Go Back   E46Fanatics > Tuning & Tech > Bavarian Soundwerks' Mobile Electronics Forum
Sponsored by Bavarian Soundwerks
Old 04-25-2004, 10:13 PM   #1
///NYCM3
My Ride: 2001 TiAg M3
Send a message via AIM to ///NYCM3
MY amp keeps cutitng out!!! please help
Whenever I have my system on volume for a little while, the interior speakers cut out. The subs still bump but my alpine-mdr 540 cuts out. I think it has something to do with the loc but would the loc cause this?
///NYCM3 is offline   Reply With Quote
Old 04-26-2004, 05:47 AM   #2
bimmer88
My Ride: 06 Lexus GS430
Send a message via AIM to bimmer88
sounds kinda like a loose remote/power/gnd wire.... check your connections...
bimmer88 is offline   Reply With Quote
Old 04-26-2004, 06:54 AM   #3
ca1242
My Ride: 2003 330i
... or a shoted wire/speaker, or overheating. If your connections are tight, disconnect one speaker at a time (both wires) and drive around for a day or two, that will help identify if a speaker is causing a problem.
Old 04-26-2004, 09:43 AM   #4
bearing01
My Ride: 02-E46/86-E30
Overload / Short?
Hi,
Amplifiers (power amplifiers) typically have an overload protection circuit that if you short out the amplifier load (speaker) the protection will kick in and steal the large current that would run into the short ... effectively powering down the amplifier. This could be your problem if you are shorting out your amp.
I have never had this problem before and I have never done the following. However, if I had this problem I would trouble shoot this as follows:
1. Remove one of the 12V supply lines (positive or negative) to the power amplifier and connect a multi-meter (on current setting) and measure the total current drawn by the amplifier.
2. Turn up the stereo and see the current rise. If suddenly the current to the amplifier drops when your problem occurs... it could be the amplifier powering itself down. This could be due to the short.
Good luck
bearing01 is offline   Reply With Quote
