Old 02-20-2004, 11:58 PM   #1
Jake
Steelblue Zim Zimma
Jake's Avatar
My Ride: "Shark Infested 323"
Send a message via AIM to Jake
For those who ever thought about getting DDE"s (kinda long)
This post right HERE is what got me hooked into the DDE's and I am so glad I waited over the years to see this product develop into what it has become.
I would like to thank JLEVI, for answering all my questions, and getting the DDE's to me way over here (in the Middle East) in just under a week (SUPERB SVC) and ensuring me that the install would be easy. "JERSEY" thank you also as your pics help me a great deal in the install, I was skeptical at first but, once I started rollin it was ALL good...Once the install was over I was ALL SMILES... ..(one halo is bad but Jlevi is on the ball again....express shipment should be sent today and arrive within days...) anyway enough talking here are some pics...(my way to give back to help out the person on the next install...JLEVI... )
Open the box to make sure all HALOS were intact (YES!!! they made the trip)
Second:
Let the install Begin...
Here is just a better shot of the clean looking in the wire rail.
At this point my Camera was acting up, but basically you then just run the RED/WHITE wire into the ECU and connect the blue clip into the RED/WHITE and DOTTED Wire (This is the accerssory wire for delayed shutting off of the lights when you exit the vehicle)....Camera works again...
Continue to run the Black cable down the drivers side of the car, following the SAME path as the OEM wires....so at this point you have a RED and Brown wire running down both sides of the car all the way to the lights.....
I then went ahead and removed my head light covers...
Before this pic I reinstalled the Covers back on the lights.
Just another shot of the light box...
Now from this point everything is connected I just pulled off the dbl sided tape stuck the light boxes under neat the radiator rail, used a few tie wraps. Prayed crossed my fingers and started up the car.
As you can see one bulb is out, not sure why but I swaped the white wire with the bulb that was on and it still did not come on so I know the Halo is bad...(no worries JLEVI is on the scene .) I will have a new halo this week.
so any comments, let me know, just my way to give back to all of you, who help so many of us all on this board...Can't believe I been a member for 4 years...wow......whatcha think?
Jake is offline   Reply With Quote
Old 02-21-2004, 12:17 AM   #2
Jlevi SW
1.888.JLEVISW
Jlevi SW's Avatar
My Ride: Vorsteiner 335i
Send a message via AIM to Jlevi SW
Glad you like them Jake
Can't wait to get that other ring in your car
Jlevi SW is offline   Reply With Quote
Old 02-21-2004, 01:19 AM   #3
doncmleon
My Ride: layin in the cut!
Send a message via AIM to doncmleon Send a message via Yahoo to doncmleon
Tight Tight!
i am thinking about ordering my DDE's in a few weeks, too. I havent seen any here in the Houston area, so i wanna be one of the first. Thanks for the motivation, man....keep rollin along!
Make GREAT decisions. All the time.
doncmleon is offline   Reply With Quote
Old 02-21-2004, 01:46 AM   #4
DiscoStu
Sienna Red Coupe
DiscoStu's Avatar
My Ride: Project 330xi
Question. I've got DDE Gen V's now and i'm upgrading to lighting enhanced in the spring. Can I use the same wire harnesses and relay?
-Gary
DiscoStu is offline   Reply With Quote
Old 02-21-2004, 01:54 AM   #5
Jlevi SW
1.888.JLEVISW
Jlevi SW's Avatar
Yes, but it won't have the clips on the ends of all the wires... so you'd have to solder on the ballast wires. Then change the fuse to a 5 amp, not a 40 amp.
Then you're all set
JL
Old 02-21-2004, 02:49 AM   #6
Jlevi SW
1.888.JLEVISW
Jlevi SW's Avatar
I've actually found that if you're gentle enough, you can put BOTH of the highbeam clips on slot 2. The thing is, I recommend wedging a screwdriver in and opening the clip a little bit, so that you can do it without too much force. You might want to change the image accordingly
AWESOME writeup though.
Old 02-21-2004, 03:10 AM   #7
Jake
Steelblue Zim Zimma
Jake's Avatar
I may do this when I get the other bulb, and see I just hate to break a clip and then have to wait on USPS again....I will see., again thanks for your help
Old 02-21-2004, 03:40 AM   #8
Double Vanos
Loves cookies
Double Vanos's Avatar
My Ride: 2013 VW GTi
Send a message via AIM to Double Vanos
Im thinking about getting some of these but i was wondering after you install these can you still wash the engine bay and not worry about the wires or light box getting wet? Also what other pros and cons are there to have these?
