32002
hello Cosmos, ran dyno today, currently has pulleys, catback exhaust, k&n intake, with cat, ecu upgrade by previous owner. as for turbo, standard 9 psi, bolt on, keeping same exhaust. now its just a matter of waiting until i get car back! Dyno was done on it, a little dissapointed, 274whp,(was expecting 280's-290's) on a mustang dyno, humidity 35%, 70f. they say that on dynojet numbers are greater. first time being in person dyno, sounded loud!! interestingly enough i have read some articles that no 2 cars are ever the same, even with same mods. see dyno attachment
Old 05-27-2014, 05:35 PM   #189
cosmos328Ci
Hi carbonm32002,
Nice numbers, considering they are not dynojet numbers.
Probably looking at around the 290 whp on a Dynojet.
How does the car feel, great I expect. Not as great when ya get your TURBO though,
What is the ECU upgrade from the previous owner?
Looking forward to the final results, should be awsome.
Cheers
Old 05-27-2014, 06:28 PM   #190
carbonm32002
not really sure to be honest, i know the speed limiter was removed, tuned for midrange. also, like a month before i had valve adjustment, found out only 5 valves were off and only by a shim, my mechanic told me it was a good sign, well maintained, last valve adjustment done in the late 60XXX's. i did it as preventative maintenance. also new water pump thermostat fan clutch going in, did also rear subframe. top subframe is being done to at shop. running strong!
Old 05-27-2014, 07:01 PM   #191
cosmos328Ci
Yeah, the valve adjustments on these motors always seem to be good.
Do you have any pics of the work on your rear sub frame?
Mine starting to feel a bit loose at the back, I will have to prop it up and see what needs doing. (No... i am not talking about all the wheel spin..) LOL.
Old 05-28-2014, 11:29 AM   #192
carbonm32002
Rear subframe reinforcement pics
had hairline cracks, definitely wanted that done, heard horror stories of people that waited until its really bad. attached are pics. akg mounts installed as well. work done at bimmer clinic. definitely felt more solid after work done.
ID:	559876   Click image for larger version
ID:	559877   Click image for larger version
ID:	559878   Click image for larger version
ID:	559880   Click image for larger version
Old 05-28-2014, 08:19 PM   #193
cosmos328Ci
Great pics, thanks carbonm32002.
Old 09-10-2014, 08:14 AM   #194
motopoint
My Ride: 2002 E46 M3 S3
2002 E46 M3 Supercharged
Not too happy with the results but will post anyway
2002 E46 M3 Dinan Supercharged (Vortech V2)
P3 Gauge reading 5.6 lbs boost
Dynojet Numbers
328.9 Hp
272.4 Torque
Dinan Claims (4-4.5 lbs boost) Crank Pulley 4 5/8 and SC Pulley 4 1/2 (Holy Hugeness... any bigger I'd have to add a cut out in the Hood...LoL
It seems most other systems are running CP 5" and SC Pulley 3.40 to 3.33 (8-10/11 lbs boost)
So looks like the Winter Project will be as follows:
Headers, 200 cell cats/resinated, X-pipe non resinated to add to my Dinan muffler
Active Autowerke Intercooler
Snow performance Boost control Meth injection
Prob the 5" CP and SC 3.40 pulley
Retuned DME
Looking for that extra 100 HP.... Any thoughts???
motopoint is offline   Reply With Quote
Old 09-11-2014, 02:25 PM   #195
6spd_legend
My Ride: acura legend 6spd
Dynojet Numbers
328.9 Hp
272.4 Torque
Retuned DME
If you want to make real power honestly drop the Dinan and go w/ a custom tune ess vt2-550 or intercooled AA kit. Or if you want to REALLY make power look into an FSR motorsports or Maximum PSI turbo kit.
2001 LSB M3 Coupe
6spd_legend is offline   Reply With Quote
Old 09-25-2014, 09:43 PM   #196
cosmos328Ci
Mainline Dyno. 370.7 HP, 681.5 Nm
Today I did a before and after OEM Air box V Cone filter in engine bay.
OEM air box has 3" hole in bottom.
OEM air box 337.4 Hp and 643.4 Nm
Cone filter in engine bay 370.7 HP, 681.5 Nm
(276.4 kW & 502.6 lbft)
Gain:
Hp 33.3 (24.8 kW)
Nm 38.1 (28.1 ftlb)
Name:	HP and Tq. Mainline Dyno. WP_20140926_11_28_07_Pro.jpg
ID:	575137   Click image for larger version
Old 09-26-2014, 06:34 AM   #197
Patton323I
My Ride: R1100GS E46 E53
Gain:
Hp 33.3 (24.8 kW)
Nm 38.1 (28.1 ftlb)
that's an insane power gain... That's going to make me question using the factory air box now...
Patton323I is offline   Reply With Quote
Old 09-26-2014, 05:15 PM   #198
cosmos328Ci
Point to note is, I am at the point of boost where the OEM intake system is greatly restricted. (18-19 psi)
So this gain would not be replicated on an engine where hp and tq are not greatly restricted by the intake system.
I have a bigger throttle body and 4" piping to go on yet.
Old 11-19-2014, 11:15 PM   #199
Tylerm325xi
My Ride: E46_325xi
quick question this might be dumb so if so don't ridicule me but if i put on an intercooler with a pod filter and run the car with out a turbo until im able to get one will the car default to any weird rich or lean air fuel ratios ?
Tylerm325xi is offline   Reply With Quote
Old 11-24-2014, 01:47 AM   #200
turbosnail
Hey guys I have a turbo 325i and the engine light keeps coming on reading multiple misfire , and the cars rpms keep playing , any suggestions on what it could be ?
turbosnail is offline   Reply With Quote
