Miscellaneous
Old 03-18-2004, 02:20 AM   #1
hamann99
X-Hamann99
My Ride: 323i->350Z->87 325is
Send a message via AIM to hamann99
Seattle Local Only: Griot's Garage Floor Paint Super Deal!!!
Hey guys I've decided to actually not use the paint I got from a while back and they're up for grabs. They're running for roughly 56 from griot's for 1 gallon. I have 3 available I'll sell them for $35 ea or 100 for all 3 Here is the description directly from Griot's website Let me knwo if anyone is interested. FYI: color is gray
THIS IS BY FAR THE SINGLE NICEST THING YOU CAN DO FOR YOUR GARAGE.
The secret to any great garage starts with the floor. And not just any floor paint, but Non-Lifting Floor Paint. The simplest and least expensive way to add enjoyment to your working environment is to paint the floor. Just read our testimonials! Twenty years ago I painted my first garage floor, and thorough the years Iíve learned what works and what doesnít. When I started my business over 13 years ago, garage floor paint was one of the very first products I offered. I now see all sorts of paints on the market. I firmly believe through our research into the best paint and development of our detailed instructions that we are able to give you the very best floor paint available. You wonít believe what a difference a painted concrete floor can make. Youíll have more light, easier clean ups, find dropped fasteners quickly, or eat off the floor like I do. Youíll have a smile on your ace every time you pull in the garage.
If you think the so-called "concrete paint" you can buy at your local paint store won't lift, you're wrong. The problem with these paints is that they reactivate themselves once a hot tire is rolled onto them. This reactivation causes the paint to stick to the rubber and lift. Our continual improvement to this product has allowed it to stand up to our toughest test yet! Our 5,000 lb. forklift with flat, smooth tires didn't even lift the paint on our warehouse floor! We turned the tires while standing still and the paint didn't even creep! We left brake fluid on it for one week and it didn't even bubble!
If you can follow directions and can prepare your floor correctly, this paint won't lift and will look beautiful for years. Come by our warehouse and see for yourself! Not warranted as I can't come and install it for you. Colors: Light Gray or Tan. Concrete must be etched with muriatic acid and all previous paint removed before painting. (Youíll find our Paint Stripper here.) One gallon covers 130 square feet in 2 thin coats. Two coats are required. Color paint chip samples are available (call 1-800-345-5789 to order samples.)
pm/email if you're interested
Any fool can drive in a straight line
hamann99 is offline   Reply With Quote
