Sponsored by BAVSOUND
Old 04-06-2004, 12:15 AM   #1
Jackboot
My Ride: Bus
Help - can't fit my MB Quart PCE 216 in sedan
I've read on here from numerous people that they fit the MB Quart PCE 216 components (6.5") in their sedan...
...well I tried fitting these components in my 2004 330i this weekend, and I cannot get the door panels to snap back on around the woofer now.
Will someone who's installed these give me some pointers? When I mounted the woofers I had to kinda force them in between the 3 pegs that go up around the speaker grill. I think they are sitting flush on the door panel.
Help, anyone!?
Jackboot is offline   Reply With Quote
Old 04-06-2004, 12:01 PM   #2
sansan
My Ride: AMG GTS
Send a message via AIM to sansan
Anyone else out there have this problem? I was thinking about getting the same components for the front.
sansan is offline   Reply With Quote
Old 04-07-2004, 12:13 AM   #3
Jackboot
My Ride: Bus
seriously folks...I know there are plenty of peeps on this board who have installed these components...help a couple fanatics out and tell us if there is any special method to mounting these woofers - my door panels won't go on correctly...
Old 04-07-2004, 01:13 AM   #4
\\V
My Ride: 2002 AW 330ci
What kinda trouble are you having? Is it that the door panel won't come back in all the way? I don't know how much difference b/w the coupe and sedan doors. I have 6.5" in my front doors and there is a small gap in the bottom part of the front doors where they snap in. My cousin did all my audio work and made them fit. I've searched the forum and read somewhere that they had to make a custom bracket so that the 6.5" speaker will fit correctly.
\\V is offline   Reply With Quote
Old 04-07-2004, 11:15 AM   #5
Jackboot
My Ride: Bus
Yes - the trouble I'm having is that the door panel won't go back in all the way - I have a small gap at the bottom part of the front doors where they snap in. Did you solve this problem? If so, how?
Old 04-07-2004, 12:55 PM   #6
\\V
I have not solved that problem. The gap is small to where you can only notice it when you're looking at it. I'm planning to take my door apart and see it there is a solution or not when I have time is available.
Old 04-13-2004, 11:40 PM   #7
prelude778
My Ride: 325
I got the solution for you guys!
DREMEL
thats what i used. Shave some of the plastic down and you'll be fine.
My set of 218's fit perfectly.
prelude778 is offline   Reply With Quote
Old 04-14-2004, 12:28 AM   #8
\\V
thanks! I just bought me a dremel a couple of days ago. I'll look into doing that
Old 04-14-2004, 01:49 AM   #9
Jackboot
My Ride: Bus
DREMEL
218s? What are those?
Where did you shave down some of the plastic? Give me a few more details if you don't mind!!! Thanks
