Welcome to the E46Fanatics forums. E46Fanatics is the premiere website for BMW 3 series owners around the world with interactive forums, a geographical enthusiast directory, photo galleries, and technical information for BMW enthusiasts. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
Forced Induction Forum Sponsored by Active Autowerke
Discuss supercharging, turbocharging and even nitrous and water injection here. Sponsored by Active Autowerke |
#1 |
Nitrous as an option for E46?
Seeing lots of superchargers and maybe a turbo... Anybody tried Nitrous for their E46 330i? Any luck not blowing up the engine? Any good kits developed?
-Greg
'01 330i with some Dinan stuff '04 C320 4-matic Sportwagon '99 K1200LT ** Sig image linked to restricted directory causing a password pop up ** |
#2 |
needs a new sig...
i have seen them in use on a 2001 330ci and a 2002 M3..the 330 was supercharged as well. The M3 hasnt had any problems yet...
#3 | |
Which kits? Wet?Dry? direct injection?
#4 |
needs a new sig...
direct port on both vehicles...same owner...
#5 |
XXXX
It's a complete mistake for an inordinate amount of reasons. You can eat a chicken wing whole and you might be full, but that doesnt mean its not gonna hurt on the way out. Sorry for the shtty analogy.
#6 | |
#7 |
XXXX
I just dont want to people suffer on the basis of misconception.
#8 | |
[_33-l- [_a[\/]e[R
330Ci///\/\anual
#9 |
The G.O.A.T. is Baccckkkkk!
Hmmm i was under the impression if it wasn't abused you'd be fine with it. I was looking to do a small set up in my car with possibly 2-3 1lb bottles basically for show but i'd use it on occasion. I've also heard it's less of an issue on a forced induction vehicle. Any comments?
09' Alpine White E92 335i - Coral l Aluminum l Sport l Premium l Cold l Steptronic l Comfort Access l Navi l Logic7 l iPod & USB... with a few mods!!
#10 |
I was under the impression that Nitrous helped FI more by it's cooling nature. Increase air density and oxygen. Could be wrong though.
#11 |
Where am I?
nitrous is safe for anycar if used correctly. most people over do it and cause a lean condition which can blow your engine up.
I would say a 50shot is not too much even for 323/325. if I remember correctly Zex has a kit that replaces your airfilter. the nozzles are behind the airfilter element? I dont' remember exactly. here is a pic of it: ![]() www.zex.com
'87 325iS Sold but not forgotten. '08 MINI Cooper S Mellow Yellow '00 M Coupe Dakar Duck '02 330ia |
#12 |
From doing research and asking around the answer i get from everyone is only use Nitrous Express
#13 |
[_33-l- [_a[\/]e[R
Zex is crap. NX is the way to go. A normal wet kit has been done on the 330 up to 75shot. I'm sure 100shot is good too. Only problem I see is our manifolds are so twisted and bent that the fuel would never get there properly. I did direct port on mine so Ill never have that problem or a lean condition. I can run 40-500shot, like Ill ever need it. I don't plan on going above 100 without a controller though.
330Ci///\/\anual
#14 |
You have any Dyno runs with your NX setup?
0-60? 1/4 mi?
#15 |
how much would a complete direct port cost? and would i need any other components?
old New
#16 |
P.I.M.P.
The problem is, the cost of a properly set up Nitrous kit, with direct port and a controller, will be close to the cost of a SC....which doesn't make Nitrous a very attractive option IMHO.
#17 |
all I can say now is ASA kit in April (hopefully ECU programming complete by then).
and headers
#18 |
on a supercharged 3er would there have to be any ecu reprograming if nitrous was added?
2000 328Ci 300+hp ESS 9 P.S.I. Supercharger Racing Dynamics Tornado Body Kit custom low-comp pistons Supersprint Headers titanium valve springs Brembo 14'' BBK 18''SSR GT1 Wheels H&R Coilovers, RDSport Sway Bars, KMAC Front Camber Kit UUC SSK, Lightweight Flywheel, Shift Knob and Ebrake Active Autowerke Rear Strut Bar, Exhaust, and Rear Control Arms Carbon Fiber Grill,Engine Covers, Interior Trim, and Strut Bar |
#19 | |
#20 |
Assuming you use the correct nitours and/or fuel jets, then you are fine. EGT gagues or W/B are nice to have to ensure you are not running under a lean condition.
Anytime nitorus is mixed with boost, boost should be turned down. It would also be great to have a seperate map for it as well. Dry kits just injects the nitrous through the intake tubing and bumps up the stock fuel pressure. Wet kits DPI & single nozzle. The single nozzles like the dry kits mounts in the intake tubing and sprays nitrous and fuel (rather then bumping up the fuel pressure). DPI has individual nozzles that sprays fuel and nitrous into each intake manifold runner (or plenum). NX and NOS both make good kits. NOS has been knowing to have their soleniods stick. People complain about popping motors because oif them sticking. If the kit was properly installed with a Fuel Pressure Safety Switch (FPSS), then these problems would be non existent.
Team MSR RASR - Racers Against Street Racing 02 WRX JDM Swapped T3/T04E 01 330ci 5mt 01 APR'd S4 03 KB'd Cobra "The difference between men and boys are the speed of their toys" |
