Thread Tools Search this Thread Rating: Thread Rating: 168 votes, 5.00 average. Display Modes
Old 06-06-2009, 10:23 AM   #181
gmwinder
My Ride: 325xi
CAB 325xi
I'm about to put mine back on this morning. I followed Tim's thread to get the old ones off even though it is a little different for the xi models (325 & 330). I ended up sending my old brackets with sleeves still in to Walter at Valley Motorwerks. He took the old ones out, replaced with new ones and shipped back the same day and didn't charge me a penny for doing the install...thanks Walter! including shipping both ways cost me $80 for the bushings and the labor.
I tried to put the brackets on with some Windex and they get stuck pretty quick so I guess I'm gonna need the mallet.
Gary
gmwinder is offline   Reply With Quote
Old 06-06-2009, 10:01 PM   #182
fmzip
My Ride: '08 328xi / '01 530i
Do you need to get an alignment after you replace them
fmzip is offline   Reply With Quote
Old 06-07-2009, 07:55 AM   #183
gmwinder
My Ride: 325xi
Alignment/bushings
After I got them back on, the drive is incredible...no wheel wobble...everything feels nice and tight and doesn't look like I need an alignment but I'll keep on eye on the tire wear.
One tip for 325xi owners: When outting the passenger side bracket back on, insert the furthest away bolt in the bracket first as the heat shield will prevent you from getting it in if not.
Gary
Old 07-24-2009, 10:58 PM   #184
TheRusski
My Ride: gone...
Great DIY!
Where did you all get Control Arms from?
TheRusski is offline   Reply With Quote
Old 08-17-2009, 10:45 PM   #185
hatchetman83
My Ride: 2001 330Ci
easier than I thought
Good description of the fix. I had to stare at it a while before I got up the nerve to do it, but after that it only took about 2 hours for both sides.
A couple of observations:
1) Apparently some of us have a one-piece aluminum brace under the front instead of individual steel tubes. I was just going to loosen the front 4 bolts and let it hang but it was so light I just pulled it off. No problem replacing.
2) To get the bushings off of the control arm I just went straight for the 3-jaw puller. The inner rubber portion stayed put for a while but as I kept cranking it started to slip off just fine. Much better than the cutting with a Dremel, etc.
Suspension is tighter, but this being a convertible there is still a little more body flex than I like. Oh, well- top down driving makes up for it.
hatchetman83 is offline   Reply With Quote
Old 08-26-2009, 12:03 PM   #186
bumere46
My Ride: E92
after replacing the bushings, do I need to do an alignment?
bumere46 is offline   Reply With Quote
Old 08-27-2009, 05:47 PM   #187
Furball
My Ride: 2000 328Ci
Only if your car pulls to one side or the other, or you notice weird tire wear.
I am about to delve into this tomorrow guys, I will take pics as well. I am replacing my control arms with Meyle and I will be using Powerflex bushings.
Furball is offline   Reply With Quote
Old 09-04-2009, 10:22 PM   #188
zYk09
My Ride: 2001 BMW 330i sedan
hi... i just replaced my bushing today... when it test drive it... feels good but when i hit 65mph to 70mph... the steering wheels shaking.. wheels are balanced and wheel allignment done already 2 days ago before putting the new bushing meyle HD. what seems to be wrong?
zYk09 is offline   Reply With Quote
Old 09-04-2009, 11:17 PM   #189
Furball
My Ride: 2000 328Ci
check your sway bar endlinks and tie rod ends
Old 02-24-2010, 12:38 PM   #190
mike86325
My Ride: ///M3
So I've been putting this off for a while but I'm considering doing the DIY soon. I remember reading that when you swap the FCABs you must replace the bolts for the carriers and the bolts for the torsion (or reinforcement) plate. I did this when I replaced everything on my 323i years ago, but I have no clue what the bolt sizes were.
Does anyone know the bolt sizes for the carriers and reinforcement plate for the M3?
2003.5 Tiag SMG ///M3
FOR SALE:
2 Michelin PS2 275/30/19: http://forum.e46fanatics.com/showthread.php?t=665386
Pre-face Sedan Tails, Corners, Side markers: http://forum.e46fanatics.com/showthread.php?t=708875
mike86325 is offline   Reply With Quote
Old 03-29-2010, 11:05 PM   #191
merlinzeta
My Ride: e46 318i
Clattering noise remains :(
Thank you for this, I did mine today. I used bushings I got from ebay (I know... but I'm a poor student :/)
I just did the left side today, as that was the side that was making clattering noises on bumps. Sad to say, the noise is still there
Anyone know what other things can cause clattering sounds when going over bumps? Or at least what I can do to try diagnose the problem?
