Thread Tools Search this Thread Rating: Thread Rating: 15 votes, 5.00 average. Display Modes
Old 03-31-2005, 10:50 PM   #21
sycE46
My Ride: 323ci
External Torx Sockets
Not a very common thing to have in your tool box.
sycE46 is offline   Reply With Quote
Old 03-31-2005, 11:05 PM   #22
sycE46
My Ride: 323ci
Stock Sway Bar removal.
picture of endlink behind spring & picture of Sway bar mount tabs.
ID:	119123   Click image for larger version
Old 03-31-2005, 11:17 PM   #23
E46325Ci
My Ride: 2004 325ci
hey thanks! I've swapped coilovers into my car, but never touched the sway bars... hope everything goes well for me tomorrow
Fern
E46325Ci is offline   Reply With Quote
Old 04-01-2005, 01:14 PM   #24
stickaz
My Ride: '01 330/'93 mustang
Originally Posted by sycE46
Diffs are cheap. They contain the final gear ratio. Easier to just buy one and swap it, then to open up the diff and rebuild it.
I understand cheap, but a re-built diff is always going to outperform/last a junkyard diff. Also you can use a stronger spring in the diff for a more robust posi-type action, and have complete freedom in gear selection, and you can stuff in additional clutch packs and so forth.
I haven't personally done the swap in an E46, but likely access to the rear cover for a fluid swap is about all the space you need to get at the diff to rebuild it and replace gears. In otherwords, their will be less labor involved.
To each their own, of course.
For instance, rebuilding the diff in my ford 8.8 takes all of around 30 minutes to swap the spring/clutchpacks in the diff, and another 30 minutes to remove the gears and swap them and set the backlash.
I have never swapped a rear (brake lines, sway bars, parking brake cables, lower/upper control arms) in less than 4 hours (removing + re-installing) and that's with some serious motivation to.
01 330i
98 QX4
98 Tahoe
93 mustang
stickaz is offline   Reply With Quote
Old 04-01-2005, 02:41 PM   #25
Alex323Ci
My Ride: M3 & 323Ci (sold)
I may be wrong, and not trying to make you look bad on this suggestion, but Ford diffs aren't as involved as BMW's. I've done diffs swaps in BMW several times, even had a Quaife on one. Having read up on the different diffs ratios and gears and such. I have found that it's always listed that BMW differentials are very tricky to rebuild and set-up properly. I have not tried on the E46, so it could be different. But Roundel, European Car, and BIMMER all strongly suggest only a very good specialized Differential shop rebuild, or else it'll go out in a short time. BMW only sells matching ring/pinion sets(engraved numbers on the sets)so that their tolerances are exact. I think that means it's gotta be very precisely installed and back lash set. But like I said, your suggestion may be very correct.
Old 04-01-2005, 05:31 PM   #26
stickaz
Differential rebuilds are always like that. This isn't a water pump replacement procedure, a more appropriate analogy is replacing a rod. You don't just slap the rod in there, you have to make sure it's straight on several axis', it may need re-machining, and you may need to install oversized bearings if you had to machine some material off to bring the rod end back to spec.
In any event, a dial caliper is part of the procedure for any make I'm aware of so that might be why hobbyists are asked to pass on it unless they know what they're doing--- But I don't think that just because there is a propeller on the hood that the differential is more complicated than anyone else's.
I could be wrong, I've never had one apart. I should ask the shop that did my last rear if they ever work on BMW's. I'm betting they do.
01 330i
98 QX4
98 Tahoe
93 mustang
Old 04-11-2005, 02:43 AM   #27
sycE46
My Ride: 323ci
I revised my DIY swap. Also include is a lot of e46 final drive ratio information, effects on top speed, BMW part #s, and other random stuff.
http://www.bokchoys.com/differential/
enjoy. Let me know if there's something you want me to add.
Old 04-16-2005, 02:22 PM   #28
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Stupid question, besides the actual 3.46 diff, what other parts do I need?
