Old 06-01-2004, 12:50 PM   #1
ADA
Banned
My Ride: 323ci
transmission fluid/oil and filter?
Guys,
How often do we have to change our transmission fluid and/or transmission oil? Does our transmission have a filter that also need replacement?
Any insight would be greatly appreciated.
Thanx
ADA is offline   Reply With Quote
Old 06-01-2004, 12:52 PM   #2
AceDaKing
Chilly Willy
My Ride: 2013 M5, 10 M6,08 M5
Send a message via AIM to AceDaKing Send a message via Yahoo to AceDaKing
i heard you not supposed to change the transmission fluid....
My pistol game been tight since chicken low mein and rice
AceDaKing is offline   Reply With Quote
Old 06-01-2004, 01:08 PM   #3
ADA
Banned
My Ride: 323ci
AceDaking,
Yeah, I heard something in that effect also. How about the transmission filter then??? Do you know anything about that?>
Old 06-01-2004, 01:23 PM   #4
bbh03
My Ride: M5, X5, 911SC
Transmission oil is supposedly a lifetime fluid. However, I change mine about every 2 years for my MT. I dont know what the story is for auto though.
bbh03 is offline   Reply With Quote
Old 06-01-2004, 01:52 PM   #5
SkipII
My Ride: 2001 330 Ci
trannies filled with crock
As with everything on BMW maintenance, if you really care about keeping it for a long time, ignore their "recommended" intervals and change all fluids more often. There is no harm done in replacing it, and invariably more harm done eventually in keeping the stock fluid for too long.
I would suggest the auto trans fluid be changed somewhere in the 50-60K (or 4-5 year) range.
The fluid filter is cleaned, not replaced. It is a fine mesh screen. Buy a Bentley if you plan to do it yourself.
Hope that helps.
SkipII is offline   Reply With Quote
Old 06-01-2004, 01:58 PM   #6
InSuboRdiNaTioN
Mmm, Pancakes.
InSuboRdiNaTioN's Avatar
My Ride: Collects dust.
"Lifetime Fliud" = For the life of the tranny. Modern trannies are only built for a service life of around a 100k miles. If treated properly they can obviously last longer.... and new fluid every 60k or so would definately help
Originally Posted by vincentvega9701
one moment, you're rolling. the next, you're blowing a guy for a sandwich
InSuboRdiNaTioN is offline   Reply With Quote
Old 06-01-2004, 01:58 PM   #7
guest1008
Banned User
My Ride: 08 Lexus ES350
BMW's definition of "lifetime" is 100,000 miles. If you plan on keeping it longer than that, get it changed much earlier. 30,000 to 50,000 is a good time. 30K if you're paranoid (hey, it's relatively cheap insurance). 50K for most people.
Manual trannies might be earlier. Supposedly it helps with the shifting feel so maybe you wanna do it every 30K just for that.
guest1008 is offline   Reply With Quote
Old 06-01-2004, 02:03 PM   #8
ADA
Banned
My Ride: 323ci
THANX for everyone that replied to this thread.
ONE QUESTION THOUGH:
What about our transmission filter? Someone told me about this. Is there really a thing in our car?
Old 06-01-2004, 02:10 PM   #9
InSuboRdiNaTioN
Mmm, Pancakes.
It's a metal screen that is a strainer that you just clean off. I can send you the service manual instructions via e-mail if you have broadband.
Old 06-01-2004, 02:18 PM   #10
InSuboRdiNaTioN
Mmm, Pancakes.
Our ZF transmissions only take a special type of fluid... Texaco 8072B. I'm looking all over the net to see if there are any other manufacturers who make a fluid that conforms to this spec, with no luck. Anyone know where I could find some? I'd much rather put Amsoil or Redline in...
Old 06-01-2004, 02:38 PM   #11
ADA
Banned
My Ride: 323ci
You got PM =)
Old 06-01-2004, 02:49 PM   #12
CtrlAltDel
www.piratecove.org
My Ride: 2007 335i Coupe
Send a message via ICQ to CtrlAltDel Send a message via AIM to CtrlAltDel
i change my tranny and diff fluid every 25k
just clean the screen for tranny if at all
hf
Yeah I havent updated my sig yet with my 335, kill me.
