Thread Tools Search this Thread Rating: Thread Rating: 168 votes, 5.00 average. Display Modes
Old 02-26-2012, 11:54 PM   #281
DJ Mabe
My Ride: Carbon Blk M3 Coupe
I finally got it right after posting this thread. I did use a pickle fork and beat the hell out of it and the joint finally let go. I got the car on the road and now it's making an awful clunking noise in the front. I just replaced the rear shocks, shock mounts, springs, front struts, springs, CA's and CAB's. The car didn't really have any major noises before the work so i'm not sure what to check. Everything seems tight and proper but the car sounds like something is really loose. Any ideas what i should check or what it could be?
DJ Mabe is offline   Reply With Quote
Old 02-27-2012, 07:18 AM   #282
schroeder6th
My Ride: 2004 330ci
Possible
In reading your post I don't see:
"Sway Bar Links" which is also a clunk maker
schroeder6th is offline   Reply With Quote
Old 02-27-2012, 01:11 PM   #283
Stinger9
My Ride: '04 330Ci
In trouble shooting the last thing or things you did are the most likely causes of the problem. If we were there we'd just have to carefully go over all that you have just done.
And then throw in anything else that may cause clunking.
Old 04-01-2012, 09:14 PM   #284
ExitBuddy
My Ride: 2008 335i Vert
Stinger, will be doing my LCABs soon, read the last few posts, not all 280, how long did it take you to do LCABs?
ExitBuddy is offline   Reply With Quote
Old 04-01-2012, 10:19 PM   #285
Stinger9
My Ride: '04 330Ci
In my car I didn't have to take off the reinforcing plate. Took time to lift car up on jackstands and I did CA's with new FSD's in the struts all in the same project. Threw in reinforcing plates too. Did over two days.
Estimate if I just did the CAB's would have been 3-4 hrs if I'd been able to get the old CAB's off of the CA's easily. I work slo.
Old 04-02-2012, 06:01 AM   #286
ELCID86
My Ride: 2004 330i (ZHP) x2
Did mine over the weekend. Front arms and CABs. About 5 hours total. Most of that being the arms.
ELCID86 is offline   Reply With Quote
Old 05-26-2012, 06:55 PM   #287
edjerum
My Ride: BMW 323i
I did CABs using Lemforder bushings today. Biggest challenge for me was getting my car up on stands as I've never used a floor jack or jack stands before. All went well there and doing the CABs was really pretty easy. Most helpful tips for me were:
Using a really large C clamp to get the old bushing off the arm. Took about 10 minutes or so slow but steady on each side.
Turning the steering wheel to the passenger side when I installed the driver side replacement bushing really helped get the new bushing lined up with the bolt holes.
My old bolts didn't look so great (had corrosion) so I'd recommend you get new bolts for the installation. (I have a 1999 323i with 150,000 and the CABs have been replaced at least once before.) I cleaned mine up and used blue loctite but I'd feel better if I had new bolts in. The bolt size is something you can easily get at Home Depot but the original bolt comes with an integrated washer that I wasn't able to remove so I just reused the old bolts.
Very gratifying to take that test drive. The steering wheel shimmy I was having when I brake on a downhill is gone and the car is handling better - tighter.
edjerum is offline   Reply With Quote
Old 05-26-2012, 09:34 PM   #288
Stinger9
My Ride: '04 330Ci
Never get bolts from Home Depot or anyone similar for your car. There is a huge difference in the bolt grade you get there. I've had their chinese crap bolts shear the head off when trying to tighten them.
Remember this is for a critical suspension mounting that would destroy control of your car if it broke.
Old 05-29-2012, 12:36 AM   #289
edjerum
My Ride: BMW 323i
Thanks for the tip.
