Thread Tools Search this Thread Rating: Thread Rating: 71 votes, 5.00 average. Display Modes
Old 02-28-2004, 12:28 AM   #1
darkmanlfe
My Ride: rocket propelled 323
Send a message via AIM to darkmanlfe
Oil and Engine Service Light Reset for 99-00 e46
This applies to earlier e46 models. eg. 99-00 with OBCI.
1. Locate the 20-PIN DLC Connector. It is located under the hood, passenger side empty compartment.
It looks like this.
2. Turn the key to position 2. key position before the engine start.
3. For OIL RESET, just ground PIN 7 and PIN 19 for 3 seconds.
4. For ENGINE SERVICE light, ground PIN 7 and PIN 19 for 9 seconds.
Albert Einstein once said - Two things are infinite: the universe and human stupidity; and I'm not sure about the universe.
darkmanlfe is offline   Reply With Quote
Old 02-28-2004, 03:06 AM   #2
MoneyFor
My Ride: 320d - 118d - Z4
Question
Do you need to connect both pin 7 ands 19 at the same time to a ground ?
MoneyFor is offline   Reply With Quote
Old 02-28-2004, 08:23 AM   #3
darkmanlfe
Just take a paper clip and connect PIN 7 (service) and PIN 19 (ground)
Old 02-28-2004, 01:37 PM   #4
MoneyFor
no luck
Thx, i have tried this but with no result. A friend of mine did reset the km's (miles) with a reset tool a wile ago, than it came back to 25.000 km. Now at this time it is showing 21.300 km on the service display and i just give the service ( oil and filters ) because i didnt have time for it earlyer and i want to reset it again so it's will show back the 25.000km interval display. I have not acses for the reset tool at this time. My 328Ci is build '99, it was the first of this model E46 Coupe in Belgium.
Old 02-28-2004, 04:16 PM   #5
BimmerPhan
My Ride: -
I tried this on my Oct. 99 build '00 328i and it didnt work either...
BimmerPhan is offline   Reply With Quote
Old 02-28-2004, 08:01 PM   #6
darkmanlfe
let me repeat this. turn the car ON position. No engine start...
short pin 7 and pin 19 with a paper clip for 3 secs for oil reset.
Make sure you are shorting pin 7 and pin 19 as described on the picture.
Again, this work on my car OBCI and 20-pin DLC Connector.
Old 02-28-2004, 08:03 PM   #7
darkmanlfe
confirmed by another fanatic
Alright. Neverclear just PMed me.
"got it to work
thanks"
Old 03-01-2004, 02:11 AM   #8
nEVERCLEAR
My Ride: 323
I had tried this with a jumper wire several times with no results.
I did this earlier with a paper clip and counted to 9 slowly ( one thousand one, one thousand two...)and it reset. This is an 09/99 build 00' 323. Don't know if it was the timing or what but it does work.
nEVERCLEAR is offline   Reply With Quote
Old 03-01-2004, 05:33 AM   #9
///SC3
My Ride: ///M3 Slick Top/6spd
Thanks!
You are the man! I was so close to ordering the reset modules. Now if you could just figure out the air bag reset then I would have to worship you . . .lol. Thanks again!
323i for sale!
///SC3 is offline   Reply With Quote
Old 03-01-2004, 05:53 PM   #10
kAst
My Ride: 99 bmw 323i
Send a message via Yahoo to kAst
thanks it worked for me i had to take some paint off so it was on the ground now it says 15525 mile inspection when i turn it on but bf it said -2525 oil service light
kAst is offline   Reply With Quote
Old 03-02-2004, 11:48 PM   #11
Dev
PSHOPWERKS
My Ride: Yellow Porsche GT2
I need to do this too.
PSHOPWERKS
Mods: 1 Inch Nail in Tire | Purple painted calipers (you know you like Purple calipers)
Current Hate Level: 10 | Previous Hate Level: 9
The hatin' level on the E46Fanatics.com board.
Dev is offline   Reply With Quote
Old 03-03-2004, 09:34 AM   #12
nEVERCLEAR
My Ride: 323
You took paint off what?
When I did this, I just connected the paper clip between the two pins. One of them (19?) is the reset lead and the other (7?) is the ground lead. I guess if you are having problems getting it to work you could just run (19?) to a ground in the battery compartment. You could use a voltmeter to be sure which one os a ground also.
That sounds like what you did.
Old 03-03-2004, 12:29 PM   #13
thais0n
SBBMotorwerks
My Ride: Your mom
Send a message via AIM to thais0n
Worked for me...thanks for the info!! This is something I have needed to do for a while
thais0n is offline   Reply With Quote
Old 03-03-2004, 01:17 PM   #14
havnfun328
My Ride: '99 328i, '03 M5
You only need to ground pin 7. I think pin 19 *is* connected to ground. I went straight from pin 7 to chassis ground and it worked great.
havnfun328 is offline   Reply With Quote
Old 03-23-2004, 11:04 PM   #15
darkmanlfe
yes that is correct. pin 19 is ground.
so you can either short pin 7 and pin 19 with a paper clip or ground pin 7.
Old 03-25-2004, 07:41 AM   #16
ps82k
My Ride: 2001 325i w s/p
2001 bmw
what about 2001 and up models?
do i have to spend 200 bux on the reset tool? or it there a way to reset?
ps82k is offline   Reply With Quote
Old 03-25-2004, 07:44 AM   #17
thais0n
SBBMotorwerks
My Ride: Your mom
Check the forums for 2001 and up models. Its even easier for you guys.....I think you hold down the trip odomoter reset button and then turn the key to on, and then push a few more buttons and its reset. I know i have seen it in the forums.
Old 03-25-2004, 08:16 AM   #18
ps82k
OH MY GOD!!!!IT WORKS!!!!!
Thank you so much!!!!!
Old 03-25-2004, 08:46 AM   #19
darkmanlfe
great news.. saving some cash on DIY is def. good.
Old 04-17-2004, 05:03 PM   #20
pyo
My Ride: Z4 3.0i '04
Send a message via AIM to pyo Send a message via MSN to pyo
I get the same thing, but I did it through the trip odometer way. How do I get the oil service to show up before start up?
2000 328i [Sold]
2004 Z4 3.0i 6spd
pyo is offline   Reply With Quote
