Thread Tools Search this Thread Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Old 10-16-2004, 07:30 PM   #61
jstar41
My Ride: TopazE46|MontegoE92
ok.. spliced wires into the motion sensor.. i used tab connectors.. worked great.. i adjusted the sensitivity to the max and no need for the pre warn .. alarm goes on as soon as someone tabs my windows.. =) there shouldn't be nobody touching my car.. =)
JSTAR41
jstar41 is offline   Reply With Quote
Old 10-17-2004, 05:20 AM   #62
SQP
My Ride: E46 Edition Sport
What are tab connectors?
SQP is offline   Reply With Quote
Old 10-17-2004, 10:39 PM   #63
jstar41
these are some connectors that allow you to splice into the wire without cutting.. you can get them in Radio Shack for about 2 bucks for 16 connectors..
JSTAR41
Old 10-30-2004, 08:45 AM   #64
SQP
If bought the 504D yesterday and would install it today but there is no place under the interior sensor...my car is a E46 2003 sedan with sunroof...and the shock sensor is to big for install in roof. Can anybody help me?
Sorry for my bad englisch...
Old 11-07-2004, 01:22 AM   #65
jstar41
i kinda had the same problem. but if you leave it right by where the motion sensor sits and where the cover for it snaps on, it'll be hardly noticeable..
JSTAR41
Old 11-15-2004, 08:14 PM   #66
SHICKS
My Ride: 325i
Send a message via AIM to SHICKS Send a message via Yahoo to SHICKS
I am about to order the 504d DEI shock sensor, is this the one I should get?
SHICKS is offline   Reply With Quote
Old 01-20-2006, 10:01 PM   #67
Got_S54?
My Ride: 2002 M3
I can't seem to find that pdf file anywhere. I guess they took it down from roadfly. does anyone still have it or remember the wiring used? Do I still need to use diodes?
05 TT 225 Quattro - APR Stage 1|FK coilovers|Megan Adj.Cont.Arms|APR catback|15F/20R spacers|OEM ALMS 18's - daily
02 M3 AW/IR - sold but not forgotten
Got_S54? is offline   Reply With Quote
Old 01-21-2006, 07:02 AM   #68
SHICKS
My Ride: 325i
I may be able to locate the documet, no diodes are needed.
I have a used shock sensor for sale if anyone wants one.
Steve
Old 01-21-2006, 08:21 AM   #69
rovert
My Ride: is an Individual
Send a message via ICQ to rovert Send a message via AIM to rovert Send a message via MSN to rovert Send a message via Yahoo to rovert
Does that mean there's a dual stage shock sensor? So you can set it up to warn you on the first tap, but on the second the alarm will go off?
What's the warning chirp sound like??
--Trevor--
Vancouver, BC
rovert is offline   Reply With Quote
Old 01-21-2006, 09:51 AM   #70
SHICKS
My Ride: 325i
It's wired into the OEM alarm, the sensor is dual stage, but the OEM alarm just goes off like normal if either the first or second stage is tripped.
Steve
Old 01-23-2006, 01:29 PM   #71
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Is there a way to test the shock sensor to see if its functioning other than beating on the car? I'm not sure if mine is working.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 01-23-2006, 01:53 PM   #72
SHICKS
My Ride: 325i
you should be able to see a red light go on in the sensor itself, how do you have it hooked up?
Old 01-23-2006, 02:00 PM   #73
PYRITE
My Ride: 1965 Ford Mustang
Loki!
PYRITE IS SOLD!!
Welcome "KRYPTONITE"...
PYRITE is offline   Reply With Quote
Old 01-23-2006, 03:18 PM   #74
bigjae1976
bigjae1976's Avatar
I took it out and I don't remember seeing a red light.
Old 01-24-2006, 05:49 PM   #75
kapkani83
My Ride: 2002 325ci
Send a message via AIM to kapkani83
OK guys I am really confused now, I just got my factory alarm activated today. I had already bought a shock sensor so when I got how I said wtf Ill install it today too, I wanted to follow the DIY for behind the glove box, so I did, but I wanted to use the conveniece of the tilt sensor blue/black wire instead of the hood so I could turn the sensor off if i didnt want it on, anyways I hook everything up and gave it a try, NOTHING, the red diode blinks so I know the sensor works; so I decide to make sure everything else is working, I turned the alarm on and stuck my hand in the window, clapped, and then got in the car and turned the alarm on and NOTHING!!!, so while Im at it why not try the tilt sensor, I turn the alarm on and jack up one side of my car, and what do you know NOTHING!!!, I called the Dealership and told them they didnt turn on the motion sensor or the tilt sensor, he checked into it and said that it is not an option to pick what turns on, he said you can turn the system either on or off and thats it, According to my research you can turn things on individually, so wtf, does anyone have any input???
kapkani83 is offline   Reply With Quote
Old 10-07-2006, 08:03 AM   #76
ChadE7320
ChadE7320's Avatar
My Ride: E90 / ATR-72
Send a message via AIM to ChadE7320
bump did any body figure out how to do the dual stage?
ChadE7320 is offline   Reply With Quote
Old 10-07-2006, 08:46 AM   #77
SHICKS
My Ride: 325i
No, but I still have a shock sensor for sale, $15 shipped.
Steve
Old 10-10-2006, 05:10 PM   #78
paraklas
My Ride: ESS TS2 320ci
ebay seems to have a variety of sensors, which one is reccomended?
http://search.ebay.co.uk/shock-senso...fkrZ1QQfromZR8
Old 01-03-2007, 10:31 PM   #79
vids_blk323Ci
DFW
My Ride: JB 323Ci SP PP
Send a message via AIM to vids_blk323Ci
hmmmm I wonder if this would be better:
http://www.crutchfield.com/S-NSqBb99...=514AU85TA#Tab
Dinan Stage I S/W | ACS RSB | ///M FSB |UUC TMEs & Pulleys |Ate Slotted Discs | ScanGuageII | RockyMounts MTB Carrrier | OEM Rear Clears | LED Euro City Lights & Rear Fogs | Two-Tone Suede DIY | ACS Pedals | Bimmian Gauge Rings & M3 Face | Smoked Frnt Corners w/ Luxeon LEDs | EAS CF Roundels | JLevi Ti CF trim | Blk Suede shift/ e-brake boots | ECS Smoked Frnt Bumper Reflectors | DICE Duo
vids_blk323Ci is offline   Reply With Quote
Old 01-05-2007, 04:00 PM   #80
Dev
PSHOPWERKS
My Ride: Yellow Porsche GT2
I have mine and still haven't installed it yet after a year. LOL!
PSHOPWERKS
Mods: 1 Inch Nail in Tire | Purple painted calipers (you know you like Purple calipers)
Current Hate Level: 10 | Previous Hate Level: 9
The hatin' level on the E46Fanatics.com board.
Dev is offline   Reply With Quote
