Sponsored by The Tire Rack
Thread Tools Search this Thread Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
Old 07-29-2004, 11:42 AM   #1
mmendezm3power
My Ride: 330ci NaV steptronic
Biggest And Widest Rim...?
wHAT IS THE BIGGEST AND WIDEST RIM YOU CAN FIT ON A 330CI?
OFF-TOPIC U ALL SOULD CHECK OUT THE EVENTS FORUMS THERES ALOT OF MEET GOING ON THIS WEEKEND! CAL.PEP
mmendezm3power is offline   Reply With Quote
Old 07-29-2004, 11:46 AM   #2
BIMMERWHORE
My Ride: '99 323i
The widest in the front would be 9" and the rear would be 10". Of course you could go wider with fender modification.
BIMMERWHORE is offline   Reply With Quote
Old 07-29-2004, 12:01 PM   #3
mmendezm3power
YOU THINK I COULD FIT 275 18" ON THE REAR?
Old 07-29-2004, 02:13 PM   #4
mmendezm3power
Old 07-29-2004, 04:44 PM   #5
blurizpimpin
My Ride: 335i
Send a message via AIM to blurizpimpin
no... the max is 265 with serious fender rolling... you should just go 255 to be safe...
blurizpimpin is offline   Reply With Quote
Old 07-31-2004, 02:32 AM   #6
blackbmw330
My Ride: 2001 330ci
265 is ok depending on offset plus fender rolling.
2001 330ci retired
blackbmw330 is offline   Reply With Quote
Old 07-31-2004, 11:30 AM   #7
mmendezm3power
MY FENDER ARE ROLLED (MAX.) AND THE OFFSET IS +38MM. YOU THINK I COULD FIT 265 OR 255 ON THE REAR? THANKZ
Size 19x8.5" all around
Bolt Pattern 5x120mm
Offset +38mm all around
Old 07-31-2004, 02:31 PM   #8
doubleloseven
Slave of Barbri
My Ride: 2002 330i
255, 265 is too wide for a 8.5 rim
doubleloseven is offline   Reply With Quote
Old 08-01-2004, 12:44 AM   #9
tbone84x
My Ride: 997 + S500
I got 19X8.5 with 235 tires in the front and 19X9.5 with 265 tires in the rear.
tbone84x is offline   Reply With Quote
Old 08-01-2004, 02:41 AM   #10
Boosted_TiAg
My Ride: 09' 535xi M Sport
if you have 19x8.5 all around then you cant really have a staggered setup. if you put a 255 or a 265 size tire on a 8.5 rim then the tire will stick out too much away from the rim. i have 19x8.5 in front with a 235/35/19 tire and a 19x9.5 in the rear with a 265/30/19 tire. offset is 37. i am dropped on intrax sports (1.6 in front and 1.2 in rear) and did not need to roll the fenders if i were you then i would go with 235 tire size and maybe get some wheels spacers to get a more aggresive look by sticking out the wheels a little. good luck bro
Boosted_TiAg is offline   Reply With Quote
Old 08-03-2004, 04:08 PM   #11
mmendezm3power
Thankz Guys. Im Buying Some New Rims
Old 08-04-2004, 04:29 AM   #12
fluevog
My Ride: '00 328ci / '07 335i
i have 19x9 in front with 235/35 and 19x10 in rear with 265/30... no rolling. my offset is +38 in front and +42 in rear. no rubbing unless i have 4 people in car, as i found out last week... SUCKS, i need to buy coilovers now!
fluevog is offline   Reply With Quote
Old 08-04-2004, 11:59 AM   #13
MNbmw330ci02
My Ride: 04 VERT M3, 07 335i
i know that the biggest rims you can go with are 20's because that's what i have on my ride. i have the 225/35/20 nitto 555's and i was surprised because there's no rubbing. i can send you pics to prove it but i'm the guy having problems with my rieger kit being put on. so as soon as i get my car back, hopefully later today or tomorrow, i'll be posting up pics.
MNbmw330ci02 is offline   Reply With Quote
Old 08-04-2004, 02:07 PM   #14
mmendezm3power
I WOULD LIKE TO SEE THAT... THANKZ
