Sponsored by BAVSOUND
Old 04-10-2004, 09:35 PM   #1
aboE46
My Ride: 2001 blk 4dr
I need advice, PLEASE help
I recently obtained a 12" Infinity Perfect. What amp should I get and what kind of box (bandpass or sealed). Also, need some ideas of how to place it the trunk (facing through the ski hole or some other idea) thanx
aboE46 is offline   Reply With Quote
Old 04-10-2004, 09:36 PM   #2
aboE46
this speaker is big, i think it has a 1400 peak wattage on it so keep that in mind. Anybody who has had experience with this speaker please get at me.
Old 04-13-2004, 01:48 AM   #3
aboE46
Some one help me out i need some bass up in my whip
Old 04-13-2004, 11:09 PM   #4
aboE46
Old 04-14-2004, 09:34 AM   #5
ca1242
My Ride: 2003 330i
Look at the instructions or contact the manufacturer for recommended enclosure. If there are different "recommended" options (i.e. bandpass, sealed, ported, etc), then it depends on what type of music you listen to, what type of bass response you like and how much space you are willing to sacrifice. I am personally into sound quality, so I prefer sealed boxes.
As far as power, get as much as you can afford!
Edit: Also, for location, generally in sedans either do a custom box in the corner of the trunk or behind the seat facing backwards. If you are going with bandpass, then the best option will most likely be to have the port right at the ski pass.
Old 04-14-2004, 10:08 AM   #6
sfh
My Ride: bmw
if you got the specific model number i could come up with some numbers
sfh is offline   Reply With Quote
Old 04-16-2004, 04:41 PM   #7
aboE46
thanx for the help, I found the link to infinity that offers all the info you all may need. According to them I can use the enclosure of my choice. I would like a big sound and I listen to hip hop, but I also want it to look good so I am open to any suggestions. Please reccomend some specefic amps that would be good to buy. I dont want to spend more than about 600 for an amp.
some details:
Power Handling, Peak: 1400W
Power Handling, RMS: 350W
Sensitivity: 96dB (In car)
Frequency Response ( 1.5dB): 18Hz - 150 Hz
Frequency Response (3dB): 18Hz - 150Hz
Impedance: 4 Ohms
Mounting Depth: 6-1/2"
http://www.infinitysystems.com/caraudio/product.aspx?ProdId='KAPPA+PERFECT12.1'&Ser=KPE&Cat=SUB
Old 04-16-2004, 04:44 PM   #8
aboE46
Edit: Also, for location, generally in sedans either do a custom box in the corner of the trunk or behind the seat facing backwards. If you are going with bandpass, then the best option will most likely be to have the port right at the ski pass.[/QUOTE]
Does anyone have a setup where the bandpass is ported through the ski pass as explained here, if so please put up some pics.
Old 04-17-2004, 12:16 AM   #9
Wai718
My Ride: 99 Bmw 328i
hi everyone! just an example!
Name:	my setup.JPG
Wai718 is offline   Reply With Quote
Old 04-18-2004, 05:24 PM   #10
aboE46
thanks, if you can post some pics of your setup from the inside, (how it looks through the ski pass) also people give me some advice after looking at infinity website
Old 04-19-2004, 09:25 PM   #11
aboE46
Old 04-23-2004, 12:51 AM   #12
aboE46
