Old 03-04-2004, 03:28 PM   #1
TeKNiC330
Banned
My Ride: IS ON STOCK 17'S
How hard is it to take out the rear springs?
I looked at the DIY instructions on this site. For the rears, it said that all i have to do is take the 18mm bolt off of the bottom of the shock and I should be able to get the springs off. Is that true? I'm thinking about taking the rubber pads off of my cupkit to give it more of a drop.
TeKNiC330 is offline   Reply With Quote
Old 03-04-2004, 03:45 PM   #2
tim330i
E46Fanatics Owner
tim330i's Avatar
My Ride: 03 Ti Silver M3
yes, it is true, why wouldn't it be?
tim330i is offline   Reply With Quote
Old 03-04-2004, 04:33 PM   #3
t-monkey
My Ride: 2004 ZHP
I'm not a mechanic or anything, but won't taking the rubber pads out make it noisy and cause metal to rub against metal?
t-monkey is offline   Reply With Quote
Old 03-04-2004, 05:20 PM   #4
SteelBlueXI
My Ride: BMW
Make sure you have a spring compressor to get those puppies back on.
-=Click For More Pictures=-
SteelBlueXI is offline   Reply With Quote
Old 03-04-2004, 05:24 PM   #5
tim330i
E46Fanatics Owner
tim330i's Avatar
You don't need a spring compressor for the rear.
Old 03-04-2004, 05:26 PM   #6
SteelBlueXI
My Ride: BMW
Really?? Good to know.
Old 03-04-2004, 05:28 PM   #7
tim330i
E46Fanatics Owner
tim330i's Avatar
This is true, also unless you cut the center out of the pad the spring is not going to sit on the control arm correctly.
Old 03-04-2004, 06:10 PM   #8
TeKNiC330
Banned
Thanks, (EDIT:=TIM, not rob)...couple of guys have taken out the pads on their cars for the cupkit. It lowered the car about 1/4-1/2 inch.
They said they never experienced any noise or any fitment problem. Do you know if any damage will be done to the car by doing this?
Old 03-04-2004, 06:25 PM   #9
tim330i
E46Fanatics Owner
tim330i's Avatar
Originally Posted by TeKNiC330
Thanks rob...couple of guys have taken out the pads on their cars for the cupkit. It lowered the car about 1/4-1/2 inch.
Are you talking to me? My name is Tim, not Rob.
Old 03-04-2004, 06:32 PM   #10
TeKNiC330
Banned
LOL my bad tim. I was on the phone with rob ordering a knob. Sorry. I'm not too good at multitasking.
Yup, so do you think it will mess up my car TIM?
EDITED.
Old 03-04-2004, 06:44 PM   #11
tim330i
E46Fanatics Owner
tim330i's Avatar
EDITED.
No problem.
I don't think it is a good idea personally but it sounds like people are running that setup without issue.
Tim
Old 03-04-2004, 07:36 PM   #12
TeKNiC330
Banned
No problem.
Tim
Yea, i'm not too sure how the long term is gonna be. But I'm gonna take them off and try it out for like a week or so. Doesn't seem too hard to do right?
Old 11-14-2005, 10:42 PM   #13
xmltok
My Ride: 2014 Carrera 4S
Send a message via AIM to xmltok
so.. How did it turn out?
xmltok is offline   Reply With Quote
Old 11-15-2005, 03:47 AM   #14
eu4yah
My Ride: 325ci sport pckg
I just did mine today with bimmerxtc. it's very easy took us 30 mins per tire to take it off and put a new springs! just 1 bolt and your good! Pm me if you need help!
BREYTON SPIRITS
19X9, 19X9.5
eu4yah is offline   Reply With Quote
Old 11-15-2005, 10:01 AM   #15
xmltok
Did you use the lower rubber pad?
Old 11-15-2005, 10:51 AM   #16
Canuck328i
My Ride: 09 Altima Cpe
Personally I wouldn't go without the pads for fear of noise and possible damage to the spring and/or mounting points. At the very least you'll have the finish wear off the spring in no time and it will rust. The pads are only 5mm uncompressed anyway - the height difference is minimal.
Mark
Canuck328i is offline   Reply With Quote
Old 11-15-2005, 11:39 AM   #17
eu4yah
Mark
yes i put it back! it's doesn't change a lot if you put it or not! Canuck328i is right, 5mm of height is minimal and it's not worth it to remove it!
BREYTON SPIRITS
19X9, 19X9.5
Old 11-15-2005, 11:42 AM   #18
trickydik_1
My Ride: stanced
Send a message via Yahoo to trickydik_1
you dont need a spring compressor!
trickydik_1 is offline   Reply With Quote
Old 11-15-2005, 03:25 PM   #19
xmltok
This is what I was originally asking about, I wanted to know if anyone had problems after running without the lower pad for some time. 5mm is 1/5", and with the angular difference this would be a little more at the wheel.
