Thread Tools Search this Thread Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Old 05-19-2004, 10:13 PM   #21
bbh03
My Ride: M5, X5, 911SC
Originally Posted by Alan L.
When you guys take the water pump out, does tons of coolant come pouring out?
Also, I noticed that most "oem bmw parts" site actually sells water pumps manufactured by Graff and other companies..... I'm wondering if its better to just get oem bmw made pumps or one of these other brands. Doesn't seem like the factory pumps lasts that long but i've also heard that some aftermarket pumps making weird noises once installed. What do you guys think?
Alan
Drain the coolant from the block first
bbh03 is offline   Reply With Quote
Old 05-19-2004, 10:15 PM   #22
darth
My Ride: 323i
Originally Posted by bbh03
Did you have a problem torquing the bolts on the water pump pulley? I was installing pulleys today and one snaped I think under less than 15 ft/lbs of torque. I have to check tomorrow but I hope the bolt snapped and not stripped threads in the water pump rotor or els Ill be doing the same thing as you soon
bbh03,
i had a little trouble cuz i didnt have a tool to hold the pulley. i just had my friend hold the pulley real tight while I cranked on it with a torque wrench (89 in-lb per Bentley Manual). I don't think I torqued it all the way but it seems good. I'ld be careful with the pulley cuz it plastic so you might crack it if you over tighten it.
hope this helps. good luck.
darth is offline   Reply With Quote
Old 05-19-2004, 10:19 PM   #23
darth
My Ride: 323i
Alan
I only drained my radiator and when i pulled the pump of only about a cup or so came out.
as for the aftermarket stuff, don't know. i did get my pump from Pacific for $63.
Old 05-20-2004, 12:53 AM   #24
tim330i
E46Fanatics Owner
tim330i's Avatar
My Ride: 03 Ti Silver M3
What are the signs that the pump is going bad? I have a rather quite but noticeable grinding sort of a sound while the car is idling. If I tap the throttle it quites, but comes back at idle.
Thoughts?
Tim
tim330i is offline   Reply With Quote
Old 05-20-2004, 10:25 AM   #25
markusmark
My Ride: 2001330Ci
Water pump
Tim,
If yo've got more than 40K miles on your ride, and it's making noises, change the pump.
It also might be a good idea to change the thermostat and the thermostat housing at the same time you change the pump. Seems that's what the local dealer (Fairfax [VA] BMW) did when my pump went at 40K miles.
markusmark is offline   Reply With Quote
Old 05-20-2004, 11:15 AM   #26
mcabr
Just Marinatin'
mcabr's Avatar
My Ride: Chikatetsu
lijasdfl
Alan
Alan,
I just replaced mine yesterday and I had bought an OEM one and a Graff one. I compared the two side by side and they were identical as far as I could tell. The graff one was brand new but when I returned the OEM one to the dealer they referred to it as "one rebuilt water pump" I was like what? Rebuilt? Why does it cost 87 bucks then? They other one only cost me 60 bucks and so far it is working fine with no funny noises.
Oh I forgot to add that the graff pump seemed a little sturdier than the OEM one. Like the parts seemed to be made of more quality material. The OEM one seems to be made of a different type of plastic that seems cheaper than the graff one.
mcabr is offline   Reply With Quote
Old 05-20-2004, 11:28 AM   #27
Alan L.
TWC Alumni
Alan L.'s Avatar
My Ride: AW M-Sport
Awesome! I think i'll go with the graff one instead since the bmw one isn't exactly bullproof. I've heard premature waterpump failures is common with bmws
2015 F15 M Sport |||More Photos of my X5 here||| -F85 X5M Incoming....
Alan L. is offline   Reply With Quote
Old 05-20-2004, 12:48 PM   #28
RushRacer
Registered Abuser
My Ride: '02 330Ci
Tim, waterpumps generally have a weephole or two, usually a 1/8th or smaller hole just behind the pulley. These are designed to release coolant that has passed the impeller and the internal seals. Small drops of coolant under the car would be the most obvious sign, but looking at the pump on the car would be the best. Check for signs of leaking coolant to determine if the seals are going bad. Keep in mind however, that signs of leakage might be normal, a consistent dripping is not. Next would come the grinding noise. Generally, the noises are caused by the failing bearings on the impeller shaft. I can't say if it's the noise that you're experiencing, but again, I suggest sticking your head in the engine bay while its running to pinpoint the noise. Just start with your ear as close to the pump as possible and you might just confirm the problem immediately. Shortly after the noises start you may experience a large loss of coolant, and then total pump failure, leading to possible engine damage.
I love you, Brian Fellow.
And I love your hat, Rufus.
RushRacer is offline   Reply With Quote
Old 05-20-2004, 01:31 PM   #29
bbh03
Originally Posted by darth
bbh03,
Thanks, Darth, I dont have to worry about the pulley because I replaced it with an underdrive pully which is aluminum. I didnt torque them all the way either because I pussied out when the one bolt snapped. I think the bolt just snpped, not a stripped thread in the water pump pulley bracket, so I bought new bolts (M6x16). Can anyone verify the material that bracket (that you bolt the pulley to) is steel and not something soft like aluminum??? Im going to remove it tonight and hopefully correct the problem.
BTW guys, pelicanparts sells the water pumps for only $54, the best price Ive seen so far.
