Rating:
Display Modes |
#41 | |
After examining design of the OEM bushings...I see why he has such low regard for these powerflex. The powerflex are harder and will not wear like the factory...but they rotate and slide within the carrier and themselves, and the control arm slides within the bushing. These probably are fine for highway driving....but did not feel safe with the driving I do. I will just have to stick with these OEMs and replace every few thousand miles until there is a better replacement. PM me if you are interested in purchasing the powerflex, already in the carriers so you don't have to worry about pressing out the old ones. |
#42 |
Owner/Admin
I don't know what you are talking about. Bimmerworld runs these on their E46 world challenge cars.
Brett knows his stuff but so does bimmerworld. Tim
#43 |
All I'm trying to convey is that these are not simply upgrades with no downsides.
The design is quite different than the factory bushing, poly vs rubber nonwithstanding. The fact that the inner sleave rotates freely within the outer sleeve is probably what makes the powerflex last so long (this retriction is likely what makes the factory bushing fail in such a short time). The fact that the outer sleeve is not in a metal carrier (like many poly bushings), and that the bushing did not require pressing onto the control arm is what really worried me. No doubt these bushings will definitely save you money in the long run. This is still a great tweak...just not perfect. YMMV Last edited by nospam; 06-03-2004 at 05:41 PM. |
#44 |
Owner/Admin
I guess I would still have to disagree. Having one of the first sets of bushings from bimmerworld installed in my car for near 6 months now my real world experiance is what I am going based on. I drive my car hard and on less than idea roads with no issues as of yet.
Tim
#45 |
Tim, what are your feelings about the design differences of the bushings? Sorry about the edit above.
#46 | |
Owner/Admin
I guess the things that they eliminated I do not feel were needed but was the way that the factory designed them to take into account the oil filled center section of the stock bushings. Tim
#47 | |
Jason posted the real world possibility regarding one of the negatives of this bushing design. I did not experience this...only feared it. I just feel better safe than sorry.
#48 |
Still searching...here is possibly another alternative, http://www.bimmerperformance.com/sus.shtml
#49 | |
Owner/Admin
Tim
#50 |
www.piratecove.org
Any other ideas on how to get the stock bushings off the control arm, other than a dremel? I mean they are on there pretty good...that appears the only/best way to go about it.
Yeah I havent updated my sig yet with my 335, kill me.
#51 | |
Lemony Fresh
A straight threaded rod puller (aka "push puller") and bearing separator work well: http://www.teamdfl.com/events/dflfest_2/
Mod the driver first. Participate in your local BMWCCA driving school. Have you joined BMWCCA yet?
My Track Schedule The solution to the lack of headroom in the X6 ![]() |
#52 | |
#53 | |
Owner/Admin
Tim
#54 | |
Another downside of the Powerflex bushes is that the grease will be washed or dry out and they may squeek or begin to wear |
#55 |
ok, im about to do this. i am still a bit apprehensive about getting the sleeve out of the carriers, as i do not have an angle grinder. wish me luck!
btw, can i rent a jack, like the one tim has in his pic, from autozone? i have no tools so i need to rent all of them, will autozone have what i need? |
#56 |
I actually had this done today by a shop for 128 dollars which I thought wasn't unreasonable. If you can explain to them exactly what you want them to do, I am sure that you can get a shop to do them also. All I did was take the urethane bushings there and explain, they proceeded to do the rest. I was going to do the DIY but also had regrets about getting the sleeve out so I saved the headache and stress. No more steering wheel vibration and no more clunking. Thanks for the DIY Tim, wouldn't have been able to get them to do it without your post
By the way Autozone around me does not rent out jacks. |
#57 | |
#58 | |
#59 | |
Also, www.bmwbushings.com's bushings should be available in about two weeks pending testing results. |
#60 | |
Trieberg?? Just did this and he said that it was a fairly easy job! Make sure to follow Tim330i's procedure for torque specifications on the cross bars and carrier to body. |
