Sponsored by The Tire Rack
Old 02-27-2004, 10:49 PM   #1
Dropkick323i
My Ride: 323i
Tire sizes for 17x8.5
Hello again
Just wondering what tire size to use for a 17x8.5 rim. 225/45 R17 will keep the diameter closer to stock, but 235/40 R17 will be wider but have a taller gap between the fender...
Is it okay/safe to ride 225s on a 8.5 wheel?
Any pics of a 17x8.5 wheel on 225s would be great.
Thanks to all who respond.
Dropkick323i is offline   Reply With Quote
Old 02-28-2004, 08:24 AM   #2
Rudy@Tirerack
Moderator
Rudy@Tirerack's Avatar
My Ride: 1-800-428-8355 X4664
The recommended rim width range on 225/45R17 is 7-8.5", even up to 9" on some tires in that sizing, so 8.5 is safe and works fine.
235/40R17 is wider and also fits of course, but as you stated will show a bit more fenderwell gap.
http://www.tirerack.com/a.jsp?a=AR8&...ires/index.jsp
Refer to 'Rudy/E46Fanatics' as your previous contact when you order online. Credit E46Fanatics.com by clicking here.
Rudy@Tirerack is offline   Reply With Quote
Old 02-28-2004, 08:24 AM   #3
GeorgeXI
My Ride: '03 330XI Steel Grey
Definetely go with the 235' on the 8.5" rim. The tire diameter is only 25.1", well within +/- tolerances. Fills out the rim a lot better, 225 kind of strectched on 8.5" rim
GeorgeXI is offline   Reply With Quote
Old 02-28-2004, 03:16 PM   #4
SkipII
My Ride: 2001 330 Ci
Some differences of opinion
Tire Rack told me that 225s are well suited for 8.5 (I thought it was a stretch). As well, I was told that a 235 did not fit the front wheel well of the E46. that's what drove me reluctantly to buy 225s for the front instead of 235.
Was I wrong, TR?
SkipII is offline   Reply With Quote
Old 02-28-2004, 05:56 PM   #5
Dropkick323i
My Ride: 323i
Was I wrong, TR?
How do you like your 225s? Are they really that stretched? The tire width is still wider than the rim. I was told 245/40 R17 would not fit under our wells. I guess if 235s arn't gonna fit, then neither will 245s!
I'm probably going to get the 225s, just because there seems to be more all season options in that size. I'm, so confused
Once again, pics if you have them!
Thank's Gary.
Old 02-29-2004, 06:34 PM   #6
GeorgeXI
Thumbs Up
Thank's Gary.
got 235/40/18's all around on bbs rgr's for a year now, they fit fine!
Old 03-01-2004, 06:24 AM   #7
rvnvet
My Ride: 2000 323i Sport
Hello again
A 225mm tire will fit on an 8.5" wheel, BUT the wheel will stick out past the tire and that just doesn't look good.. You can put a 235mm all around with no problems....
THE AIR CAV... 5/7... RVN...1967
rvnvet is offline   Reply With Quote
