Sponsored by BAVSOUND
Old 04-23-2004, 04:15 PM   #1
rdsesq
ouroboros autorotica
rdsesq's Avatar
My Ride: 2002 330i
A (probably) stupid sub mounting question...
So I see a lot of info on box specs for Subs, sealed and ported. However, I also see plenty of installs in mags of subs installed without boxes, (like face down in a fiberglass center console, like in the latest Alpine mini or Audiobahn "demo" cars) So what happens if you install a sub in openspace in your trunk?
As an example, I build a metal frame to mount the sub, but it is just that, a frame. and mount it in the trunk, what will happen to the sound quality, and why?
rob
"The existence of life is a highly overrated phenomenon."
-- Dr Manhattan
quis custodiet ipsos custodes
rdsesq is offline   Reply With Quote
Old 04-23-2004, 05:55 PM   #2
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Nope not stupid. I don't know the whole answer but part of it is that the sub depends on pressure to damp or control the movement of the sub. Otherwise it will self-destruct. That's why a sealed box can handle more power than a ported box because the internal pressure creates an opposing force. That's also why sealed boxes aren't as efficient as a ported box.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 04-23-2004, 06:13 PM   #3
breyton3er
My Ride: 04 M3
Send a message via AIM to breyton3er
I'm not positive but I think when they do a down firing sub there is still a sealed box its just the box is in front of the sub instead of behind it. Ported boxes have a tendency to have more of a boomy type sound. They aren't as tight as a sealed box but def louder. I think we need a professional on this topic.
MECP Silver
Cedia Level I
breyton3er is offline   Reply With Quote
Old 04-23-2004, 07:07 PM   #4
mnbmw
My Ride: 2001 330CI
Each sub will have an optimum mounting type, free-air (what you asked about), sealed or ported. Typically ported is louder, more efficient but is not as tight of sound. Sealed usually provides the tightest sound. Free air has the most flexible install but usually sounds the most muffled. I personally hate free air and really like tight sealed enclosure subs. Every sub should state the optimum install options. For example size of box, size and lenght of port. The most important thing is to match the enclosure and the sub. There are many subs that don't perform well in free air installs and there are a wide variety of similar size subs that have very different enclosure sizes.
mnbmw is offline   Reply With Quote
Old 04-24-2004, 09:44 PM   #5
djabaley
does anyone read my p0sts?
My Ride: 325 slushbox
breyton3er is the only one on track here
The subs still face into a sealed enclosure of the appropriate dimensions. Most serious subs cannot be run w/ any significant power in a free-air situation because, in a sealed box for example, the air pressure involved w/ a sealed box helps to keep the sub physically intact.
djabaley is offline   Reply With Quote
