Sponsored by BAVSOUND
Old 04-27-2004, 10:50 AM   #1
Blazin e46
My Ride: 323Ci
Send a message via AIM to Blazin e46
Can someone explain the concept of a mono class D subwoofer amp?
These mono class D subwoofer amps.....can they power multiple subs or just one sub? If for example its rated at 1200X1 @ 1ohm what's the deal with that? YEA YEA, I know, I suck when it comes to car electronics, Im just trying to figure out the best AMP route to go with , for a setup that has 2 kicker s12L7 subs.
Any suggestions/explanations?
Thanks in advance
BLaZiN e46
Blazin e46 is offline   Reply With Quote
Old 04-27-2004, 03:59 PM   #2
ca1242
My Ride: 2003 330i
Thanks in advance
You can use as many subs as you want, as long as their total resulting impedance is 1 ohm at the final connection point. For example, if you use 2 kicker subs, and each sub has a dual 4-ohm voice coil, you connect both coils from both subs together (parallel) to the amplifier and get 1-ohm.
For a more detailed explanation (I hope I didn't confuse you), go to my website http://home.comcast.net/~customcarstereo