Sent from my SAMSUNG-SGH-I717 using Bimmer App
Old 07-30-2012, 09:50 PM   #290
328redleather
My Ride: 328ci white/red
going to be looking at this next weekend. thanks
2000 328ci alpine white on tannin red leather
328redleather is offline   Reply With Quote
Old 02-10-2013, 11:05 PM   #291
Passnu2
My Ride: Sport Wagon
pretty straight forward, did this over the weekend. Went with the powerflex hoping to not mess with them again.
Ran into one issue and have to take it out to look at. The rear passenger side brace bolt went in by hand, did this with all 4, I had it hand tight. Torqued the front two bolts and the drivers side with no issues. Passenger side not sure if the bolt took a dump or maybe the prior owner or a tech over torqued it? I also had no issues taking the bolt out.
2000 323iT - 158k
Recent Maintenance: Spark Plugs/CCV/Expansion Tank/Radiator/Thermostat/Both Intake Boots/Air Filter/Cabin Filter/Valve Cover Gasket/Control Arm Bushings/All Pulleys/Hatch Shocks/Vanos Oil Line/Fuel Pump/Fuel Pressure Regulator/Rear Rotors & Pads/Belts/Water Hoses/Front End Links/Front Sway Bar Bushings/Alternator/Power Steering Hoses/Power Steering Reservoir.
Passnu2 is offline   Reply With Quote
Old 02-11-2013, 12:05 AM   #292
Top_Bunk
My Ride: Ram-Air Nylon
Gotta do these again next week
So far my OE lasted about 40k, and ECS branded poly lasted about 55k. Going to try Meyle next.
Top_Bunk is offline   Reply With Quote
Old 02-11-2013, 11:22 AM   #293
Passnu2
^Well I gave the powerflex a shot and I was impressed with my ride this am, especially given the crappy roads in the winter months in Chicago. No rattling, jarring, noises, ect. I actually only had one bad but decided to replace both since I didn't know when either was last replaced from the prior owner. What I have read is these last much longer then anything else and offer the closest to the OEM bushings. If I recall they are only 30% stiffer? Anyway worth giving a try if your looking to try something different.
2000 323iT - 158k
Old 02-11-2013, 11:40 AM   #294
Stinger9
My Ride: '04 330Ci
Had Poly's on for 40K miles so far and haven't begun to show any wear.
Dealer saw them on my car, and said "smart thing to put these on so you won't have to replace them so frequently".
Old 04-15-2013, 04:54 PM   #295
jason330cic
My Ride: 2001 330cic
Has anyone experienced problems after using just soap with no water to slide on the FCABs? Liquid soap seems to stay greasy when it dries, so I'm worried that the bushings might slide around and not seat right.
Jason330cic
jason330cic is offline   Reply With Quote
Old 04-15-2013, 05:06 PM   #296
Stinger9
My Ride: '04 330Ci
As per TIS instructions, that's why we use a very dilute soap solution. Full strength is ill-advised.
Old 04-15-2013, 05:22 PM   #297
jason330cic
I first tried a soap & water mixture and the FCABs were impossible to push on by hand with the control arms still on the car, so I ended up using 100% soap. Many DIY video's and people in this thread used just soap and even grease. I'm wondering if they ever had problems afterwards.
Jason330cic
Old 04-15-2013, 05:29 PM   #298
schroeder6th
My Ride: 2004 330ci
nope
Old 04-15-2013, 06:23 PM   #299
Stinger9
My Ride: '04 330Ci
Good question.
BMW makes it seem like it would be dangerous to do it the wrong way.
Old 04-27-2013, 12:04 AM   #300
Nickvjr
My Ride: 2004 330Ci Conv.
Send a message via AIM to Nickvjr Send a message via Yahoo to Nickvjr
Front Control arm bushings install (Pictures/Instructions)
TIS does ask for a 20:1 mixture of water to soap.
I just replaced my FCABs with Meyle HDs and I went with the full strength soap. It worked well for my install.
If there is some concern about using full strength soap I will just take my hose to the FCABs tomorrow and dilute that soap.
-Nickvjr
2004 BMW 330Ci Convertible
Nickvjr is offline   Reply With Quote