Also, I have a 04 6 Speed MT, I can put any old 3.46 diff from an E46 AT?
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 06-12-2005, 09:19 PM   #29
jmsanders78
My Ride: 328i, Z4
I did the DIY swap in my 328i today and followed your directions. They were spot on. My buddy said the same thing. Thanks for taking the time to write it up, because it was really helpful.
I think it took my buddy and I about 5 hours of real work. I stopped for lunch and the Canadian Grand Prix in the middle of the job. Plus a trip to Sears for a 6" socket extension. This thing is worth it's weight in gold for the diff swap. Perhaps most other people already have one, but I didn't, and it was immediately obvious to me that having one would make the job far easier. And it did. I might add that to your recommended tools list, but again, most people probably already have one.
Thanks again.
And I agree with everyone else's post-install reviews. I like the car a lot with this gearing. It'll take me a while to get used to how short 3rd gear is, but it's worth it for me.
jmsanders78 is offline   Reply With Quote
Old 06-13-2005, 01:53 PM   #30
E92M
E92M's Avatar
My Ride: '08 ZCP M3 | '03 R6
how do you know which diff you have already?
E92M is offline   Reply With Quote
Old 06-13-2005, 03:08 PM   #31
jmsanders78
My Ride: 328i, Z4
I'm too lazy to look, but on page 1 someone laid out pretty nicely which differential comes with with model car (based on transmission type as well). I went from 2.93 to 3.46.
Old 06-13-2005, 04:02 PM   #32
pwraudio1
My Ride: 330ci / Duramax
Very good info, thanks........
Remus DTM Exhaust
ECIS Evolution Air Intake System
AC Schnitzer 19" TYPE III
Yokohama AVS Sport
Racing Dynamics Front Strut Brace & Pedals
Momo Silver Combat Shift Knob
Piaa H7 & 9005
OEM Euro Clears
AC Schnitzer Roof Spoiler
M-Technic Lip Spoiler
Shark Injector
UUC Power Pulley & Clutch Stop
3.46 Diff
Hella Air Horns
pwraudio1 is offline   Reply With Quote
Old 06-14-2005, 02:11 PM   #33
pwraudio1
Question
Will a diff from a Xi work in my Ci????????
Remus DTM Exhaust
Yokohama AVS Sport
Piaa H7 & 9005
OEM Euro Clears
Shark Injector
3.46 Diff
Hella Air Horns
Old 07-31-2005, 11:34 AM   #34
tlp-96M3/2
My Ride: 03 e46 M3 - SOLD
Is there a DIY for a gear & pinion swap anywhere?
Past
e30 325is
e36 M3
e46 M3
tlp-96M3/2 is offline   Reply With Quote
Old 07-31-2005, 12:07 PM   #35
sycE46
My Ride: 323ci
http://www.bokchoys.com/differential/GearRatios.htm
if you have a manual tranny, look at the "Final Drive" column. Otherwise, the auto tranny column.
Old 07-31-2005, 12:08 PM   #36
sycE46
My Ride: 323ci
should work. Someone on the forum used an XI diff on his non-XI e46.
Old 07-31-2005, 12:19 PM   #37
E92M
E92M's Avatar
damn, as soon as i get my wheels, i'll start saving for a diff.
this sounds so sweet.
Old 10-16-2005, 12:21 PM   #38
iibauti
My Ride: 323ci
diff flange
how do you reinstall the diff flange? it came off and now i cant get it back on all the way?
iibauti is offline   Reply With Quote
Old 12-28-2005, 10:24 PM   #39
BimmerboyCi
My Ride: '00 BMW 323Ci
Thank you! Did the diff swap today and your write up was very helpful! Justin
BimmerboyCi is offline   Reply With Quote
Old 12-31-2005, 02:39 PM   #40
sycE46
My Ride: 323ci
I'm glad this write up has helped out a lot of people.
