Sponsored by BAVSOUND
Old 04-10-2004, 10:38 AM   #1
rps4
Remote Wire for Line Converter in Touring
Guys,
i have a touring with the stock audio system and wanting to add a amp in the rear for a sub. i have a line converter that i can connect into the rear speakers however still need a remote leed, anyone know if theres and connections in the rear on where i can take the remote off for the amp,
cheers.
rps4 is offline   Reply With Quote
Old 04-10-2004, 11:04 AM   #2
CynicalWry
Doesn't like PMs...Email me
CynicalWry's Avatar
My Ride: 00 323i-05 cbr600rr
Send a message via AIM to CynicalWry
Originally Posted by rps4
Guys,
cheers.
Tap into the white wire in the wiring harness for your stock amp in the back.
is your friend
Authorized Umnitza.com installer
301-825-5871
http://www.robinsNestChildCare.com - - - - - http://www.tntTint.net
CynicalWry is offline   Reply With Quote
Old 04-10-2004, 08:45 PM   #3
rps4
hi mate,
thanks for the reply, however i dont have a amp in the back, i do have a cd changer of which i will look for a white wire.
You setup is exactly what i want, a screen with pc functions.
I own my own Computer buz in the uk so i have access to any pc stuff and have thought about installing a pc however dont know how i would go about installing the screen (like yours), i have called a number of shops here in the uk about mounting the screen and all they can offer is a bracket which will sit ontop of the dash (i dont what this), also how have you connected the pc in to the stock stereo system.
Thanks for the advice.
Sorry mate, but my final question is how do i run the cables from the front of the car to the back.
Old 04-11-2004, 05:49 AM   #4
briank995
My Ride: 323i
hi mate,
you do have an amp... its right here buster!
http://members.roadfly.org/captain_w...o/Dscn3627.jpg
http://members.roadfly.org/captain_w...o/Dscn3628.jpg
http://members.roadfly.org/captain_w...o/Dscn3629.jpg
http://members.roadfly.org/captain_w...o/Dscn3630.jpg
briank995 is offline   Reply With Quote
Old 04-11-2004, 10:41 AM   #5
rps4
thanks Brian,
i have just checked and all i have is a cd changer.
My BMW is a new 320d sport touring with the blue tooth phone system and the standard bmw business stereo.
thanks mate.
Old 04-11-2004, 04:03 PM   #6
CynicalWry
CynicalWry's Avatar
thanks Brian,
thanks mate.
Did you actually pull the carpet away from the wall in your trunk? I just checked my BMW ETK and you sure better have an amp. It should be on the left side of the car behind the trunk liner closer to the tail light.
is your friend
301-825-5871
Old 04-12-2004, 03:02 PM   #7
rps4
hi mate,
i double checked again and i do not have a amp, i checked my car with the pictures and i dont have the small black box (amp)
could this be because i am in the uk or its a wagon/touring.
thanks
Old 04-12-2004, 09:01 PM   #8
CynicalWry
CynicalWry's Avatar
hi mate,
thanks
I've never known of an e46 without an amp. You can look at your head unit wiring harness for the white cable. Test it with a volt meter to see if it gives you 12 volts only when the car's radio is turned on. If it does, tap into it and run a fresh wire for your subs.
is your friend
301-825-5871
Old 04-13-2004, 03:12 AM   #9
rps4
Thanks mate, it looks like i'll have to do that, i even checked again to see if i have a amp, o well, more work for me.
Thanks for all you help mate.
Best Regards
Roger
