Sponsored by The Tire Rack
Old 07-22-2004, 08:55 PM   #1
ZHP
My Ride: '04 330i ZHP
What tire pressure for stock 18's?
Drive mostly in the city, can the pressure be adjusted to reduce the chance of bending a wheel. I also take frequent highway trips so i cant sacrifice much. The door sticker said max 36psi front and 46psi rear, seem strange? Currently i am running 35 in front and 41 in rear.TIA
ZHP is offline   Reply With Quote
Old 07-22-2004, 09:37 PM   #2
Dinkus
My Ride: 04 SilverGrey 330Ci
Bump i would like to know as well.
Dinkus is offline   Reply With Quote
Old 07-22-2004, 09:50 PM   #3
04ragtop
My Ride: 04 330 Cic
Just follow the info on the door sticker according the the number of passengers you most often carry. You can bump up a couple of pounds to give a little extra insurance against road damage but don't go too high or you'll wear your tires too fast.
04ragtop is offline   Reply With Quote
Old 07-22-2004, 09:50 PM   #4
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
I run 35 front...42 rear...
Old 07-22-2004, 10:30 PM   #5
audioaffliction
My Ride: 87 M6
I'm in Boston too and commute every day to the North Shore. I'm running 37 all-around right now and it's been pretty good so far. Might change things around and start running higher for the rears soon.
audioaffliction is offline   Reply With Quote
Old 07-22-2004, 10:35 PM   #6
joedaddy
My Ride: OCTA
I run 36F/41R in my 18's Style 71
joedaddy is offline   Reply With Quote
Old 07-23-2004, 08:01 AM   #7
coocoohead
My Ride: bmw 330ci
That should be fine. I actually took my car in for service yesterday and ask the same question to the head tech guy at Global BMW in Atlanta. I'm getting 18'' put on my car next week and I will run 36 in front and probably 40 in back.
coocoohead is offline   Reply With Quote
