Thread Tools Search this Thread Rating: Thread Rating: 71 votes, 5.00 average. Display Modes
Old 06-20-2005, 09:45 PM   #61
SSYHARATH
My Ride: 00 323CI
It reset my oil service but now car won't start. According to the gauge, the car is in S. Please help
SSYHARATH is offline   Reply With Quote
Old 06-21-2005, 02:23 PM   #62
dillard
My Ride: 2004 M3 Cabrio
Very strange. Try disconnecting the battery.
Proud owner of '04 M3 Convertible:
dillard is offline   Reply With Quote
Old 06-21-2005, 11:23 PM   #63
Cobra
My Ride: '00 328i & '06 R6S
thanks, this is really helpful
Cobra is offline   Reply With Quote
Old 06-22-2005, 01:54 AM   #64
SSYHARATH
My Ride: 00 323CI
I disconnected the battery and waited till the next morning and it still won't start. Radio, power window, lights, AC all works. The car is in Park but the gauge reads S, even when I put in R or N. I got it towed to a local BMW repair shop this afternoon.
Old 07-19-2005, 07:30 PM   #65
Cobra
Originally Posted by darkmanlfe
yes that is correct. pin 19 is ground.
so you can either short pin 7 and pin 19 with a paper clip or ground pin 7.
what do you mean by ground pin 7 only? what does grounding mean?
Old 07-27-2005, 02:46 AM   #66
monchhichi
monchhichi's Avatar
My Ride: 2003 330i
Send a message via ICQ to monchhichi Send a message via MSN to monchhichi
Smile How to reset Servise engine light on 2003 330i
I have a 2003 330i..I can't locate the data link connector inside the hook....and I want to know how to reset the servise engine soon light. Thanks!!!!!!!!!!!!!!!!!!!!!!!!!!!!
monchhichi is offline   Reply With Quote
Old 07-27-2005, 03:02 AM   #67
Cobra
dude, the data link connector is only for 99-00 models. for your '03, theres a completely different method to reset the light;
B. After Mid-2000: You should not have the 20-pin DLC connector. You only need to hold the left odometer reset button while turning the key to position 1 (Accessory). Keep holding the button for 5 or so seconds until any of the following shows in the display: OIL SERVICE or INSPECTION with RESET or RE. Release the button and press it again for another 5 or so seconds until RESET or RE flash. While the display flashes, press the button one more time briefly. If done correctly, END SIA should show up for a few seconds. All done.
Old 07-27-2005, 12:14 PM   #68
monchhichi
monchhichi's Avatar
My Ride: 2003 330i
Thumbs Up
COOL... It does reset my oil service but the service engine soon light still on..
Thank you very much!!!
Old 07-27-2005, 12:38 PM   #69
Cobra
whoops, i missed that. i'm not sure if you can even reset the service engine soon light yourself, you need to have that checked out, somethings probably wrong. take it to autozone and have them scan the error code.
Old 07-27-2005, 06:07 PM   #70
kevmo
kevmo's Avatar
My Ride: vDubDizzle
Send a message via AIM to kevmo
i just ddi it... worked on first try!!
now does anyone kno how to get rid of the airbag light?
kevmo is offline   Reply With Quote
Old 08-02-2005, 07:28 PM   #71
djpennin
My Ride: 00 323Ci SP/HK
Pin7 to GROUND works (19 didnt work for me)
I kept trying over and over again 7 to 19 with no luck. Finally I went from 7 to GROUND (on of the strut tower screws/bolts thats about 4 inches away)
and voila! it reset
djpennin is offline   Reply With Quote
Old 08-03-2005, 12:52 PM   #72
Lone
My Ride: 2000 328i
do you have to wear rubber gloves or anything? just paraniod that im might get electrocuted
Lone is offline   Reply With Quote
Old 08-03-2005, 01:25 PM   #73
kevmo
kevmo's Avatar
My Ride: vDubDizzle
no gloves required... use 2 paper clips.. one to connect 7 and 19.. and the other to touch the bolt right next to it to ground it... ur done
Old 08-12-2005, 05:54 PM   #74
cancell
My Ride: Is slow
my 2000 323i doesn't have the datalink connector... and that "empty box" has something that looks like an abs/dsc controller or w/e..
I don't have a current pic of that "empty area" but there should be pix of it on the photoalbum i made when i first got the car HERE
DISREGARD MY POST, i just read COBRA's post..
Live slow, die whenever.
cancell is offline   Reply With Quote
Old 09-23-2005, 12:21 AM   #75
tblue3cibm
My Ride: allroad / Hayabusa
I just happened upon this post and would like to it for a fanatic that might need it.
tblue3cibm is offline   Reply With Quote
Old 09-24-2005, 07:56 PM   #76
RockerGuy
My Ride: Not a BMW
Oh Gosh I finally got it to work. I spent like 2 hrs going between this computer and the car. I must have shhort every single pin in that DLC, I figured that I was shorting pin 20 instead of 19. I was about to give up but I think I read Jak's reply and he said to connect 7, 19 + Ground and it works. Thank God! U are the man Jak, I dont know how u figure it out.
I am soo friggin proud of myself now.
There is however, one concern. How is it that it says 25,000km inspection and not 25,000km oil service??
But anyway big thanks to those who contribute, u guys are the best
RockerGuy is offline   Reply With Quote
Old 09-24-2005, 11:24 PM   #77
SD 328I
My Ride: S197, E90, and 1125R
Because you go from oil and inspection intervals. If you want it to say oil service, you can short it again. It really doesn't matter though, just think of it as a service countdown no matter what it says.
BTW - How many miles do you actual go thru from "15,500 to 0" on the maintenance counter? I get a little over 8,000 miles by the time my counter reads zero from 15K.
SD 328I is offline   Reply With Quote
Old 10-05-2005, 11:26 PM   #78
markl951
My Ride: 323Ci
Having trouble resetting the oil service indicator even though I've tried every variation of the instructions throughout this post. As you can see, this is my first post to this forum so be easy on me...
There must be more detail to the process such as;
turn the key to position 1 or 2, short pin 7 and 19 for 5 seconds, unshort 7 & 19, turn off key, ect. Does it matter if you short pins 7 & 19 first and then turn the key? I've tried all different combinations and it still won't reset.
I also noticed that I don't have as many pins on the DLC as that shown at the top of the post but I definately do have 7 & 19.
BTW, pin 19 has continuity to chassis ground so all this talk about shorting 7, 19, and chassis ground together with a paperclip makes no sense to me at all. Against my electrical engineering judgement, I tried it anyway. Still no luck.
The car is a 2000 323Ci convertible.
markl951 is offline   Reply With Quote
Old 10-06-2005, 11:55 PM   #79
miclo82
My Ride: 99 bmw 323i
airbag?
thanks man, but any luck with reseting the air bag light?
miclo82 is offline   Reply With Quote
Old 10-11-2005, 07:10 PM   #80
acouet
My Ride: 2000 323I
Talking This is great!!
I'm new at the forum and was looking at a way to reset the stupid inspection light which was now at -4,200Km. I'm in Canada and the timer was in French. Didn't want to buy the tool or pay to get it reset after I did my own oil change, filter and spark plugs. After a few failed attempts...Bingo...25,000Km now showing.
COOL!!!
acouet is offline   Reply With Quote
