Sponsored by BAVSOUND
Old 03-23-2004, 12:00 AM   #1
BGAndrea
My Ride: 2012 Audi S4 Sedan
Send a message via AIM to BGAndrea
Amps/subs for 330 droptop?
Im looking to upgrade my factory amp and maybe put in a removable sub box that I can switch back to factory when it is taken out of car as I have NO TRUNK SPACE... I dont want to lose my spare wheel well but want to know how I can put amps in... I got a kicker amp from my suburban but it would cover up my ski hole thing. Are there small amps that maybe I could put one on each side? Has anyone done an install on a droptop? Is it worth changing amps or is the HK good enough?
BGAndrea is offline   Reply With Quote
Old 03-24-2004, 03:02 PM   #2
unionjack
Conceited Prick
unionjack's Avatar
My Ride: 997.2 C2S | ML350
Here's a nice setup:
http://forum.e46fanatics.com/showthr...hreadid=120335
Note: on convertibles there is only 1 sub and no separate sub amp. You must tap into the line-level wires going into the sub.
Additionally, if you use the Peripheral VENREM line-out converter you don't have to splice into the main amp for the remote switch. The VENREM has a built-in remote switch. It has a lead and ground that can be wired up easily from the trunk and a remote that goes to the amp. This makes it even easier to wire.
unionjack is offline   Reply With Quote
