Rating:
Display Modes |
#41 |
Hi fanatics,
Cary : thanks for the wirte up! I contacted BMW customer relations and asked what oils besides the factory brand are acceptable for use. Keep in mind I have a 2000 328i. The answer: "Castrol Synthetic, Mobil 1 >Synthetic, and Valvoline High Performance Synthetic with a weight of SAE >5W-30 are also approved by BMW, however, these oils are not formulated for >15,000 miles between oil changes like the BMW High Performance Synthetic >engine oil. " But he recommended the BMW synthetic as best choice. I take my car in for all the services as per the computer, every 15k miles and get oil service, where I get BMW oil, but I do my own home oil change in between, at 7500 mi, where I put 5W30 Mobil 1. oops! My car got 5W30 2 times so far, but in the future I am switching to 0W40!!! Weird thing though, I went to the oil application page on the mobil1 site and they suggested 0w-20, 10w-30, and 0w-40 as being okay.
2000 328i
SuperSprint Exhaust |
#42 |
Cary, this is fantastic info....clears up alot of the wives tales about oil...greatly appreicate it.
Where can I purchase the oil filters for a 2000 BMW 328Ci? |
#43 | |
2000 328i
#44 | |
The claims of 35,000 miles are far overplayed. There are many caveats, including regular filter changes during that period, that the car is not operated in severe operating conditions, including much stop and go and cold starts. From the Used Oil Analysis I have seen, Amsoil is capable of turning in low wear numbers for long change intervals (15,000-20,000 miles), the biggest issue being that Amsoil tends to thicken out of grade during extended oil changes. Personally, I believe that Mobil 1 products are of equal quality (guess where Amsoil buys their base oils from!!!) and cheaper. I would not recommend using either oil much longer than 10,000 miles without getting a used oil analysis to determine how the oil is holding up for your application and driving style. Redline is a different oil than Amsoil. Where Amsoil is focused on extended oil changes, Redline has traditionally focused on racing. Redline used Group V Polyester base stocks (compared to Mobil and Amsoil using Group IV Polyoflin stocks) which arguably are better stocks for supporting additive packages. Redline also uses very high levels of Moly in their oil which will provide a margin of protection should there be oil starvation (i.e. high cornering loads, oil pump breaks, oil line breaks). Redline's chief engineer used to work for Luberzoil, the primary manufacture of oil additives used by nearly all oil companies. He is well respected as an lube engineer. Note that redline makes race and street oils, the race oils lacking the needed addtive package for long term use (more than a month or so). Finally, in terms of used oil analysis, Redline turns in numbers from amazing to so-so. Terry Dyson who performs a great deal of oil analysis and testing for oil manufactures, fleet vehicle owners, etc., however swears by Redline. As a quick seperate note, oil life is a function of many variable including, but not limited to 1) oil quality, 2) driving conditions, 3) engine design, and 4) engine oil capacity. I have seen oil analysis on the M50 series BMW engines where the factory BMW Synth 5w-30 has been just about used up at 7500 miles, and others where the same engine design and same oil have held up pretty well to 14,000 miles. Cary |
#45 | |
Cary |
#46 | |
As far as BMW's own oil being adequate for 15,000 mile oil changes, perhaps they should look at the used oil analysis that come from motors run that long, the condesation and brown crud that comes from running their oil that long, and the horrible sounding drivetrain and obvious sludge buildup after 100,000 miles from using their oil at 15,000 mile intervals. Yes, they do have extra addtives from the standard Castrol Syntec, the the oil is nothing special and does not reliably make the 15,000 mile interval. Cary Hey, I got on the Mobil site, their recommendation of 0w-20 for all temps is flat out wrong. If you read the bottles it even says it is designed for honda and for applications calling for 5w-20. Once again an example of bad information floating around. Look for that A3 or BMW LL-01. Last edited by cary1; 05-28-2004 at 10:39 AM. |
#47 |
WOW, so much info my head is going to explode.
So can anyone who understood all of this tell me iz Mobil 1 0w-40 the absolute best for 2000 328Ci. (I live in Mass as far as the climate). |
#48 | |
There I was, Sicily, 1918..
Incidentally, great write-up!
#49 | |
The rumors are exactly that, rumors. Mobil 1 is still a Group IV and considering Mobils investment in Group IV will likely continue to be. The following if from Mobil 1's website, and unless they are lying!!! What is Mobil 1 and why is it now called Mobil 1 with SuperSyn™? Mobil 1 is a fully synthetic motor oil for automotive engines. It is made from a unique combination of high-performance fluids, including polyalphaolefin (PAO), plus the SuperSyn™ anti-wear system for protection under the most extreme use. Mobil 1 with SuperSyn™ is available in five viscosity grades: * Mobil 1 with SuperSyn™ 10W-30 – Higher-Mileage Vehicle Formula * Mobil 1 with SuperSyn™ 5W-30 – Newer Vehicle Formula * Mobil 1 with SuperSyn™ 15W-50 – Performance Driving Formula * Mobil 1 with SuperSyn™ 0W-30 – Enhanced Fuel Economy Formula * Mobil 1 with SuperSyn™ 0W-40 – European Car Formula Mobil 1 with SuperSyn™ is truly a global formulation, exceeding the latest standards from the government, the oil industry and vehicle manufacturers. For instance, the appropriate grades of Mobil 1 with SuperSyn™ exceed ILSAC GF-3, API Service SL/CF, European ACEA standards and Japanese valvetrain requirements. In addition, some viscosity grades exceed specific OEM standards. One example is Mobil 1 with SuperSyn™ 0W-40, which exceeds Mercedes Benz's 229.3 specification. As a CF rated oil, Mobil 1 with SuperSyn™ can also be used in diesel engines calling for a CD oil. Cary |
#50 |
My Ride: A Benzo with an "H"
awesome stuff cary
but I'm still sticking with the 15k/1yr service interval. |
#51 |
So whats the deal 5-30 Mobil Supersyn or 0-40 Mobil. I'm due for an oil change soon. My dad's Porsche gets 0-40 (its pretty expensive). Where is the cheapest place to get it? ??
