Old 02-03-2004, 06:59 PM   #1
BMR2NV
My Ride: E46 318I 2002
Transmission Malfunction With Boost
Hi guys recently i have installed a supercharger sysytem to my e46 2001 bmw! I havent don the software yet still getting it done nxt week but the other day just cruising around the auto transmission went into transmission malfunction mode? After turning the car off it went out an rove normally again! How could this be? Im gussing its cause the software isnt done yet? Any one?
BMR2NV is offline   Reply With Quote
Old 02-03-2004, 09:20 PM   #2
Will ZCPM3
Will ZCPM3's Avatar
My Ride: ///M3
should you be driving it without the software?
Will ZCPM3 is offline   Reply With Quote
Old 02-03-2004, 09:29 PM   #3
BMR2NV
I was on my way to see a workshop bout the computer when it happened! Other than that i Dont really drive it around!
Old 02-03-2004, 09:51 PM   #4
eyemd
My Ride: 2005 IR M3 Cab
Hey BMR2NV, let us know what happens.
Also, could you tell us which SC you got? And how about a little review if you don't mind. I'm sure many would like to know.
2005 IR M3 Cab (gone but not forgotten)
Eibach Pro-kit, Rogue wheel spacers, painted reflectors
eyemd is offline   Reply With Quote
Old 02-04-2004, 08:32 PM   #5
BMR2NV
Well i have a 2001 model e46 318i i live in australia it comes with a 2.0L engine down here! Its a full custom setup running a roots style blower at 8psi larger injectors ems computer front mount intercooler! Will be getting dynoed and tuned this thursday! So when that happens ill post the results!
Old 02-04-2004, 10:15 PM   #6
Hobbes
Nonsense Generator
My Ride: 2006 X5 4.8is
Send a message via AIM to Hobbes
Did you hit the rev limiter too hard/too long?
I did this once while trying to keep pace with xS3x at the bimmerfest west run.
Car went into tranny fault mode/limp. Pulled over, shut down, waited a sec. Started up. It's been fine ever since.
Hobbes is offline   Reply With Quote
Old 02-05-2004, 02:47 AM   #7
xS3x
mi casa @ technik
My Ride: 2002 330Ci
Send a message via MSN to xS3x
haha..i forgot about that!
xS3x is offline   Reply With Quote
Old 02-06-2004, 05:46 PM   #8
Craig
The G.O.A.T. is Baccckkkkk!
Craig's Avatar
My Ride: 09' AW E92 335i
Anyone with a valid technical answer to this question???
Craig is offline   Reply With Quote
Old 02-08-2004, 04:05 PM   #9
Mr Paddle.Shift
Mr Paddle.Shift's Avatar
My Ride: B3 epsilon
I highly doubt that the lack of a ECU remapping is causing the transmission to go into a limp mode. Next thing, I will do is bring your car into a dealer and have them use a GT-1 to diagnose the system again. Never assume a "reboot" on a car and everything will be ok.
Also, try to find out the version of the transmission control unit (maybe there might be an update?) and also the model of your transmission.
Alpina has been using ZF 5-speed 5HP19 in their latest B3 S 3.4L, which outputs 300bhp and 362Nm. I will use that as a upper bound for our steptronic systems as well.
Technik Engineering ASA Stage 1.
Supercharged E46 M54B25.
2011 NASA TTC So Cal Champion!
Track blog.
Technik Engineering oil cap o-ring maintenance kit available.
Mr Paddle.Shift is offline   Reply With Quote
