Sponsored by BAVSOUND
Old 04-23-2004, 03:10 PM   #1
Tom///
My Ride: 95 M3 RIP, tpz 330ci
headunit amp and factory amp does one have to give?
Ok, so I am about to put in my alpine headunit in and I am using scoshe wiring harness for oem plug in, problem is if I do that I think all my signals will be running 45 watts * 4 to the factory amp, which might fry the factory amp??? If there is a way to turn off the alpine interal amp should i do that? I am also using a line output converter to power a mono block amp and two channel amp for the fronts, could the alpine signal pose a problem there?
Finally, the scosche mounting plate doesn't seem to clip onto the alpine deck at all how do you secure it? Thank you soo much for your help in advance
Tom
Tom/// is offline   Reply With Quote
