Sponsored by BAVSOUND
Old 04-14-2004, 01:42 PM   #1
pbotz2000
My Ride: 2002 330ci
Is 40 Rms Watts Enough
IS 40 WATTS RMS ENOUGH TO POWERFULLY RUN 5-1/4 COMPONENTS, INFINITY PERFECT, 5.1, ITS A KICKER AMP, NOT SOME BS
ANY FEEDBACK, 40 WATTS RMS GONNA DO IT,,
pbotz2000 is offline   Reply With Quote
Old 04-14-2004, 04:01 PM   #2
ca1242
My Ride: 2003 330i
Your caps lock button might be stuck. 40 watts is definitely more than the 15 watts a head unit puts out, so it will be ok. But it really depends on how loud and how clear you want your music to be. It is all relative to your personal preferences. I would not get anything less than 100 watts, if budget allows.
On my last car I had about 150 watts per channel on my front speakers and it sounded pretty decent. I will probably go with 200+ on my next setup though.
It's like horsepower. You can never have enough!
Old 04-14-2004, 04:32 PM   #3
PM "Corrupted"
Clem's Padawan
My Ride: 2004 X3
Kicker = not BS
PM "Corrupted" is offline   Reply With Quote
Old 04-14-2004, 06:11 PM   #4
ca1242
My Ride: 2003 330i
Originally Posted by PM "Corrupted"
Kicker = not BS
Kicker makes pretty good stuff (I used to install it and had three of their amps, and subs).
Old 04-14-2004, 06:38 PM   #5
330Bimmer3
My Ride: ///M3
Send a message via AIM to 330Bimmer3
Yeah Kicker isn't bad stuff, just a little cheezy/crappy looking designs. There high end stuff is actually pretty good.
Current: 2006 BMW ///M3 Vert | Black, Black | SMG | 19" CSL Concave
Previous: 2001 BMW 330Ci | Steal Grey, Black | Dinan Stage 3 | B&B Exhaust | Bel Installed | (2) JL W6v2 (2) JL 500w | Rear Spoiler | 30% Tint
330Bimmer3 is offline   Reply With Quote
Old 04-14-2004, 07:19 PM   #6
PM "Corrupted"
Clem's Padawan
My Ride: 2004 X3
there older stuff was I have not heard good things relating to actual power ratings, etc about there newer "affordable" lines.
Old 04-15-2004, 07:36 AM   #7
ca1242
My Ride: 2003 330i
If that is the case, then it is certainly a shame... they used to make really good solid stuff, even in their old lower line (Impulse). I also don't care much for their newer "gothic" look, it is a little bit gaudy.
Old 04-15-2004, 08:25 AM   #8
Myah
My Ride: CB ZCP
I'd agree with most of the opinions I've seen thus far on this topic... 40 watts is "enough" but more would be better. If you had kept your stock speakers, I'd say 40 watts would be more than enough... Since you have upgraded your speakers, look at the "operating" range of input wattage they suggest... something tells me it's in the 40 to 100 (max) range... You also need to keep in mind that 40 watts out of a Kicker will not be the same as 40 watts out of a PPi or JL... Everyone rates theirs differently. If you're questioning whether or not 40 watts is enough, why not hook up the system with the option of trading up your amp.
What I'm suggesting is install (maybe not permanantly just yet) what you have with the intention of protecting for a larger amplifier if need be; put in larger than required power cable, and whatnot... this way if you are not happy with what you have, you'll be able to upgrade the amp and just swap out the old one?
Just my 2 cents...
Best Regards,
Jeremy
Myah is offline   Reply With Quote
