From Auto-X to Trackday to Racing and Professional Motorsports – this is the place to discuss making BMWs fast
Old 03-22-2004, 11:50 AM   #1
mfino
I give up.........
My Ride: 00 323i SP-P blk/blk
Custom Alignment - Autocross
Hi there. I hope this is in the right forum, if not, I'm sure it will get moved. But has anyone had a custom alignment done for Autocross purposes? What should I know on what setup to look for or recommend. Also, can any shop can perform this, most places say they cannot do an alignment on BMW's, and I'm not quite sure why. Also, Can this be done on a stock suspension? Sorry for all the questions, but rookie school is coming up. Thanks again.
ECIS Intake | Shark Injector | Scorpion Exhaust | PG2 style rims, YOKOHAMA AVS ES100 235/40/18 | M3 Lip Spoiler | OEM Clears | Hamann Eyelids | M-Technik Front | M-Technik Sides | M-Aero Rear | 50% Tint | M3 Dead Pedal | MOMO Aluminum Pedals | UUC Gauges |Titanium Shadow Painted Trim
mfino is offline   Reply With Quote
Old 03-22-2004, 11:59 AM   #2
MrMotorwerk
Der Meisterstück
MrMotorwerk's Avatar
My Ride: '02 330Ci,'01 M3,M4
Some serious autocrossers do setup their cars for autocrossing. However if this is going to be your first autocross or maybe even your first season, you should get to know your car first before you do anything. Hardcore autocrossers who setup their alignment, usually have Camber plates installed into their cars so that they can adjust: camber, toe etc... But you should just make sure that your car is straight first and have fun before you get serious. Once you get to know your car fairly well, the camber and toe of the car will mean alot more to you in an autocross.
As for alignment shops, I recommend that you look into the shops that advertise in the local newsletter of your BMWCCA chapter. Chances are that most of the BMWCCA shops are weekend warriors.
Mr.Motorwerk
MrMotorwerk is offline   Reply With Quote
Old 03-22-2004, 12:39 PM   #3
Mr Paddle.Shift
Mr Paddle.Shift's Avatar
My Ride: B3 epsilon
mfino, I will definitely recommend attending the event with you car as-is. In fact, take enroll in a couple more events after that. Get to know the car a little better. Then think about adjusting the necessary. Talk to some of the more experienced autox-ers at the events. You will learn a lot from them.
Technik Engineering ASA Stage 1.
Supercharged E46 M54B25.
2011 NASA TTC So Cal Champion!
Track blog.
Technik Engineering oil cap o-ring maintenance kit available.
Mr Paddle.Shift is offline   Reply With Quote
Old 03-23-2004, 08:37 AM   #4
mfino
I give up.........
Thanks for the input guys. I hope to have a write up on how the school, and non points session go this weekend. Thanks!
Old 03-23-2004, 09:23 AM   #5
sfzBimmer2
My Ride: '05 Ducati Monster
^^Can't wait to see the review, have fun !
sfzBimmer2 is offline   Reply With Quote