CtrlAltDel is offline   Reply With Quote
Old 11-05-2008, 06:03 PM   #13
TedPre
My Ride: 2003 325i and 1990 5
I have a 2003 325i auto trans and I cannot see a fill plug or drain plug?...So I can't change my fluids. I would like to though If I can access them. Also I think there's a temperature requirement that you need to watchout for during the process. any comments on this?/
Appreciate any info.
thanks
TedPre is offline   Reply With Quote
Old 11-05-2008, 06:31 PM   #14
Androo
My Ride: Has 4 wheels
I'd never touch changing my transmission fluid, my opinion on that is if it ain't broke don't fix it.
I've heard to many stories of issues after changing the transmission fluid, including complete failure of transmission/gearbox... FK THAT, leave it.
Androo is offline   Reply With Quote
Old 11-05-2008, 08:17 PM   #15
K:^P
My Ride: 00 323//65 Fastback
http://forum.e46fanatics.com/showthread.php?t=438667
The fill hole is on the driver side(US). See if you can remove it first before the removing the drain plug.
There is some spec on the car needing to be level, warm up, shifted around, and then fill until it slip out of the fill hole. Another way, if I drained 5 qt. I'll put back 5 qts.
K:^P is offline   Reply With Quote
Old 11-05-2008, 08:23 PM   #16
Alex323Ci
My Ride: M3 & 323Ci (sold)
Holly thread revival batman
And one where the member is banned none the less. bonus points.
Old 11-05-2008, 09:35 PM   #17
samBROchill330i
My Ride: Dinan 330i
my guess is your fluid is BEGGING you to "fix it" although it wont scream "im broke"...change it if you can, but not if you're over 60k...too late
and sick thread revival. wtf
Performance: Dinan Stg 3, Dinan Perf Tranny Software, Dinan High Flow Throttle Body, Dinan High Flow Intake, UUC TSE3~TMS Power Pulleys
Suspension: Eibach Sportlines, Koni Sports, Ground Control RSMs, Dinan Strut Brace, Eibach Sways, Ground Control Endlinks, Poly RTABs
Exterior: Painted Kidney Grille, BSM Roundels, Clear Sides, Corners, & Tails, 3M Tint 20% Rear, 35% Front, Halogen to P46/AE
Wheels: Staggered 19" V710s on T1Rs
samBROchill330i is offline   Reply With Quote
Old 11-06-2008, 12:35 AM   #18
nleksan
My Ride: 328Ci, 325i, M3 ZCP
Send a message via AIM to nleksan
If you have a manual transmission (I have a 328Ci 5-Speed Manual), can I change the tranny fluid at 97k miles if it's never been changed before? What about the differential fluid? I'm not talking about a "flush", just a drain and fill. Thanks.
(Temporary Sig)
- DPE - Volk - BBS - OE CSL - JRZ Race 4Way -
- M-Tech II - RE - AP Radi-CAL -
- Hotchkis - AFE - AKG - KW CS 4way -
- TMS - OS Giken - SS V1 - Vorsteiner - Recaro - Focal - JL - MORE! -
GARAGE:
-00 328Ci Topaz 6MT ZSP/ZPP/HID (Street) ESS TSE2+ 2980lb
-01 325i TiAg 5MT/ZSP/ZCW (Street) Track Susp/Brk/Whl 3102lb
-06 M3 AW/IR 6MT/ZCP/HID (Dual-purpose) NA Fully-Built 2810lb
nleksan is offline   Reply With Quote
Old 11-06-2008, 12:42 AM   #19
Alex323Ci
there are no issues with changing the diff or manual tranny fluids. easy to do.
it's only the automatics that are known to be hit or miss.
Old 10-16-2011, 10:13 PM   #20
jbehr99
My Ride: 2005 330CI Vert ZHP
I have a 330ci with 62000 miles on it. Is it ok to change the tranny fluid and differential fluid. They have never been changed before
jbehr99 is offline   Reply With Quote
