Go Back   E46Fanatics > Tuning & Tech > Forced Induction Forum Sponsored by Active Autowerke
Old 01-19-2004, 02:40 PM   #1
mchM3
My Ride: 2003 M3
supercharged e46 m3
whoa just saw activeauto's supercharged m3 it loooks sick has anuone seen it yet or posted pics of the intercooler?
2003 m3 silver, H&R SPRINGS, 20 INCH HRE 841 IN SILVER 20X10.5 IN REAR,STOP TECH BIG BRAKE UPGRADE, AC SCHNITZER CARBON FIBER FRONT LIP(cec sucks!!(GRUPPE M INTAKE, ACTIVE AUTOWERKES EXHAUST, AND AC-S PEDALS.. carbon fiber hood, 04 tailights, demon eyes.
mchM3 is offline   Reply With Quote
Old 01-19-2004, 02:43 PM   #2
Unveiled
Guest
Posts: n/a
somebody please post pics!
Old 01-19-2004, 02:50 PM   #3
budman
-not a mod-
budman's Avatar
My Ride: is your mom
Send a message via AIM to budman Send a message via Yahoo to budman
Search the Showroom... somebody already posted pics of it all...
-Gunnar
budman is offline   Reply With Quote
Old 01-19-2004, 03:08 PM   #4
tim330i
Owner/Admin
tim330i's Avatar
My Ride: 03 Ti Silver M3
we have a forced induction forum for just this sort of thing
http://forum.e46fanatics.com/showthread.php?t=135516
The F32 4 Series Coupe - On sale summer 2013
More pictures of the F32 4 Series Coupe
tim330i is offline   Reply With Quote
Old 01-19-2004, 04:17 PM   #5
Boosted330
Eurowerkz Co-Founder
My Ride: 993Cabrio/f30 335xi
Send a message via AIM to Boosted330
i was the first 1 they showed to to actually, i was also the first one they let to take pix,
http://forum.e46fanatics.com/showthread.php?t=133501
go there, i posted pix and everything
Past:
2010 MB C300 Sport
2001 BMW 330ci, Eurowerkz Co-Founding Car
1999 Shelby SP360 #150
Boosted330 is offline   Reply With Quote
Old 01-21-2004, 12:41 AM   #6
1BADM3
My Ride: 95 M3
i've had my stage 3 for 8 months now and it still runs good with no problems
ID:	66087   Click image for larger version
1BADM3 is offline   Reply With Quote
Old 01-21-2004, 10:50 AM   #7
Will ZCPM3
Will ZCPM3's Avatar
My Ride: ///M3
with rms did they change your internals
Will ZCPM3 is offline   Reply With Quote
Old 01-21-2004, 11:28 PM   #8
1BADM3
My Ride: 95 M3
i dropped in new pistons myself. rms had the pistons made to their specs and dropped shipped them to me. instead of 11.5:1, im running 9.5:1.
Old 01-22-2004, 02:51 PM   #9
BMWDon
My Ride: Needs a cage
That's the kind of shyte I'm talking about! Where's your boost set at and what kind of dyno numbers you putting down?
BMWDon is offline   Reply With Quote
Old 01-23-2004, 12:08 AM   #10
1BADM3
My Ride: 95 M3
i hit the dyno today, the rpm cut off at 6000 rpm. it might be the wheels sensors or something cuz my abs light came on. i turned off the traction control. at 6K rpm i was making 347@ 8psi on a mustang dyno. im gonna try again tommorrow.
Old 01-23-2004, 07:40 AM   #11
BMWDon
Nice, I think I've read you need to pull an assload of fuses in order to get that thing to quit shutting itself down, any fuse that deals with traction control, good luck, post numbers, scan the dyno run and post that sucker!
Old 01-26-2004, 11:14 AM   #12
BMWDon
Did Osh say that 8psi was all you should run on a set of 9.5:1 pistons? I would of thought you could push more, maybe because you aren't running an intercooler? I decided to try a supercharger setup too, going with 9.0:1 pistons
Old 01-26-2004, 11:27 AM   #13
Will ZCPM3
Will ZCPM3's Avatar
My Ride: ///M3
isnt there an intercooler in the pics?
Old 01-26-2004, 11:44 AM   #14
1BADM3
My Ride: 95 M3
im supposed to to be boosting at 11-12psi. im thinking i maxed out the bypass valve which is set to run at 8.5psi. by the way the dyno chart was looking, if it could rev to 8k i'd be making about 405-410hp.
Old 01-26-2004, 11:58 AM   #15
BMWDon
I'm blind as a bat...my bad
1BADM3, you gots nice numbers for only 8.5psi, any reason why you haven't gotten around to upgrading your bypass valve yet? Just lazy or nervous? just kidding, I wonder at what point will the fuel pump cry foul when you try and go to the full 12 psi
Old 01-26-2004, 12:15 PM   #16
1BADM3
My Ride: 95 M3
bmwdon,
i'm just lazy. osh asked me to bring it to rms to crank up the boost and do some dynos down there. i think the fuel pump should be fine since im running 12 injectors.
Old 01-26-2004, 12:24 PM   #17
BMWDon
Jaysus! 12 injectors, damn man, that's crazy, you couldn't just have went with like 42lb injectors or something? And I'ld still be worried about the fuel pump, unless you now have 2 fuel pumps, one for each set of 6 injectors. That thing is crazy man, very nicely done, congrats on having one bad m3 Now I wonder if the 36lbs injectors will take me to where I hope to be with my s/c setup. fizzuk
Old 01-26-2004, 12:50 PM   #18
1BADM3
My Ride: 95 M3
i will put one in sooner or later. what s/c are you putting in?
Old 01-26-2004, 03:29 PM   #19
BMWDon
Got myself a Rotrex unit, same thing AA puts in their setups
