Miscellaneous
Old 04-19-2004, 04:06 PM   #1
socowolf
My Ride: 2000 328i
Send a message via Yahoo to socowolf
Behringer GEQ3102 Ultra Graph Pro 31-Band EQ
This is a great unit. My wife bought it for me for my birthday thinking it was a mobile audio accessory - and of course it's not ... but that's OK. I just don't have a need for another home EQ. Brand new, in the box, all manuals, etc.
First $140 OBO takes it - I'll pay for shipping.
PayPal master@socosolutions.com
Features
31-band stereo graphic equalizer for live and studio applications
Sound improvement in post-production and all recording situations
Sweep-able high-pass and low-pass filters remove unwanted signal portions, i.e. impact noise, tape hiss, etc.
Servo-balanced inputs and outputs with gold-plated XLR and 1/4" TRS connectors
Relay-controlled hard bypass switch with auto bypass function (safety relay)
Extremely low-noise operational amplifiers for outstanding audio quality
Illuminated high-precision Alps faders
12-segment LED display for input or output level
High-quality components and rugged construction for long life
Manufactured under ISO9000 certified management system
Audio Input
Connectors: XLR and 1/4" jack
Type: RF filtered, servo-balanced input
Impedance: 50 kOhm balanced, 25 kOhm unbalanced
Max. input level: +21 dBu balanced and unbalanced
CMRR typ.: 40 dB, > 53 dB @ 1 kHz
Audio Output
Type: electronically servo-balanced output stage
Impedance: 60 Ohms balanced, 30 Ohms unbalanced
Max. output level: +21 dBu balanced and unbalanced
System Specifications
Frequency response: 10 Hz to 35 kHz, +/- 3 dB
Noise: > 92.3 dBu, unweighted, 22 Hz to 22 kHz
THD: 0.004 % typ. @ +4 dBu, 1 kHz, Gain 1
Crosstalk: < -85 dB, 22 Hz to 22 kHz
Roll-Off Filter Section
Type: 12 dB/oct., butterworth
Input variable: (-15 dB to +15 dB)
Low cut variable: (10 Hz to 400 Hz)
High cut variable: (2.5 kHz to 30 kHz)
Graphic Equalizer
Type: analog 1/3-octave equalizer
Frequency range: 20 Hz to 20 kHz in 31 1/3-octave bands (ISO frequencies)
Bandwidth: 1/3 octave
Control range: +/- 6 dB or +/- 12 dB (switchable)
Function Switches
Audio in/out: switch to bypass the equalizer functions
I/O meter in/out: switches the meter display from input to output
Range: shift of the maximum cut/boost range for all 31 bands
Indicators
Input/output level: 12-segment LED display: -30/-24/-18/-12/-6/-3/0/+3/+6/+9/+12/+18 dB
Function switch: LED indicator for every switch
Power Supply
Mains voltages: USA/Canada 120 V ~, 60 Hz
U.K./Australia 240 V ~, 50 Hz
Europe 230 V ~, 50 Hz
General export model 100 - 120 V ~, 200 - 240 V ~, 50 - 60 Hz
Power consumption: max. 20 Watts
Fuse: 100 - 120 V ~: T 400 mA H
200 - 240 V ~: T 200 mA H
Mains connection: standard IEC receptacle
Physical
Dimension: 3-1/2 x 19 x 5.3 in. (89 x 482.6 x 135 mm), approximately
socowolf is offline   Reply With Quote
