All Boosted E46 - registry - Page 9 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 23 votes, 4.83 average. Display Modes
Old 06-21-2013, 04:40 PM   #161
bonhamsurf
My Ride: 2003 M3 Convertible
Originally Posted by m3rdpower View Post
Im runnin AA S/C on meth with my 04 M3 soon to be dynoed.
Have you dynoed it with the meth yet?
Paul
2003 M3 Convertible
Hawaii Web Design & Static Performance
bonhamsurf is offline   Reply With Quote
Old 06-21-2013, 04:48 PM   #162
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
AA stage 2.5 running 12 PSI, intercoolee, Rotrex blower and oil cooler, Bimmerbrakes headers, AEM stage 2 meth injection kit, and ProSport gauges. Installed and custom fabrication by RRT.
| 435 HP 328Ci | RRT Racing | Designer Wraps | Active Autowerke | Vorsteiner | STATUS Racing |
Timeless Motor Group
Old 06-21-2013, 04:54 PM   #163
JohnBlaze
My Ride: Black Sunshine
AA stage 2.5 running 12 PSI, intercoolee, Rotrex blower and oil cooler, Bimmerbrakes headers, AEM stage 2 meth injection kit, ProSport gauges, and RRT engine build.
engine build, what did you have built?
05 ZHP w/Epic tuned s54, Euro headers&Sect.1, Dinan 3.91 and a lot of other things built by Road Race Technologies
JohnBlaze is offline   Reply With Quote
Sponsored Links
Advertisement
Old 06-21-2013, 05:23 PM   #164
2000_328CI
2000_328CI's Avatar
Assembled. Fabricated. Whatever
A lot of the IC piping from Active didn't fit so they had to build their own piping. Also did tons of custom work to fit 330 headers on a 328.
Old 06-21-2013, 05:27 PM   #165
bonhamsurf
WHat numbers did you make?
Paul
2003 M3 Convertible
Old 06-21-2013, 05:45 PM   #166
2000_328CI
2000_328CI's Avatar
Only tested so far pre tune and without meth. Car did 300 wheel with a 14 AFR. We're expecting to be up around 350 after sorting everything out.
Old 06-21-2013, 05:57 PM   #167
JohnBlaze
that's not a built engine though. 330i headers bolt right up it's only where they connect to the catback or in your case catless back system they don't fit.
Also, modifying IC piping isn't a built engine, that's all just custom fabrication. I knew you'd want to know so you don't claim that at a show and get a bunch of $hit
Old 06-21-2013, 06:53 PM   #168
2000_328CI
2000_328CI's Avatar
Good call. And Fixed
Old 06-29-2013, 03:35 PM   #169
bees323
My Ride: 323ci
2000 323ci
283hp/232tq 5psi
AA stage 2, cams,header, exhuast, m54b30
10psi coming soon
bees323 is offline   Reply With Quote
Old 07-17-2013, 07:27 PM   #170
m3sc
My Ride: 06 TurboM3,06 SC C55
Max PSI Stage 1
Getting this kit installed at Castro's in Los Angeles....
m3sc is offline   Reply With Quote
Old 08-01-2013, 01:39 PM   #171
fmzip
My Ride: '08 328xi / '15 S4
See my sig
fmzip is offline   Reply With Quote
Old 08-06-2013, 10:07 AM   #172
bmeyer
My Ride: 2006 M3
2006 M3 Coupe / SMG / Evolve SMG software / Fabspeed headers / CPI Euro200R / VF570 + extras
Hoping to make it to the dyno in Sept. and re-tune with Evolve. Looking to hit 500+whp before I park it for the year.
'06 ///M3 Coupe | MaxPSI Stage 2+
bmeyer is offline   Reply With Quote
Old 09-25-2013, 04:00 PM   #173
cannockwolf
My Ride: 330Ci ESS TS2+
E46 330ci
ESS TS2+ 8.5psi
Schrick Cams
Rear Wheel BHP 328
Rear Wheel Torque 299
They only went to 6500 but my car can do 7000 now so it should be a bit more than that
Dave :: My Photo Site
cannockwolf is offline   Reply With Quote
Old 10-20-2013, 04:23 AM   #174
_SIIM_
My Ride: 2004 325
E46 2004 325 steptronic.
Asa T313/G-power with original soft still
No idea how much power,but it is lot of faster.
The kit is also for sale 1600-. eur and located in finland. 10 tkm on it.
G-POWER supercharger system SK Plus RS "Sporty Drive"
Basis: 320i/M54, 170 hp (125 kW) increased to 215 hp (158 kW)/245 Nm
Basis: 325i/M54, 192 hp (141 kW) increased to 240 hp (176 kW)/290 Nm
Basis: 330i/M54, 231 hp (170 kW) increased to 306 hp (225 kW)/360 Nm
_SIIM_ is offline   Reply With Quote
Old 10-28-2013, 09:04 PM   #175
Patton323I
My Ride: R1100GS E46 E53
I have joined the ranks.
Patton323I is offline   Reply With Quote
Old 10-29-2013, 12:09 AM   #176
m3sc
Max PSI Stage 2.5?
I decided to upsize the turbo from the 6266 journal bearing version to the 6466 ball bearing version.
Should have an advantage over the HPF 6766 older turbo unit. It's a newer design and spools much faster than the HPF.
Less lag and more immediate response is the perfect combo. Larger injectors, fuel system and up the boost and set timing and AFR for MS109 or 91 Oct with the press of the sport button.
Old 10-29-2013, 02:16 PM   #177
MachRc
is divorced
MachRc's Avatar
My Ride: 2003 Technik S1 M3
^ SHould start a build thread. I live in west covina aswell, and would love to check it out after its finished.
"Can it be, we've run out of time? You're alive.. ohhh? In these streets we living to die. When it's your time, you will know..
..cause it ain't hard to tell. "
MachRc is offline   Reply With Quote
Old 02-10-2014, 04:43 AM   #178
GeorgeGG
My Ride: 323
GeorgeGG
1999 323i (3.0 built motor)
Turbocharged
778HP (not finished yet, went out of fuel)
video
last test (keep in mind that this is dyno dynamics where 778HP would be 855ish on Dynojet)
GeorgeGG is offline   Reply With Quote
Old 02-11-2014, 10:56 AM   #179
lobudgetlovemy330
My Ride: 2002 330ci convertib
Thumbs Up my dream beamer , maybe on day for my '02 330ci convert
Originally Posted by jonsibal View Post
Can we have a roll call for all forced induction E46 -turbo or supercharged.
Post your yr/model, rear wheel hp/tq and which system (ASA, AA etc) did you use. Oh and also which Dyno did you guys used to measure the power.
I know we got Jojo, Kromex and others here that got these beast.
Thanks.
perfect beamer future goal 4 my '02 330ci convertible
lobudgetlovemy330 is offline   Reply With Quote
Old 02-11-2014, 11:32 AM   #180
Viral@ActiveAutowerke
Past Site Sponsor
My Ride: E46 M3
Awesome I have an 02 Convertible myself.
Viral@ActiveAutowerke is offline   Reply With Quote