I can get a case (6 qts) of 5W30 Super Syn Mobil I from Costco for $23.
2004 330Ci 6-Speed
Titanium Silver/Black PP, SP, CWP, Xenon, UUC Sways, EVO3, TSE3, 3.46 Diff, BFP Front Strut, 18" CSLs |
#52 | |
Cary,
I work in the lubricants industry and want to comment on a few of these items. There is nothing wrong with using the 5W-30 Mobil 1 oil if you are concerned about the ACEA requirements. It is an ACEA A5 oil which adds ontop of A3's requirements with fuel economy. The engine oil manufactuer/lubricant additive company must prove that the oil proves fuel economy over a base oil. Its quite possible that other oils also meet this, but this is another costly certification that they may not choose to run for all oils. All certifications cost money. The additive packages you get in all the mobil 1 grades is not going to vary performance wise. they dont make the 0-40 better than the 5W-30 by adding more anti-wear, dispersants or detergent additives. Also i think you were concerned about the weights of the oil. The company cannot brand the oil at a 5W-30 unless it meets certain viscosity ranges. I highly doubt your going to experience substantial engine wear if you are 2 cst off of the BMW target but you have a great additive package (which mobil 1 does). Its the additives that do all the protection. Lastly about using oils not from major companies... I really would not recommend it. Companies like ExxonMobil and Castrol actually do a lot of engine testing and are very involved in selecting the best additives and making sure the package works together well with the oil. They spend lots of money to get approvals. The smaller companies cannot do all this testing and get so involved with fine tuning the oil. They buy a good base stock but what about the additive package? Theres a lot of science that goes into makign a good additive package and i doubt if they a lot of times have the resources to develop one. Often times a lot of these packages are the same ones used by a big name company just stuck in a different base stock with no testing. You dont see formula one cars running around with joe schmoe oils in them now do you? Bottom line, anyone using 5W30 Mobil 1, dont worry about. your engine is going to last a long long time and i wouldnt change a thing. -Jeff Quote:
#53 | |
My Ride: some hooptie
anyone? |
#54 | |
If you need to add oil I would think it best to add the same type of oil as whats in your car right now. My guess is Castrol Syntec 5W-30.
2005 Imola Red 330i 6MT, ZHP, ZCW, Xenons
Previous: 2007 Mystic Blue 530i 2003 Gray Green 330i 2003 Electric Red 325iTa Nice guys finish last. And I'm a very nice guy... -Jay ![]() [IMG]Under construction[/IMG] |
#55 |
![]() I don't know what to believe anymore. I've been doing filter changes and top offs at 5k between the service intervals. I actually once scheduled an oil change and the dealership told me I wasn't due for one. I told them I would pay for one and they told me it was unnecessary and silly. Fortunatly, because of random luck, the longest any oil has ever been in my engine is 10k miles. But, whatever. I guess I'll start changing the oil at 7500k miles between intervals if that's the recommendation of the day. |
#56 | |
So is the one BMW sells a BMW - Castrol Synthetic 5W-30 oil? |
#57 |
I've never actually changed the oil @ BMWs 15K mark, the computer seems to tell me I need a change ~12K or so. Anyhow, is that computer accurate? How does it decide.
Also, My Xi seems to need a qt of oil every 4-5 month. Based on this, I should be able to ride out the 12K-15K change intervals right? Cuz I'd have about 3-4 qts added, that pretty much have replaced all the "old" oil. ![]() I used to change every 3K, but I used organic oils then (non-bmw). With synth. people tell me that since the oils don't change shape etc, 10k-15k should be ok.
2005 M3
Silver Grey|Titan Shadow Trim|NAV|Moonroof|NAV|PDC|Rear Sunshade|Power Seats|Lumbar|HK|Xenons|Heated Seats Bluetooth ULF|OEM Sirius Radio|ZR3+8500 X50|Body colored reflectors|Door lock delete|ZCP wheels + Toyo T1-R|Alpine MP3 6 disc changer|AUX|UUC EVO3 SSK|OEM CSL Bootlid|Euro split mirror glass|Vorsteiner Full CF CSL Defuser |
#58 |
so guys is it okay to top off with mobil1 0w-40 or should i top off with the same kind of oil thats already in the engine?
also...when I go in for the 15k mile service, can you request what oil to use? thanks guys! |
#59 |
wha whaa whaaa
Great write up man!
Make GREAT decisions. All the time.
#60 | |
I tried to post the chart but it won't so here is a link: http://www.lubrizol.com/ReadyReferen...es/default.asp You should know who lubrizol is, since you probably buy your additives from them. On the right of the page you can pull up the ACEA specs which clearly show the diff between A1, A3 and A5. In reference to your comment about 5w-30 being only 2cst thinner, note that it 1) is A5 rated, not A3, because it has to low of an HTHS, 2) BMW's own oil is A3, and 3) the only oil that Mobil 1 makes with BMW LL approval is the 0w-40. Small oil companies- Note that I disagree about the quality, redline and amsoil make great products. I agree with sticking with Mobil because if you have an engine failure, however unlikely, BMW will not be able to say it was becasause you used a non API rated oil. Cary |