Old 08-02-2005, 12:48 AM   #30
EDawg
My Ride: :/
EDawg is offline   Reply With Quote
Old 08-04-2005, 10:48 AM   #31
328idriver
behind blue eyes
328idriver's Avatar
My Ride: 328i
Send a message via AIM to 328idriver
sometime at idle i get a knocking sound from the engine compartment usually..its very intermittent it comes and goes, seemingly with no regularity,the car is a 328i and its got 90,000 on it very good condition very well maintained, im wondering if the water pump is going? no leaking coolant that i can see,normal operating temps, but occasional knocking that isnt loud like engine knock and it comes and goes so its not like my motors about to go, it hasnt happend in like 1 month and yesterday it happend again wonder if the bearing in the pump are shot... No obvious clues, can someone shed some light and let me know more about the sound that a failed waterpump would emit. thanks-
Joe
328idriver is offline   Reply With Quote
Old 08-04-2005, 12:16 PM   #32
Canuck328i
My Ride: 09 Altima Cpe
Joe
I get a knocking sound at low RPM from the AC compressor - AC still works, but it makes one hell of a whacking sound at 800 to 1200 RPM. It will only happen when the AC button is on, so if you hear the noise try turning off the AC to see if it goes away.
From what I've heard, the WP will make more of a grinding noise when the bearings are going bad.
I will be doing the WP tonight or Saturday, parts are coming in tonight. BMW wants $160 plus $50 core charge, local auto parts store wants $90 plus $20 core charge (CDN) and they are BOTH rebuilds.
Has anyone seen an E46 WP with a plastic impeller (either the old one from your car or the new one)? Didn't they have problems with these in the E36?
Mark
Canuck328i is offline   Reply With Quote
Old 04-18-2006, 08:17 AM   #33
g911turbo
My Ride: 2001 330ci
Great DIY thanks.
Might I add that on an AUTO 330CI (with fan clutch) the fan and clutch are a PITA to get off without the bmw (or like) holding tool. My clutch was all rusty and seized, and I tried to get it off by wedging something in between the pulley bolts and ended up BREAKING my waterpump pulley in half
My holding tool is on order and meanwhile my 3.0L is out of commission
g911turbo is offline   Reply With Quote
Old 04-18-2006, 12:33 PM   #34
nEVERCLEAR
My Ride: 323
Thoughts?
Tim
Sounds like more of a idle tensioner then a waterpump.
Take a ling screwdriver or stethescope and and tough the water pump and the idle tensioner being careful f the fan and belts.
They should not have a clunking sound at all more of a muffled bearing spinneing sound under water.
I changed the waterpump first and it ended up being the idle tensioner.
Thinking about a Honda or VW Dont buy from East Coast Honda - VW Read about my experience here
Some people dream of speed-others create a damn jet powered shopping cart.
Curious about VoIP and Vonage click here
nEVERCLEAR is offline   Reply With Quote
Old 04-20-2006, 10:33 AM   #35
g911turbo
My Ride: 2001 330ci
Well, I still can't get the fan clutch off of the water pump, it's seized so bad its not even funny (i've sprayed in numerous times with PB Blaster).
Also, when I spin the clutch, it wobbles and doesn't spin perfect. I'm assuming this means the water pump bearings are bad. Can anyone verify this? This might also explain the slight groaning/droning noise from the fan area on cold idle before - lack of balance...
Therefore, im just going to disconnect the water pump with the clutch still on and chuck the whole thing. New pump, pulley, and fan clutch for about $150 and no more guessing. I'm thinking I should change the belt too, but it was changed less than 20k ago and does really look that bad (just some coolant and/or WD-40 splashed here and there)
Old 04-20-2006, 10:48 AM   #36
nEVERCLEAR
My Ride: 323
Go ahead and change the belt. It's not expensive and you will likely never have to change it again, If I was doing it I would change the idle tensioner as well. It is around 40.00. You can probably get the fan off once the water pump is off. How will you get to the pump bolts that go into the block with the fan on?
Old 04-20-2006, 12:57 PM   #37
g911turbo
My Ride: 2001 330ci
Actually, the fan is off... I was able to dismount the shroud and fan from the clutch. The clutch is mounted to the water pump, and THAT is what seized up...
I think I have enough clearance between the radiator, etc. and the fan clutch to pull out the water pump with the clutch still attached. if not, I'll probably just cut off the clutch at the bolt (PITA) then pull out the pump.
I keep telling myself it's not that expensive, but when you do that and combine things it really starts to add up. This all started out with me JUST changing the clutch, resulting in me breaking the pulley, needing to change the pump, and now the belt, etc.
This is what happens when a simple job goes wrong...
$150 and climbing... uff.
Also, what do you mean by idle tensioner?? Does this part go by a different name? cause I'm not really sure what you're referring to...
Old 04-20-2006, 01:29 PM   #38
nEVERCLEAR
My Ride: 323
It is the part looking at the engine to the righ near the power steering that you move to remove the belts. Some are known to go bad and will make a noise at idle like a rattle. Most people change their water pumps and when the nosie doesnt go away they end up changing the belt tensioner. THere are 2 kinds Mechanical and hydraulic. I think the mechanical one goes bad.
I can't help you identify them, and I dont know which one goes bad more often. Do a search to see if you think you need to change this part.
I just bought an 87 Wrangler so I know all about the simple fixes going wrong and costing a couple dollars
Old 04-20-2006, 01:45 PM   #39
g911turbo
My Ride: 2001 330ci
yeah, most fixes would be easy on a new car... but when you add in rust, seized bolts, brittle metal, etc., sh*t hits the fan REAL quick
thats why when i reinstall my pump, pully, and clutch im using anti-seize on the bolts - and PB Blaster to get them out so they dont crack
So I AM assuming here that if I spin my clutch still attached to the pump and it wobbles, as in doesn't spin perfectly, that the bearings on the pump are going right?
Old 05-28-2006, 05:03 PM   #40
Cobra
My Ride: '00 328i & '06 R6S
would anyone happen to have a writeup on how to change the water pump on an automatic car? that damn clutch fan is in the way
Cobra is offline   Reply With Quote
