Jack/lift points for 325i - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 31 votes, 5.00 average. Display Modes
Old 07-08-2004, 03:48 PM   #1
aa325i
My Ride: BMW
i know the car has the black little pads on each side of the car to raise it, but would like to know when u jack it up can u place the jack stands (for the front of the car) on this rail/beam about a foot inside from the pads on the side. it looks like it is right next to the floorpan. it is like a long beam that runs almost close to the rear seats.
aa325i is offline   Reply With Quote
Old 07-08-2004, 05:24 PM   #2
cgrizzly888
My Ride: 00 328i
Send a message via AIM to cgrizzly888
Are you referring to the subframe?
cgrizzly888 is offline   Reply With Quote
Old 07-08-2004, 05:42 PM   #3
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
The best way to put E46's on jack stands is to jack it up from the front and back and slip 4 jackstands under each of the black pads...
I jack the front up by using that little dot that is just behind the dust pad in the front.
The rear, I use the rear differential...
Old 07-08-2004, 05:45 PM   #4
truwon
2 point five 3 two 3 i
My Ride: .2000.323i.
Send a message via MSN to truwon
I heard its not good to jack from the rear diff.
there is a U brace right by the diff that you can jack the rear up from
edit: heres a pic
truwon is offline   Reply With Quote
Old 07-08-2004, 05:55 PM   #5
tim330i
E46Fanatics Owner
tim330i's Avatar
My Ride: 03 Ti Silver M3
Correct, the diff is mounted with tabs and you could break a tab off the diff, much better to jack from the subframe as shown.
Tim
tim330i is offline   Reply With Quote
Old 07-08-2004, 08:06 PM   #6
Edison@JleviSW
1.888.JLEVISW
My Ride: BMW Duh
Good to know
Old 07-26-2004, 07:01 PM   #7
pyo
My Ride: Z4 3.0i '04
Send a message via AIM to pyo Send a message via MSN to pyo
where do you jack from the front? If anyone can provide a picture would be nice. Thank you
2000 328i [Sold]
2004 Z4 3.0i 6spd
pyo is offline   Reply With Quote
Old 07-30-2004, 10:41 AM   #8
PDACPA
My Ride: 03 Dinan M3
Bump for the front jack point. Thanks for the rear picture. Very helpful.
"It's nothing personal, it's just business."
2014 BMW 435i M Sport Vert (Black)
Carrera 911 Guards Red (Garage Queen)
2003.5 BMW Dinan M3 (Black)-Sold
2002 BMW Dinan 330Ci (Steel Gray) - Sold
PDACPA is offline   Reply With Quote
Old 07-30-2004, 11:07 AM   #9
pyo
for the front jack point too
2000 328i [Sold]
2004 Z4 3.0i 6spd
Old 07-30-2004, 12:07 PM   #10
HyPeR3eR
Banned
My Ride: 330i
FRONT:
For the 1999-2000 cars, there should be a little black jack point in the front of the car right in the middle. Just look under your car and you'll see it. The whole front end will be lifted.
For 2001-200x cars, I just use the frame to jack up the car and stick the jack stands under one at a time on each side.
HyPeR3eR is offline   Reply With Quote
Old 08-01-2004, 07:43 PM   #11
berserker
My Ride: 2000 328i stick
front:
rear:
berserker is offline   Reply With Quote
Old 08-01-2004, 10:08 PM   #12
pyo
...Awesome!
2000 328i [Sold]
2004 Z4 3.0i 6spd
Old 08-02-2004, 08:26 AM   #13
PDACPA
Just a note.
I installed my rear spacers Saturday. My jack handle would not fit under the car so I could lift it. I had to use the factory jack to just lift the car enough so I could pump my hydraulic jack.
Thanks for the pics.
Old 08-02-2004, 06:02 PM   #14
berserker
PDACPA, lay down a slab of wood 2x8 on the floor drive up on that - that should be enough for the clearance you need - i had the same problem...
Old 08-03-2004, 10:04 AM   #15
PDACPA
Thanks! I had thought of doing that, but had no wood laying around (I think my scraps were tossed in the garage cleaning blitz! Not to mention I was trying to get them on before some people were coming over for a get together. I hate getting Mods and not installing them.....drives me crazy until I get them on and I figured it was an easy install. Which it was, the jacking up was the stumble on this install, though only minor.
Thanks again guys for the pics and tips.
Old 09-02-2004, 11:43 AM   #16
lintyLaundry
My Ride: e46 sedan
I took a quick pick of my under carriage cause it doesn't look EXACTLY like what was posted. Better safe than sorry.
So the circled bump is the center jack point in the front?
lintyLaundry is offline   Reply With Quote
Old 09-02-2004, 01:25 PM   #17
low
OG e46fanatics lurker!
My Ride: is outside
good thread
Pretty girls in bikinis...
Originally Posted by kwang1
no one ask you to click on it cry baby :cry: now I can see why Dougsun doesn't like you either.... sigh....
- I've been victimized with BOARD DRAMA!!! :lmao:
low is offline   Reply With Quote
Old 09-02-2004, 11:44 PM   #18
berserker
Dooooooooode, you still have the plastic cover on underneath you car, lage star screwdriver I think 5 screws, and it drops down, revealing the true underneath of the car.........I think I read somewhere that the jack point in the front is different after 2001, but who knows, pull off the plastic (start with the rear srews first) take more pics, and we'll see where you jack point is, but I am not feeling too good about your red circle....
Old 09-03-2004, 12:43 AM   #19
lintyLaundry
My Ride: e46 sedan
Actually, the cover is metal. But I share your skepticism about that jack point. Here is a thread I found on another forum about this same subject.
http://www.bimmerfest.com/forums/showthread.php?t=42371
I will snoop around the undercarriage tomorrow and test out how sturdy the cover is. But from my research, it seems that the oval part is the front, center jack point. I'm still uncertain though.
Old 09-03-2004, 12:52 AM   #20
THATS FRESH
My Ride: SSHNIPER
Send a message via AIM to THATS FRESH
ONE OF THE BEST AND USEFUL INFO THREADS.
aa325i stepped up to the plate.
this will be helpful and USEful to MANY.
*admins. sticky this.*
THATS FRESH is offline   Reply With Quote
