Old 04-24-2011, 08:16 AM   #41
bassem2u
My Ride: 2003 E46 330CIC
solution found!
I had the same problem as well, After replacing the spark plugs, ignition coils, and fuel injectors the problem was still there. I took out the DISA flap and it was broken, replaced it, now the car runs normal.
bassem2u is offline   Reply With Quote
Old 06-28-2011, 02:53 PM   #42
tong
My Ride: 330ci convertible
my car has a slightly different problem,it only starts to shake and move intermittely and the whole car lose power,but take note that this only happens when i drive the car really hard in the sport mode and there is also a engine checklight.
this do not happen in the normal mode even if irev really hard
i have since change all plugs and coils and the problem is still there.
does anyone of you out there has a similar problem?how did you guys fix it?
tong is offline   Reply With Quote
Old 07-19-2011, 09:43 AM   #43
association16
My Ride: 2003 BMW 330xi
I am going to buy new spark plugs and I want peoples opinions on what brand I should get. I found a pack of 6 bosch plugs for 34.95 and a kit of 6 NGK for 50. Should I just stick with the more inexpensive bosch or is the NGK a lot better and longer lasting?
association16 is offline   Reply With Quote
Old 07-19-2011, 09:50 AM   #44
CylonRed
My Ride: '01 E46 330i sport
General consensus is that NKG is the better plug - a few folks have reported problems with the Bosch.
CylonRed is offline   Reply With Quote
Old 04-20-2014, 01:58 PM   #45
c stockwell
My Ride: 2002 330ci
wow iv got the same problem w my 02 330 Ci i changed the plugs and still misfires and won't clear up as it has before, im hoping that its not the engine cu i can't afford the $1100 bucks for a new one guess i'm done look for my car going up for parts.
c stockwell is offline   Reply With Quote
Old 04-20-2014, 02:05 PM   #46
jfoj
My Ride: 330CiC, M5, X5
This is a 3 year old thread you are bringing back to life and you mention you are worried the DME/ECU may be the issue!
Forget about the DME for now, you need to gather data. Also do not knee jerk and replace the MAF as this is not likely the issue either.
You need to get an OBDII scan tool and do your homework.
$35 or less for a smart phone App and interface - http://forum.e46fanatics.com/showthread.php?t=967204
Also read the links below in my signature.
Old 08-28-2014, 03:28 PM   #47
czhawaii
My Ride: 2001 BMW 3.31
Alright guys I know this is an old feed but I am trying to track down the problem and figure a solution. The engine runs very rough. It feels bogged down and when I plugged it to the computer it gave me numerous codes: (cyl. misfires 1,2,3,4,6 fuel cutoff) (multiple misfires) (fuel lean banks 1 & 2). Ive seen on here a lot of mentions of the O2 sensors, which is something I have been hearing from people to check as it may be the cause of loss of power. top speed is down to 20 MPH Im not sure where to start... Ive seen people mention coils, plugs, clogged injector lines... and everything from here to the moon and back. The real question is whether anyone has had the same problem: numerous misfires, ridiculous loss in power (20 mph), engine roughness, bogged down sound; and how did you fix it/ where would you who haven't solved it suggest starting? because this is driving me
czhawaii is offline   Reply With Quote
Old 11-01-2016, 02:01 PM   #48
Rickey79
My Ride: 01 330i
Old thread
I'm have the same trouble I replaced everything that is being stated in this thread even the ecm and coil harness anymore in put on what can I do on fixing this problem
Rickey79 is offline   Reply With Quote
Old 11-01-2016, 02:23 PM   #49
jfoj
Start a new thread.
Provide vehicle year and mileage.
Post trouble codes, Freeze Frame data and Fuel Trim info.
Describe what happened just before the problems started, was any work performed before the problems started.
List what parts have been replaced.