2011 135i 6 speed (Gone and missed)
Double Vanos is offline   Reply With Quote
Old 02-21-2004, 04:25 AM   #9
blue_bimma
E46
My Ride: BMW
I've been out of the E46 loop for a while and just coming back. I got some crappy Gen V DDE's that suck. All my fiber optics are melted and it looks like yellow crap on my headlights.
So, what light source does it use? And are these THE BEST out there right now for DDEs??
https://lh5.googleusercontent.com/-zjEo_YuC2rI/TiISYslkcsI/AAAAAAAAD6Y/icoRA9K8EZA/bmw-12.jpg
blue_bimma is offline   Reply With Quote
Old 02-21-2004, 05:43 AM   #10
ab325
My Ride: bipedal
Ive got the same problem with melting fiber optics and yellow on my headlights. my lightboxes tend to go out on me pretty regularly as well. i shouldve just waited for the dde's, but now theyre too expensive
ab325 is offline   Reply With Quote
Old 02-21-2004, 08:15 AM   #11
Jake
Steelblue Zim Zimma
Jake's Avatar
Yes you still wash your engine, and cover up the same spots, you would do normally,(cover mine with Aluminum foil works well since the water just runs off...)(you cover up the ECU,DSC Area, and your two front Head lights (the back part where the wire are at) and you are good to go.
As far as pros and cons....PROS: you will have the best DDE's on the market to date and by far the easiest install.....CONS:...Uhhhhh...Uhhhhhh... when i think of one I'll let ya know....(don't hold your breath.. )
Old 02-21-2004, 08:19 AM   #12
Jake
Steelblue Zim Zimma
Jake's Avatar
Look at the above pics the light source its that little White box. the best out right now??? No Question DDE's Enhanced..
Old 02-21-2004, 12:53 PM   #13
dronell19
JDM - Style
My Ride: is sold
Send a message via MSN to dronell19
Right now, I am very worried about breaking a ring while installing. The replacement ring may never reach me (postal service here sucks big time).
Gone but never forgotten; E46Fanatics first Arqray+Strassentech combo
dronell19 is offline   Reply With Quote
Old 02-21-2004, 01:03 PM   #14
nikemykee
First 19" ZHP
My Ride: 03 3 Series
Send a message via AIM to nikemykee
congrats nice write up
UNDER CONSTRUCTION
Want to buy Arqray Add-on
nikemykee is offline   Reply With Quote
Old 02-21-2004, 01:28 PM   #15
umnitza
8774866489
umnitza's Avatar
My Ride: E39M5, Sequoia
The clips take a lot of abuse, don't worry about it.
For those of you having issues with your Gen V - contact your retailer - if that's us, contact us, if that's someone else - get on them until they fix it or help you get "into another product"
Old 02-21-2004, 01:54 PM   #16
///ACS330Ci
Artist formerly k/a Steve
My Ride: ACS/M-Technik 330Ci
Send a message via ICQ to ///ACS330Ci Send a message via AIM to ///ACS330Ci
Jake you're a !
Car looks awesome
  • Checkout Project HyperWorksMCS HERE
  • View My Other Automotive Project HERE
///ACS330Ci is offline   Reply With Quote
Old 02-21-2004, 02:08 PM   #17
///ACS330Ci
Special upgrade price for a never installed Gen V kit?
Old 02-21-2004, 02:28 PM   #18
Jlevi SW
1.888.JLEVISW
Jlevi SW's Avatar
Bluebimma: No doubt. The source of light is the ring itself if that helps at all. They're about 2-3x brighter than GenV, with half the heat, and NO damage to the car. Oh yea... NO lightboxes
For those of you who need more information, contact myself or umnitza... or check out one of our sites. I have a nice little writeup and comparison picture on my site, www.jlevistreetwerks.com
Like Matt said, I'll be happy to help your switch up to the latest and greatest in DDE technology, and I'm sure he will too.
Old 02-21-2004, 02:41 PM   #19
JoeyGoodfella
My Ride: 330i 03'
Send a message via AIM to JoeyGoodfella
I'm doing the same. How long ago did you get the gen-v's? out of curiousity and how bright are they now?
JoeyGoodfella is offline   Reply With Quote
Old 02-21-2004, 03:46 PM   #20
biggie27
My Ride: turbocharged camel
Send a message via Yahoo to biggie27
hey jake this is kinda off topic but I was wondering how did you get your car sharked since I was looking at the shark upgrade and it said it was only for us spec cars, Im in kuwait by the way and I have a euro spec M3
on topic : those DDE's look tight, I should have mine on tuesday ( shouldve had them a month earlier but Kuwaiti customs suck a$$ )
biggie27 is offline   Reply With Quote
