Thread Tools Search this Thread Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Old 06-30-2002, 02:06 AM   #1
loki
My Ride: has wheels
DIY: E46 Shock Sensor Install
Thanks to Dave (Osbee on the board) with his post about adding the sensor... I got inspired, purchased a similar product to the Audiovox sensor he used, and installed it this afternoon.
This is a great, easy, and affordable addition to the OEM alarm and adds the level of security you'd expect but never got with the factory hardware.
happy modding!
-loki
loki is offline   Reply With Quote
Old 06-30-2002, 02:37 AM   #2
KevinJ_2k1_325ci
My Ride: 2001 325ci
What does this do? If the car moves the alarm goes off?
I assume that's what this is right?
KevinJ_2k1_325ci is offline   Reply With Quote
Old 06-30-2002, 12:21 PM   #3
loki
My Ride: has wheels
Re: What does this do? If the car moves the alarm goes off?
think "Hit and Run", and you'll get the idea of why this is worthwhile.
Old 06-30-2002, 12:29 PM   #4
StreetTrixE4six
E46Fanatic
My Ride: 08' 328i E92
Did you have to run the power all the way to the battery or was there a wire you spliced into?
08' BMW 328i coupe
07' Audi A4 2.0T Quattro S-Line
04' 325Ci
StreetTrixE4six is offline   Reply With Quote
Old 06-30-2002, 02:32 PM   #5
jun
My Ride: 2001 330ci
Loki,
Where did you get the sensor?
jun is offline   Reply With Quote
Old 07-01-2002, 12:11 AM   #6
Dev
PSHOPWERKS
My Ride: Yellow Porsche GT2
Ummm...someone go do a Hit and Run test on Loki's car to see if the thing works. J/K
From the pictures, doesn't seem too difficult. Now where can we get a hold of this sensor? Radio Shack?
PSHOPWERKS
Mods: 1 Inch Nail in Tire | Purple painted calipers (you know you like Purple calipers)
Current Hate Level: 10 | Previous Hate Level: 9
The hatin' level on the E46Fanatics.com board.
Dev is offline   Reply With Quote
Old 07-01-2002, 03:10 PM   #7
mickey513
My Ride: e46
Any audio/alarm shop. It should cost around $20, more or less depending on where you. I recommend you go with the DEI shock sensor instead of the audiovox one. The audiovox is made by radio shack
mickey513 is offline   Reply With Quote
Old 07-01-2002, 03:21 PM   #8
vinnymac
St. Louis BMW Fanatic
My Ride: 2011 335is
Send a message via AIM to vinnymac
Nice!
Damn, now I have to spend more money and add another mod to my car. where and how much?
vinnymac is offline   Reply With Quote
Old 07-01-2002, 03:23 PM   #9
vinnymac
My Ride: 2011 335is
Wait a minute...
someone explain to me how this interfaces with the OEM alarm...what is triggered when the car is bumped? I'm confused here...
Old 07-01-2002, 03:28 PM   #10
JACOB NJ
My Ride: 00 540 sport
Send a message via AIM to JACOB NJ
vinny heres the break down
the shock sensor gets power from the cars electrical system.. then triggers the hood pin switch when the car is bumper or tampered with .. so the alarm is in turn set of by the hood pin switch.... loki write up is great.. not sure if he used the diodes on the install ..but the paperwork for the 504 from what i remember suggest diode use so the shock sensor does not back feed from the pin switch the the sensor but vise versa.. but i dont think its necessary but dfiently a plus.. i also had all power and wires inside the car.. nothing was seen under the hood but all was hidden behind the glove box.. loki defiantly has the easier install there but i guess my mentality of clean and simple is just because of the work i do.. and how i do this daily.. i try to keep to out of sight out of mind either way will work fine
JACOB NJ is offline   Reply With Quote
Old 07-01-2002, 03:38 PM   #11
vinnymac
My Ride: 2011 335is
Re: vinny heres the break down
OHHHHH...that's makes sense now...thanks for the explanation!
Old 07-01-2002, 03:39 PM   #12
JACOB NJ
Re: Re: vinny heres the break down
anytime if you ever need electrical guidance just holla
Old 07-01-2002, 03:42 PM   #13
ptsao
My Ride: 2003 M3
thanks,
Just a thought.
my previous shock sensor is mounted on a clip like sheet metal so is not rigid against the body of the car.
I wonder if that will just make it more sensetive, or the new shock sensor is better.
I'm going to get his done this week.
ptsao is offline   Reply With Quote
Old 07-01-2002, 04:47 PM   #14
jestr
is bester
My Ride: '02 Steel Grey 325i
Nice write-up Loki
I'll have to do that soon too... BTW did you choose the more sensitive setting or the less sensitive setting and how sensitive is it?
jestr is offline   Reply With Quote
Old 07-01-2002, 06:14 PM   #15
JetBlackE46
Modded
My Ride: E36/E46 M3 E46 323
i have a 2000 323ci and i don't have that hood pin switch. did it come with the factory alarm?
JetBlackE46 is offline   Reply With Quote
Old 07-03-2002, 01:16 PM   #16
Chailo27
My Ride: A Car
Comes with the factory alarm.
Chailo27 is offline   Reply With Quote
Old 07-03-2002, 03:21 PM   #17
loki
My Ride: has wheels
I choose the green (more sensitive) wire. With the stock sensitivity setting it seems fine. Will go off with sudden impacts (like a kick to any tire) but not general rocking.
If you desire it even more sensitive, you can adjust by a screw on the DEI sensor or mount it to a part more susceptible to shock.
BTW, the hood pin switch should aleady be there, the factory alarm kit only includes the horn, motion sensor and tilt sensor.
good luck!
-loki
Old 07-03-2002, 09:28 PM   #18
JetBlackE46
Modded
how can you hook up the dual stage shock sensor?
i want it to chirp on light shocks and trigger the alarm on a hard shock...anyone know?
also, is the purple wire a positive or negative trigger?
Old 07-04-2002, 12:48 AM   #19
sycE46
My Ride: 323ci
anyone know how long the alarm goes off before it turns off?
sycE46 is offline   Reply With Quote
Old 07-04-2002, 01:22 AM   #20
Full Time Hit Man
Banned
My Ride: E46
Send a message via AIM to Full Time Hit Man
Thanks, I'm gonna get the parts and do that this weekend.
Full Time Hit Man is offline   Reply With Quote
