Old 04-19-2002, 12:04 AM   #1
BimmerBong330ci
My Ride: POS
Send a message via AIM to BimmerBong330ci
UUC Short Shift Kit - Please help!
So I had this loud gear whine in the cabin but installed a new SSK yesterday. It's 100% quieter but I can still hear the synchros and gears mesh when I shift gears.
Anyone experience this? I've got the Delrin Bushing upgrade, could this be part of the problem?? I'm getting so bloody annoyed with this! I've even changed the shift knob to a MOMO short anatomic as the stock wood knob was making the noise even louder.
Please help!
BimmerBong330ci is offline   Reply With Quote
Old 04-19-2002, 12:05 AM   #2
Clem
Alpha Male
Clem's Avatar
My Ride: Twin Turbo'd Beast
Check if the rubber boot is seated correctly.
Clem is offline   Reply With Quote
Old 04-19-2002, 12:17 AM   #3
BimmerBong330ci
My Ride: POS
checked, along with foam insulation. could it be the delrin bushings?
Old 04-19-2002, 12:19 AM   #4
tim330i
E46Fanatics Owner
tim330i's Avatar
My Ride: 03 Ti Silver M3
Re: UUC Short Shift Kit - Please help!
Best bet is to give Rob at UUC a call.
Tim
tim330i is offline   Reply With Quote
Old 04-19-2002, 12:30 AM   #5
Karl
Engineer
My Ride: 2001 330xi
With such a stiff setup from the selector rod on the transmission to the shift lever, noise transmission from inside the gearbox to the knob is unavoidable. The connection is more direct than you think - the selector rod manipulates additional pieces inside the gearbox that move the gears around. The way you stop this noise is that you need acoustic dampening material in the lever or the rod, between the gearbox and the shift knob. Stock BMW levers have this - the lower and upper sections of the shift lever are connected with semi-stiff rubber. But the stiff nature of the UUC setup (esp with non-rubber bushings) causes this noise to be transmitted into the cabin. It shouldn't be much louder than a "normal" playing volume on your stereo though.
Karl is offline   Reply With Quote