The noise is so loud that people will turn heads to look at my car
Thanks!
merlinzeta is offline   Reply With Quote
Old 04-08-2010, 08:50 PM   #192
manaman22
My Ride: 2000 323i
This is a wonderful tool for getting this done. I found it quite useful when I did this with my Dad a few weekends ago. Tim, without this, I don't think I could have mustered the gusto to tackle it! Thanks for the write-up.
I decided to install Meyle HD bushings and carriers. I wanted something more than stock, while not sacrificing too much comfort for the daily driver. They have been great. Tightened things up and made my front end clunk disappear. Also took care of the end-links while I was in there. No sweat while you have the tires off.
The only thing I did different was use mineral oil for the reassembly. According to Dad's "sagely" advice, mineral oil would provide assembly lubrication without damaging the rubber and would wash out with time. After about three weeks, I have not had any noise problems and the bushings are holding up fine.
Once again, thanks for the write-up, Tim!
@merlinzeta,
Take a look at your sway-bar end links. The seals on the ball joints may be ruptured and have lost their lubrication. That might be the cause. They are easy to change as long as you have a thin set of wrenches. They run between $60 and $80 a set for the most part. Hope it helps.
manaman22 is offline   Reply With Quote
Old 05-18-2010, 11:52 PM   #193
alwaysbored786
My Ride: M3
what sizes are all the bolts that need to be removed, can any one remember? I like to be prepared.
*NO F-BOMBS IN SIGS*
How to refinish rims
2004 Noble M12 GTO 3R
1998 M3 Coupe
1996 BMW M3
2003 330I ZHP
1998 Honda Civic - Sister Totaled
2002 330CI - SOLD
2006 CBR 600RR - SOLD
1995 M3 Coupe - SOLD
1988 325E - SOLD
1996 Cherokee - SOLD
alwaysbored786 is online now   Reply With Quote
Old 05-19-2010, 01:57 PM   #194
moose82
My Ride: 04 ZHP
The bolts on the carriers are 16mm. Let me know if you need help, I am in FFX
moose82 is offline   Reply With Quote
Old 06-23-2010, 06:05 PM   #195
stoble
My Ride: 2004 325i
I just did this yesterday using Powerflex bushings. The purple inner part looks a little different than the ones I have.
On mine, one side has a square opening and the other side is a hex opening. Whereas in Tim's pictures both sides are hex. So with the newer model the square side should be facing the front bumper. Can anyone confirm?
stoble is offline   Reply With Quote
Old 07-03-2010, 11:28 AM   #196
agapebmw
My Ride: E46
I noticed a lot of people used grease to put the new bushing on. Are we even supposed to do that?? I am worried that this might just wreck the purpose of putting the new bushings on.
agapebmw is offline   Reply With Quote
Old 07-03-2010, 09:15 PM   #197
andrewboi
My Ride: PY M3
I used soap and water for mine - evaporates after a while so its not "permanently lubed"
andrewboi is offline   Reply With Quote
Old 07-30-2010, 12:04 PM   #198
2001BlackOnTan
My Ride: 2001 330Ci
Probably a good idea. There are a lot of different interactions (expansion, deterioration, etc.) that can happen when petrol-based lubricants meet rubber or something like rubber, and as you said, soap and water is likely to be washed or abraded away over time with no lasting effects. And plain water can be surprisingly effective as a short-term lubricant, particulary when it comes to sliding something rubbery over metal -- I use plain water when sliding new rubber grips on the handle of my lawnmower, and it works great -- and once the water evaporates, the grips are pretty-much locked into place.
2001BlackOnTan is offline   Reply With Quote
Old 07-30-2010, 12:06 PM   #199
2001BlackOnTan
My Ride: 2001 330Ci
So people have done this job with the wheels still on, but can this job be done with the car (i.e. the front wheels) on ramps? Or does the suspension need to be decompressed (as would occur with a jack stand) for some reason? If I do the job, I'll be doing control arm bushings AND control arms at the same time.
Old 08-21-2010, 12:08 AM   #200
SuperYeti
My Ride: 2002 BMW 325ci
Talking Amazing Write Up
Hey guys, i just want to thank everyone who contributed to this thread. With the help of this i did my FCAB's successfully in 2.5 hrs today. I wanted to note, i used the jack/jackpoint method a few ppl have spoken about in the forums to push the bushing back in. Worked a charm. Cheers guys, and happy driving. i sure am now
SuperYeti is offline   Reply With Quote
