Sponsored by The Tire Rack
Old 07-19-2004, 07:20 PM   #1
F360C
My Ride: 3er Coupe
Tire PSI.... someone please help me!!!!
I have a set of 19" SSR GT3s with 235/35/19 and 245/35/19 tires on them. What PSI should I run in them? know the that on the side of the tire it says not to put in more than 51 PSI. TIA!!!!!
07 Z4 M Coupe AW/IR
306rwhp/241rwtq (Mustang Dyno)
F360C is offline   Reply With Quote
Old 07-20-2004, 09:10 AM   #2
Gary@Tirerack
Moderator
Gary@Tirerack's Avatar
My Ride: 1995 BMW M3
What exact year and model E46?
Refer to 'Gary/E46Fanatics' as your previous contact when you order online. Credit E46Fanatics.com by ordering through the sig link.
Click sig! -->
Gary@Tirerack is offline   Reply With Quote
Old 07-20-2004, 11:24 AM   #3
F360C
My Ride: 3er Coupe
2000 323ci.... thanks Gary
07 Z4 M Coupe AW/IR
Old 07-20-2004, 11:26 AM   #4
Gary@Tirerack
Moderator
BMW recommends running 29psi front and 33psi rear. You may run higher pressures if you'd like, however watch for more rapid wear on the center ribs if you do so.
Click sig! -->
