Go Back   E46Fanatics > Tuning & Tech > Bavarian Soundwerks' Mobile Electronics Forum
Sponsored by Bavarian Soundwerks
Old 04-13-2004, 07:16 PM   #1
pbotz2000
My Ride: 2002 330ci
Where Did You Mount Your Amplifer
Im Looking To Mount My Amplifer Under The Rear Deck Of My Coupe, Upside Down, Im Worried About It Heating Up, Anyone Else Have Their Amp Under There, And How Does It Work, There Is A Cooling Fan In My Amp,but I Feel It Will Be Hard To Blow The Air Downward,
pbotz2000 is offline   Reply With Quote
Old 04-14-2004, 02:26 AM   #2
PAGALM3
My Ride: 2002 M3
I installed my JL Audio 250/1 under the rear deck and I haven't had any issues with it so far. Of course, it isn't the most ideal mounting scenario especially since the heat rises straight into your amplifier, yet having a fan and some clearance for air to circulate won't hurt. I got my idea from fellow e46fanatic Frank Rizzo, you can check out his post here Frank Rizzo's Install. He mounted his amp using a size 10-32 screw, some well nuts, and nylon spacers. The well nuts are basically rubber rivets, and you can find them in any local hardware store. I had to modify his method a little and mount a board to the rear deck using the well nuts. Then I mounted the amp to the board with nylon spacers to give it some breathing room. Finally, I cut up the HK sub system and used it as a cover to hide all the wiring and make the install appear stealth when you're looking into the trunk. You can't see the amp until you look under the deck. Here are some pics for reference; hope this helps!
• Here's the mounting board attached to the rear deck:
• Here's the final product when seen directly at rear deck level:
PAGALM3 is offline   Reply With Quote
Old 04-14-2004, 02:34 AM   #3
budman
-not a mod-
budman's Avatar
My Ride: is your mom
Send a message via AIM to budman Send a message via Yahoo to budman
Mine is mounted that way and I haven't had any issues with it. Maybe my posted box blows enough air on it to keep it cool.. who knows.
-Gunnar
budman is offline   Reply With Quote
Old 04-14-2004, 06:43 AM   #4
pbotz2000
My Ride: 2002 330ci
nice job
what are those boxex below the rear speakers, ive never seen them before, is it a sub in each of them,
Old 04-14-2004, 08:25 AM   #5
stinkboy
My Ride: 04 330i ZHP
Send a message via AIM to stinkboy
those are jl audio stealthbox subs. they replace oem stereo's that have subs. the rear speakers are in the deck about six to eight inches in towards the cab.
stinkboy is offline   Reply With Quote
Old 04-14-2004, 09:30 AM   #6
ca1242
My Ride: 2003 330i
Instead of mounting it upside down, why not mount it in the same place, but "top side up". You might need to come up with some creative mounting brackets or "suspended" mounting board, but it would be a better solution to put less strain on the amplifier.
Old 04-14-2004, 10:14 AM   #7
sfh
My Ride: bmw
make sure your amp is not in touch with any metal as it most likely will be broken....
sfh is offline   Reply With Quote
Old 04-14-2004, 10:41 AM   #8
Mystikal
My Ride: S54 M Roadster
I mounted mine above the battery, on the side. Never in the way, great ventilation, easy to adjust settings.
Mystikal is offline   Reply With Quote
Old 04-14-2004, 05:28 PM   #9
djabaley
does anyone read my p0sts?
My Ride: 325 slushbox
I mounted mine on a motorized plexi rack
http://forum.e46fanatics.com/showthread.php?t=22573
djabaley is offline   Reply With Quote
Old 04-15-2004, 09:53 PM   #10
CQVD330
My Ride: 2001 330ci
I you have 80hrs to spend...
CQVD330 is offline   Reply With Quote
Old 04-15-2004, 10:22 PM   #11
sansan
My Ride: '11 Cayenne S
Send a message via AIM to sansan
What's wrong with mounting your amp to metal?
sansan is offline   Reply With Quote
Old 04-16-2004, 06:28 AM   #12
ca1242
My Ride: 2003 330i
You could get alternator noise.
Old 04-16-2004, 07:11 AM   #13
sansan
I guess I was referring to this post. How would it break the amp?
