Old 07-16-2002, 06:46 PM   #1
puyerplaya
Angry PLLLEEEASE! someone help me put my headlight back together quick
Well i took apart my headlights on my coupe, removed the trim, painted it, let it set for a few hours, put the insert back in, now im having trouble putting the plastic headlight cover back in. It goes in just fine, and I'm able to secure the 3 tabs on the top, 1 tab on the side, but im having a **** load of a hard time securing the lower 3 tabs, specifically the one closest to the corner lamp. Anyone else have this problem? The other 2 I can secure but its a serious pain in the ass, and i keep removing it thinking im putting it in wrong....HELP!
puyerplaya is offline   Reply With Quote
Old 07-16-2002, 06:59 PM   #2
Dev
PSHOPWERKS
My Ride: Yellow Porsche GT2
This is what I did: I did the bottom clips first. The top is easier as you have more access/clearance to use more force. It was a bit tough, but it should go back in. Try that and see.
I used a flat-head screwdriver to help "lock" the bottom clips (while pushing in the cover).
PSHOPWERKS
Mods: 1 Inch Nail in Tire | Purple painted calipers (you know you like Purple calipers)
Current Hate Level: 10 | Previous Hate Level: 9
The hatin' level on the E46Fanatics.com board.
Dev is offline   Reply With Quote
Old 07-16-2002, 07:12 PM   #3
lyon123
I holla
My Ride: AW 325Ci
Re: PLLLEEEASE! someone help me put my headlight back together quick
if ur still having problems w/ it just take the whole headlight out...it makes it 500X easier toput the plastic back on and it only takes 10 more minutes for the headlight removal and replacement.
lyon123 is offline   Reply With Quote
Old 07-16-2002, 07:13 PM   #4
lilherc79
"DPErt-ASchnizA-*****"
My Ride: ASA ACS 3.0 Cabrio
the clips should glide in with ease. when i did mine, i lined them up together and just pushed in until i heard the click. No problems what so ever.
lilherc79 is offline   Reply With Quote
