Old 03-28-2015, 10:34 PM   #1
taylor192
My Ride: 2003.5 M3
Brake bleeding question
Sorry if this has been discussed, I couldn't find the right terms to narrow my search.
I'm replacing brake lines (upgrading to stainless) and wondering if I can bleed each line as installed (starting with passenger rear) or if I should replace all 4 lines then bleed all 4.
I have 2 jack stands, so I can only work on the front or rear at a time. I'm hoping I can replace and bleed the rear lines, then replace and bleed the fronts. I don't have space (condo) for 2 more jack stands :-(.
Old 03-28-2015, 10:43 PM   #2
Foxtrot_Uniform
My Ride: 325Xi
You can bleed them as you go! Not a problem. I would think you would need a lift, or the car up on 4 jack stands, to do them all at the same time. I have always done mine as you described.
Foxtrot_Uniform is offline   Reply With Quote
Old 03-28-2015, 10:57 PM   #3
kendogg
My Ride: Way too many to list
Ya, I agree - no problem with doing them individually.
kendogg is offline   Reply With Quote
Old 03-30-2015, 09:36 AM   #4
Typeone08
My Ride: 01 325i sedan
Just start bleeding the line furthest from the master cylender. So rear passenger then driver side rear then passenger front then the driver side and u should be good.
Typeone08 is offline   Reply With Quote
Old 03-30-2015, 10:05 AM   #5
leblancrene
My Ride: volvo 240 bmwe46
You should bleed them one at a time as you replace them.Cap of the open end immediately as you remove pieces,fill bleed lines immediately so you
dont let air to to the abs dsc unit.If you were to replace all before bleeding
you would likely get air to abs unit which requires special procedure with
BMW dealer equipment to bleed.( Unless someone in fanatics knows and will tell us how to bypass dealer on this)If you are carefull as not to let air into abs
unit, keep master cylinder full, you should be just fine
leblancrene is offline   Reply With Quote
Old 04-02-2015, 04:05 AM   #6
50sKid
My Ride: 330i
You don't need to follow the 1970s rule for brake bleeding with the E46 (ie. rear passenger first)--it has ABS which means there is an independent line running to each wheel. You can replace the lines and bleed in any order.
If you're really worried about the master cylinder running dry, pick up this item from Harbor Freight:
http://www.harborfreight.com/brake-f...der-92924.html
It has a bottle that sits upside down in the reservoir and keeps it topped up with fluid.
Also, if you DO run the master cylinder dry for any reason and need to bleed it using the factory procedure, grab a K+CAN cable from eBay:
http://goo.gl/6i0MZk
It comes with INPA software, which you can use to activate the bleed procedure. I've used it and it works.
Good luck.
-Jason
50sKid is offline   Reply With Quote
