Sponsored by BAVSOUND
Old 04-14-2004, 06:49 AM   #1
rdsesq
ouroboros autorotica
rdsesq's Avatar
My Ride: 2002 330i
Mounting cd changer and/or nav under a sub box
I am trying to layour my ICE install. I will have a sub box, probably with 2 10inch subs. My calcs show, that in theroy there is enough space to mount the cd changer and navi under the sub box. So it would look like this
|xxxxxxxxxxxxxxxxx|
|xxxx Sub Box xxxx|
|xxxxxxxxxxxxxxxxx|
| cdc xxxxxxx navi |
Anybody tried doing this type of setup or would the subs cause to much vibration.
Any info appreciated.
thanks,
rob
"The existence of life is a highly overrated phenomenon."
-- Dr Manhattan
quis custodiet ipsos custodes
rdsesq is offline   Reply With Quote
Old 04-14-2004, 08:41 AM   #2
ca1242
My Ride: 2003 330i
There really is no way to guess if it will cause problems. I would try to avoid it if you have any alternatives, but if you are really set on doing it that way, try to isolate the changer/navi from the box. If possible, don't mount them directly on the box. Maybe you could put an piece of wood on the floor to mount them to and then build the box around it, without directly touching them. I have done it many times without problems, while there have been a couple times when I have seen skipping problems when changers are mounter directly on the box.
