Miscellaneous
Old 04-26-2004, 11:42 AM   #1
nzDave
My Ride: Darth Bimmer
12" Powerbook DVD-R Brand New $1450
Brand new, sealed box:
Full Description:
PowerBook G4 1GHz Power PC G4 Processor
12.1 TFT-XGA with 1024x768 resolution
256MB PC266 DDR SDRAM
40GB Ulltra ATA/100
256K DDR SDRAM Level 2 cache
NVIDIA GeForce4 420 Go with 32MB of DDR SDRAM
DVD-R/CD-RW SuperDrive(2x)
56K modem , 10/100 Base T
One FireWire, Two USB ports, VGA output port
Built in Bluetooth 1.1: Airport Extreme Ready
H: 1.18inch, W: 10.9 inch, D: 8.6inch, W: 4.6pounds
1 Year Warranty
Plus and additional brand new 256mb RAM installed or not installed
Additional info from Apple site:
Technical Specifications
Processor and memory
***149; 1GHz PowerPC G4 processor with Velocity Engine
***149; 512K SRAM on-chip L2 cache
***149; 133MHz system bus
***149; 256MB of PC2100 (266MHz) DDR SDRAM; one open
SO-DIMM slot; support for up to 1.25GB
Storage
***149; 40GB 4200-rpm Ultra ATA/100 hard drive5
***149; One of the following optical drives:
***150; Slot-loading Combo drive (DVD-ROM/CD-RW):
reads DVDs at up to 8x speed, writes CD-R discs
at up to 24x speed, writes CD-RW discs at up to
10x speed, reads CDs at up to 24x speed
***150; Slot-loading SuperDrive (DVD-R/CD-RW): writes
DVD-R discs at up to 2x speed, reads DVDs at up
to 8x speed, writes CD-R discs at up to 16x speed,
writes CD-RW discs at up to 4x speed, reads CDs
at up to 24x speed
Communications
***149; Built-in antennas and expansion slot for optional
54-Mbps AirPort Extreme wireless networking card3
(based on 802.11g standard; Wi-Fi Certified for
802.11g and 802.11b interoperability)
***149; Built-in Bluetooth
***149; Built-in 10/100BASE-T Ethernet (RJ-45 connector)
***149; Built-in 56K V.92 modem6 (RJ-11 connector)
Expansion
***149; One FireWire 400 port at up to 400 Mbps7
***149; Two USB 2.0 ports at up to 480 Mbps
nzDave is offline   Reply With Quote
Old 04-26-2004, 02:29 PM   #2
The 330i
My Ride: 330i
Hello nzDave,
Full Description:
40GB Ulltra ATA/100
1 Year Warranty
Storage
at up to 24x speed
Communications
Expansion
I want to let you know that if you purchased your PowerBook less than a week ago, you may be able to return it. [As you may know, your model is discontinued, and there is a new model for a similar price - if not cheaper.]
The 330i is offline   Reply With Quote
