Old 05-30-2013, 02:39 PM   #1
vbfronkis
My Ride: 2001 325iT
Engine chatter
So at idle, I've got a bit of a "chatter" in my engine and I'm not sure what it is. I made a video so you could hear it.
It sounds like it comes from the front of the engine around where the pulleys are so I don't know if it's that I've got a tensioner that needs doing. Don't think it's VANOS because that sounded different and I had the seals re-done a year ago.
Thoughts? Thanks!
2001 325iT, manual
vbfronkis is offline   Reply With Quote
Old 05-30-2013, 04:43 PM   #2
David McMahon
My Ride: '99 E38 740iL
You could always (very temporarily) remove the belts and see if noise still remains, that will at least rule out Water pump, PS pump/ tensioners /Alt/ AC Comp etc. Remember no water pump is BAD! So only do for a very short while
David McMahon is offline   Reply With Quote
chatter, chattering
