Sponsored by BAVSOUND
Old 04-08-2004, 09:12 PM   #1
668Ci
My Ride: 2.5 ASA Technik SKI
ppi amp not working
My $600 PPI amp has been sitting in my garage for a long time. It has stopped working since I messed with the wires and the battery terminal still on, i know stupid but oh well the amp is only a month old. Is it fixable? is the fuse located inside? if not where can i get it fixed in the bay area???
Thanks guys
668Ci is offline   Reply With Quote
Old 04-08-2004, 11:16 PM   #2
SiLvaC32
My Ride: C32 AMG
Send a message via AIM to SiLvaC32
check if there is a voltage feed and draw. if you have a volt meter, that should be very easy.
SiLvaC32 is offline   Reply With Quote
Old 04-09-2004, 09:27 AM   #3
kartele
My Ride: 2000 323ci SOLD!
If its not fixable I have a PPI 2150 2 channel amp for sale. Its the power class amps dealer cost on it was $690, retail was $900. I'll take $300.
kartele is offline   Reply With Quote
Old 04-09-2004, 10:01 AM   #4
ca1242
My Ride: 2003 330i
Repair is not always the best option anymore, unless you can find a good/cheap place. Most places charge $30 - $50 just to look at it and just find the problem! Repair and parts is usually at least $100.
Open it up and see if you can find anything obvious such as a loose wire. Maybe you can fix it yourself if it is simple enough.
Old 04-09-2004, 11:30 PM   #5
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
If its the old "art" series, it would be worth fixing.
Ca142, did you install those Punch 200's yet?
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 04-13-2004, 05:48 PM   #6
668Ci
Ok, I got the volt meter and the needle moved to the middle, but then it just stopped? is the amp dead? sorry dont know about electrical stuff
Old 04-14-2004, 07:02 AM   #7
ca1242
My Ride: 2003 330i
Do you mean my amp? I have not started working on the audio in my car yet (maybe next month) I am finishing up with the remote start/instrument cluster V1 display.
Old 04-14-2004, 07:11 AM   #8
ca1242
My Ride: 2003 330i
What setting is the voltmeter on and what are you measuring? What does it say "when the needle is stuck in the middle?" If you measure DC voltage (set it on 20v scale), you should have about 12volts from the amplifier ground to the battery (should be two fat wires). You should also have about 12 volts from the gound to the remote turn on wire -when the radio is on-
Maybe you amp is not bad and it is an installation problem. If it is too difficult, have someone check it out for you and tell you for sure. Grab the yellow pages and ask around how much they would charge you to figure out what the problem is.
